Acer Aspire 5734Z with no backlight, replaced by LED screen, still no backlight
  • ed1973
    • Sep 2013
    • 16
    • The Netherlands
    For the first time I repaired a 5734Z Acer Aspire laptop from which the backlight did not work, but the screen showed output.
    When I connected the laptop to an external monitor, it works.
    First I replaced the invertor, but the problem persisted.
    Then I ordered a new LED screen, to replace the LCD B156XW01 V.2 screen.
    According to the supplier the LED screen was a good replacement for the B156XW01 V.2 LCD.
    I replaced the screen, removed the invertor, installed the PCB, connected everything correctly, but the problem remained the same.
    I saw display output, but no backlight.
    Then I measured some connection points on the PCB which came along the LED screen:
    +VBL : 18.06V
    EN/ADJ : 3.31V
    ON/PWM: 0v
    -GND = GND
    I am not too familiar with the terms I mentioned above, but could it be that there was nothing wrong with the display, and that a fuse might have blown on the laptop motherboard ?
    When I measured voltages on the connector (which normally goes into the invertor) which I inserted in the PCB, then from left to right I measured:
    GND
    GND
    0V
    3.31V
    3.31V
    18.06V
    18.06V
  • dycc
    Vision
    • Nov 2011
    • 625
    • Côte d'Ivoire
    Re: Acer Aspire 5734Z with no backlight, replaced by LED screen, still no backlight
    ON/PWM must not be equal to ZERO . this voltage is for the brightness adjustment. use schematic to find if there is no short on this line first .
    now if you find nothing disconnect that pin (on/pwm) from the connector and connect (with tin) the EN/ADJ pin and ON/PWM pin directly on the invertor PCB.
    it will result a full brightness on the screen .
    • ed1973
      • Sep 2013
      • 16
      • The Netherlands
      So what you mean is that ON/PWM can be shorted to GND for example ?
      First I need to find the schematic of the mobo.
      If there is no short, then I can bridge EN/ADJ pin with ON/PWM ?
      • ed1973
        • Sep 2013
        • 16
        • The Netherlands
        I have sent back the LED screen to the supplier.
        Now I have the current LCD with the inverter and a connector that is going into the inverter PCB with the following voltages measure on the connector:
        GND
        GND
        0V
        3.31V
        3.31V
        18.06V
        18.06V
        I removed the wire with 0V from the connector, and put back the connector into the inverter.
        Then I soldered the 0V connection on the inverter PCB to one of the 3.31V lines.
        When I switched the laptop on, the backlight worked for a few seconds, and then turns off.
        What can I do to keep it on ?
        • spidey
          climbs
          • Dec 2012
          • 644
          • Cyprus
          ccfl or inverter.
          • ed1973
            • Sep 2013
            • 16
            • The Netherlands
            But when I replaced the LCD and inverter by a LED screen, I had the same problem.
            So the problem does not seem to be the backlight or inverter. And by the way, someone said that it is not normal that you have 0V on the incoming line ON/PWM.
            So it looks like the problem is not related to the inverter, and not related to the backlight.
            What else could it be ?
            • Claudio Silva
              • Feb 2013
              • 94
              • Portugal
              Check the S/IO chip, pin BLON (Backligth on), this pin will send the signal to activate de backlight on the LDC screen.
              • JoeyJoe
                • Sep 2012
                • 76
                I used to deal with these laptops a lot. If the laptop doesn't work on an external display, then I'm sure the GPU chip has over heated. Look up gpu reflow.
                • ed1973
                  • Sep 2013
                  • 16
                  • The Netherlands
                  The laptop is working perfectly on an external display, no problems at all.
                  So the problem is not GPU related.
                  • masud
                    • Jul 2011
                    • 317
                    • Bangladesh
                    your +VBL : 18.06V voltage is faulty (may have not sufficient amp).try to use an universal inverter.
                    • ed1973
                      • Sep 2013
                      • 16
                      • The Netherlands
                      So you conclusion is that the mainboard of the laptop, is not delivering sufficient Amp, because you think the voltage is too low ?
                      Also somebody mentioned that it is not correct that the motherboard is giving 0V on ON/PWM, and my conclusion is, is that because of that the inverter does not get the signal to turn on the backlight. Is that correct ?
                      • thezozu
                        • Jan 2014
                        • Malta
                        Hi there, did you try to adjust the brightness of the screen from the keyboard hot keys.. if you adjust it to max it should work since it varies the voltage sent to the pcb through the board.
                        • Chrissygizmo
                          samsung galaxy ao2s very temperamental after screen replaced
                          by Chrissygizmo
                          Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                          Ive eventually managed to get it on and working but it's very temperamental...
                          The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                          05-26-2024, 12:05 AM
                          ACER Aspire Aspire X3910 Aspire E5700 Specification for Upgrade or Repair
                          This specification for the ACER Aspire Aspire X3910 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire X3910 boardview and Aspire Aspire X3910 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                          09-12-2024, 03:36 PM
                          ACER Aspire Aspire XC-886 Aspire XC i5-9400 Specification for Upgrade or Repair
                          This specification for the ACER Aspire Aspire XC-886 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire XC-886 boardview and Aspire Aspire XC-886 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          09-12-2024, 03:30 PM
                          ACER Aspire Aspire XC-330 Aspire XC A4-9120e Specification for Upgrade or Repair
                          This specification for the ACER Aspire Aspire XC-330 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire XC-330 boardview and Aspire Aspire XC-330 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          ACER Aspire Aspire XC-885 I5418 NL Aspire XC i5-8400 Specification for Upgrade or Repair
                          This specification for the ACER Aspire Aspire XC-885 I5418 NL can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire XC-885 I5418 NL boardview and Aspire Aspire XC-885 I5418 NL schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                          09-12-2024, 03:28 PM
