Compaq CQ62
  • greigc
    • Jul 2013
    • 8
    Compaq CQ62
    I have two motherboards from this model with the exact same problem... Turns on and the CAPS lock light flashes 3 times then it turns off and back on, then flashes constantly.
    I have changed the memory as per HP's diagnostic table (3 Flashes states bad memory).
    I have reflown the GPU and southbridge with no difference...
    Any other ideas???
  • spleenharvester
    • Mar 2010
    • 902
    Re: Compaq CQ62
    Have you checked the 1.8v voltage supply for the RAM is present?
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
    • spidey
      climbs
      • Dec 2012
      • 644
      • Cyprus
      Re: Compaq CQ62
      it is a point.
      Also clean ram slots.
      • Pragmatiko
        • Jul 2013
        • 468
        • IT
        Re: Compaq CQ62
        bios
        • greigc
          • Jul 2013
          • 8
          Re: Compaq CQ62
          If its the bios how would I reflash it?
          • greigc
            • Jul 2013
            • 8
            Re: Compaq CQ62
            Where would I find the 1.8V on the ram?
            • Pragmatiko
              • Jul 2013
              • 468
              • IT
              Re: Compaq CQ62
              with programmer
              • spidey
                climbs
                • Dec 2012
                • 644
                • Cyprus
                Re: Compaq CQ62
                check from the schematics.
                • greigc
                  • Jul 2013
                  • 8
                  Re: Compaq CQ62
                  From what I can see there is 1.6V on the VSUS so that should be ok... Now I gotta try and find the BIOS IC ;-)
                  • Pragmatiko
                    • Jul 2013
                    • 468
                    • IT
                    Re: Compaq CQ62
                    pls write right model #ABZ
                    • sasser
                      • Dec 2012
                      • 364
                      • Malaysia
                      Re: Compaq CQ62
                      Could someone create collection for bios laptop thread . Sometimes hard to find correct bios for some model laptop. Anyone hav the collections?
                      • spleenharvester
                        • Mar 2010
                        • 902
                        Re: Compaq CQ62
                        Need the model number as someone else mentioned. You can get it from manufacturer 99.9% of the time if you put the whole model number in. The hardest part is doing the flashing
                        • greigc
                          • Jul 2013
                          • 8
                          Re: Compaq CQ62
                          I can find a pre programmed one on ebay. Its a winbond BIOS. or if I can remove the same one from another board I got lying around.
                          • greg464
                            • Jul 2013
                            Re: Compaq CQ62
                            You can try with good CPU and check CPU socket.
                            • greigc
                              • Jul 2013
                              • 8
                              Re: Compaq CQ62
                              I have tried another CPU but the error states bad memory, I know the memory is ok tho as it works fine in another laptop...
                              • greigc
                                • Jul 2013
                                • 8
                                Re: Compaq CQ62
                                Would a bad CMOS cause the cpu to not get hot? without the heatsink the cpu is stone cold, southbridge is warm and GPU is warm... this is on both boards... just flashes 3 times then goes off and back on then constantly flashes the CAPS lock.
                                • spidey
                                  climbs
                                  • Dec 2012
                                  • 644
                                  • Cyprus
                                  Re: Compaq CQ62
                                  check vcore voltages, you need a schematic. What is the mobo code ?
                                  • spleenharvester
                                    • Mar 2010
                                    • 902
                                    Re: Compaq CQ62
                                    Definitely check Vcore. If you can't find the schematic, just take your DMM, wind the ground wire round the shielding of a USB port or a similar ground, then try and get some readings off the caps behind the CPU socket.
                                      HP Compaq Compaq SG3-240ES Compaq SG3 220 Specification for Upgrade or Repair
                                      This specification for the HP Compaq Compaq SG3-240ES can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-240ES boardview and Compaq Compaq SG3-240ES schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      09-12-2024, 03:44 PM
                                      HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) Compaq Elite 8000 E5500 Specification for Upgrade or Repair
                                      This specification for the HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) boardview and Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request...
                                      HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower Compaq Pro 6005 B59 Specification for Upgrade or Repair
                                      This specification for the HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower boardview and Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                                      09-12-2024, 03:36 PM
                                      HP Compaq Compaq SG3-331IT Compaq SG3 245 Specification for Upgrade or Repair
                                      This specification for the HP Compaq Compaq SG3-331IT can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-331IT boardview and Compaq Compaq SG3-331IT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      09-12-2024, 03:30 PM
                                      HP Compaq Compaq dc7900 Compaq Q9400 Specification for Upgrade or Repair
                                      This specification for the HP Compaq Compaq dc7900 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq dc7900 boardview and Compaq Compaq dc7900 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
