IC Code
  • masud
    • Jul 2011
    • 317
    • Bangladesh
    IC Code
    anybody knows the meaning for CP-CD and DH=BM. what would be the substitute of those?
  • spidey
    climbs
    • Dec 2012
    • 644
    • Cyprus
    Re: IC Code
    Here, check it.
    • masud
      • Jul 2011
      • 317
      • Bangladesh
      Re: IC Code
      I con't find here what cp=cd is?
      • spidey
        climbs
        • Dec 2012
        • 644
        • Cyprus
        Re: IC Code
        check for "DH=" (RT8207AGQW)and "CH-" (RT9367PQW) also you can identify it by checking from the schematic. What is the motherboard code ?
        • masud
          • Jul 2011
          • 317
          • Bangladesh
          Re: IC Code
          Cp=cd??
          • spidey
            climbs
            • Dec 2012
            • 644
            • Cyprus
            Re: IC Code
            RT8207
            Part Number Product Code Package
            RT8207GQW CP= WQFN 4x4-24
            RT8207AGQW DH= WQFN 4x4-24
              LCD LED TV Service Menu Codes
              ALL LCD LED TV SERVICE MENU CODES
              Service Menu Code with Board Name
              China Universal Board / Jumper Board Service Menu Code
              Changhong Ruba Service Menu Code
              Ecostar LED TV Service Menu Code
              Orient LED TV Service Menu Code
              Haier LED TV Service Menu Code
              TCL LED TV Service Menu Code
              Samsung LED TV Service Menu Code
              LG LED TV Service Menu Code
              Videocon LED TV Service Menu Code
              Supra LED TV Service Menu Code
              Toshiba LED TV Service Menu Code
              Symphony LED TV Service Menu Code
              Veste/ LED TV Service Menu Code...
              10-31-2024, 03:58 AM
            • Curtissimo
              HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
              by Curtissimo
              Hi everyone.
              I have a HP Elitebook 850 G8.
              Serial: 5CG2324XM0
              ProdID 6L8D5EC#ABA
              It has a Winbond W25Q256JVEN Chip.
              I need to remove BIOS Password.
              I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
              Attached my dump.
              I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
              I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
              What I did:...
              08-26-2025, 04:42 AM
            • Sorrow1
              Intergraph TDZ 2000 mainboard post code 2F/2E
              by Sorrow1
              I try to repair an old Intergraph TDZ 2000 from 1998. It is a dual Pentum II machine based on Intel 440LX chipset. There is a non-removable bios chip named PhoenixBios B1787840. I cannot see any physical damage to the board. All caps look OK.
              It shows no picture and POST stops with code 2F/2E regardless whether or not any graphic card is plugged in. If memory is removed, it stops on previous code 28/17 and stars beeping. I tested both CPUs in another machine and I also use RAM from another machine.
              When I recorded video of POST card and played it in slow...
              01-03-2024, 04:13 AM
            • DynaxSC
              MSI PRO Z690-A DDR4 (MS-7D25) - stuck during boot every second time - debug code 16 & A1
              by DynaxSC
              Hi Folks
              I have an MSI PRO Z690-A DDR4 (MS-7525) which underwent LGA1700 replacement and had a missing resistor in the VRM section. The missing resistor RV170 (49,9Ω) has been resoldered, and I have also replaced a demaged LGA1700 socket.
              Generally the board does boot to Windows, but not always in the first attempt, but after the second attemp to boot the board with Power Button. Also restarting the board from Windows ends up with stuck boot process, but restarting the board again (long push Power Button or switching off and on PSU). Under Windows etherything works
              09-29-2024, 04:27 PM
            • Ebarlas
              Wht is caps code meaning on schematics
              by Ebarlas
              Hi all. I couldnt figure out the coding here can someone help?
              Sc means seramic capacitor i guess. But not sure about the rest
              scd22u10v2kx-1gp
              05-26-2022, 05:59 PM
