Toshiba Satellite L500-1R1 no backlight
  • rtstorm
    • Feb 2012
    • 971
    • Croatia
    i have this toshiba, when turn ON, all working ok but no backlight on LCD.
    I disassemble the screen and i think this is LED LCD so no inverter.
    Can you please check the photo of the LCD board and tell me what should i check.
    I see on one pict there is circle component marking (220). Is this a capacitor?
    Thank you
    ...the quieter you become the more you are able to hear...
  • dycc
    Vision
    • Nov 2011
    • 625
    • Côte d'Ivoire
    Re: Toshiba Satellite L500-1R1 no backlight
    Pin 1 ,2,3=19v (VSL)
    pin 5=3.3v (BL_EN)
    pin6= 3.3v for full brigthness (PTW)
    • rtstorm
      • Feb 2012
      • 971
      • Croatia
      pin 1= 0V
      pin 2,3 =3V
      pin 4,5,6 =3.15
      • rtstorm
        • Feb 2012
        • 971
        • Croatia
        I think i dont have anyware 19V on JLVDS connectror on mainboard.
        Here is schematic
        • rtstorm
          • Feb 2012
          • 971
          • Croatia
          i found 19V on LCD board, it is marked here.
          • dycc
            Vision
            • Nov 2011
            • 625
            • Côte d'Ivoire
            0.81v is too small for back light control . it should be between 2 and 3v max . reflow GPU and if it does not not work ; disconnects the connector pin(0.81v) and with a wire ,solder 3V(+v3alw) directly from the motherboard up to the screen at pin ptw(0.81v).
            • dycc
              Vision
              • Nov 2011
              • 625
              • Côte d'Ivoire
              it'll work, but it may display blank screen before the writing appears. minor annoyance but it does not prevent the laptop to operate
              • rtstorm
                • Feb 2012
                • 971
                • Croatia
                But i can see the picture on display only backlight is not working, is this really issue with GPU?
                • dycc
                  Vision
                  • Nov 2011
                  • 625
                  • Côte d'Ivoire
                  yes because GPU trigger the switch who give brightness
                  • dycc
                    Vision
                    • Nov 2011
                    • 625
                    • Côte d'Ivoire
                    according to your diagram you have to disconnect pin 11(JLVDS) on page 18 . solder +3VALWP(page 40) on it and you will see the magic .
                    • rtstorm
                      • Feb 2012
                      • 971
                      • Croatia
                      Hmm how to disconnect pin 11? Any suggestion so I do not break that pin.
                      But i noticed that i dont have anymore picture on LCD, only on VGA output. I check Fuses and noticed that fuse is dead, i dont know how but it is not pass contingency test.
                      What value is that fuse?
                      • rtstorm
                        • Feb 2012
                        • 971
                        • Croatia
                        i got pictiure on LCD, still no backlight. i will try to connect +3VALWP (page 40).
                        But i am not shure how to disconnect pin 11(JLVDS)
                        • rtstorm
                          • Feb 2012
                          • 971
                          • Croatia
                          is it necessary to disconnect pin 11 on JLVDS? can i just connect +3VALWP directly on pin 11 JLVDS?
                          • alihomee
                            • Dec 2012
                            • 1575
                            • malaysia
                            did you try with other led and cable?
                            • rtstorm
                              • Feb 2012
                              • 971
                              • Croatia
                              No i dont have another led this type
                              • spleenharvester
                                • Mar 2010
                                • 902
                                Maybe you could break Pin 11 off on the cable side? I'm not too sure.
                                Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
                                • rtstorm
                                  • Feb 2012
                                  • 971
                                  • Croatia
                                  hmm ok, i will try that way.
                                  • rievax_60
                                    • May 2012
                                    • 897
                                    • australia
                                    I first try to apply the voltage through a resistor to avoid causing more damage.
                                    470 ohm to 1k should be ok.
                                    • spidey
                                      climbs
                                      • Dec 2012
                                      • 644
                                      • Cyprus
                                      i think you have problem with your led control ic or led itself. Check the working conditions of ic, in the 2nd photo near the ribbon cable which goes to leds.
                                      • rtstorm
                                        • Feb 2012
                                        • 971
                                        • Croatia
                                        i disconnect pin11 and connect +3VALWP on it, but light wont turn on. Now i have 3V on PWM. Is this the LCD screen fail?
                                        @spidey: how can i check this IC?
                                          Toshiba Satellite Pro L300-156 Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro L300-156 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L300-156 boardview and L300-156 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                          09-06-2024, 05:27 AM
                                          Toshiba Satellite Pro A50-E-1CH Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro A50-E-1CH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A50-E-1CH boardview and A50-E-1CH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 07:07 AM
                                          Toshiba Satellite Pro A200-1K4 Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro A200-1K4 can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A200-1K4 boardview and A200-1K4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                                          Toshiba Satellite Pro L350-17D Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro L350-17D can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L350-17D boardview and L350-17D schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                                          Toshiba Satellite Pro A300-22J Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro A300-22J can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A300-22J boardview and A300-22J schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
