notebook hp g62 not turn, component burned, (mayabe controller)
  • tanohack
    • Feb 2013
    • 38
    • Italia
    Hello, i was very unlucky...
    (I write from tablet)
    The my notebook hp g62 450 sl, does not turn after cortocircuit port usb.
    When I connected the pendrive bad on usb lateral port, the notebook was still working, but overloaded and something and I started to smell and smoke, the pc does not shut down, it was working normally, but when it was turned off and turned on not more.
    Then i disassembled and i watch component burned around port usb, my problem is, what's the component ? Where is the one new ?
    The last trhee number of code on chip was 7f2...
    (Sorry if i misspelled, write from tablet is uncomfortable, if there are mkssing details i add later, i am italian)
    Component in photo. PLEASE HELP .
  • spidey
    climbs
    • Dec 2012
    • 644
    • Cyprus
    Re: notebook hp g62 not turn, component burned, (mayabe controller)
    need photo..
    • whaldsz
      • Apr 2013
      • 395
      • Philippines
      It is U28:
      M219
      G54F72
      • tanohack
        • Feb 2013
        • 38
        • Italia
        Here the pictures of the component bad...
        Now I unsoldered that component in the picture and I did try turning on your pc, and the part near the attack power supply makes a little noise TIC TIC (as if something does not start) and the adjacent parts heat up a little, but the pc does not turn on. I want find the component you want and burned and re-welded..
        • tanohack
          • Feb 2013
          • 38
          • Italia
          Originally posted by whaldsz
          It is U28:
          M219
          G54F72
          Thanks for reply,
          Sorry, but..what do you mean U28 ?
          I searched on google and ebay this code G54F72 M219 and i not found anything, where can find and buy this component burned..?
          Thanks ..
          • whaldsz
            • Apr 2013
            • 395
            • Philippines
            U28 is the symbol in the schematic diagram. In the schematic (page 29) there are some IC Part No there, you can use it.
            One example is this - http://tinyurl.com/l2ozzhs
            • spidey
              climbs
              • Dec 2012
              • 644
              • Cyprus
              if it is a 5v switch for usb, de-solder it. wire +5v from another always on switch.
              • tanohack
                • Feb 2013
                • 38
                • Italia
                There, is a circuited integrated not switch..
                • spidey
                  climbs
                  • Dec 2012
                  • 644
                  • Cyprus
                  • tanohack
                    • Feb 2013
                    • 38
                    • Italia
                    So the chip that I've linked on ebay, should be fully compatible ..? (I did not see diagram) I saw that the feet of the larger 'original. Now I buy it and I will let you know if the PC will turn on again ...
                    Thanks very much
                    • nfikh
                      • Jun 2013
                      • Moroocco
                      please I need the help
                      I want to know some of the values of the voltage Mosfet
                      because I have the power problem
                      sory my english is bad
                      • tanohack
                        • Feb 2013
                        • 38
                        • Italia
                        Today arrived by courier the chip, hope in lucky..
                        • whaldsz
                          • Apr 2013
                          • 395
                          • Philippines
                          Goodluck!
                          • tanohack
                            • Feb 2013
                            • 38
                            • Italia
                            Goodluck!
                            Thank you, but unfortunately I was unlucky, (for second time) while I was cleaning the contacts after removing the chip burned, the pond is not taking off and came off a leg from the motherboard, and now I do not know where to weld it ...
                            Yes came off the fourth pin in the upper right...
                            There another point where the motherboard solder this pin ?.. see on the diagram, i not found..
                            • whaldsz
                              • Apr 2013
                              • 395
                              • Philippines
                              if that is so, then just follow spidey's advise,
                              or short PIN 2 to PIN 8 - this will provide a direct 5V supply to the USB port.
                              • tanohack
                                • Feb 2013
                                • 38
                                • Italia
                                Thanks for reply,
                                what is the pin 8? I do not have the diagram..
                                I then short the pin 2 and pin 8 of the motherboard..?
                                Old photo with pin cut...example..
                                http://s24.postimg.org/trchoqzxf/paint_11362172947.png
                                • whaldsz
                                  • Apr 2013
                                  • 395
                                  • Philippines
                                  yes, see the attached picture.
                                  • tanohack
                                    • Feb 2013
                                    • 38
                                    • Italia
                                    I am in sea of shit...
                                    I have short pin 2 and pin 8, but when I connected the power supply another component is burned and the PC not boot, turn on and turn off, and overheated component board but not work...
                                    Attached files...
                                    • whaldsz
                                      • Apr 2013
                                      • 395
                                      • Philippines
                                      It means there are other shorted components. You must find these shorted components before powering your laptop again.
                                      • tanohack
                                        • Feb 2013
                                        • 38
                                        • Italia
                                        Surely... The PC now turn on and off equal, also without short circuit of pin 2 and 8 of motherboard...
                                          HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-07-2024, 06:40 AM
                                          Samsung Notebook Plus2 Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Notebook Plus2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Notebook Plus2 boardview and Notebook Plus2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-07-2024, 05:20 AM
                                          Lenovo Legion Laptop Gamer Notebook Legion 5 15ACH6H Notebook Specification for Upgrade or Repair
                                          This specification for the Lenovo Legion Laptop Gamer Notebook Legion 5 15ACH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Laptop Gamer Notebook Legion 5 15ACH6H boardview and Laptop Gamer Notebook Legion 5 15ACH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-07-2024, 05:00 AM
                                          Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          LG GRAM NOTEBOOK SILVER 16.0 I5 Notebook Specification for Upgrade or Repair
                                          This specification for the LG GRAM NOTEBOOK SILVER 16.0 I5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GRAM NOTEBOOK SILVER 16.0 I5 boardview and GRAM NOTEBOOK SILVER 16.0 I5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                          09-07-2024, 04:10 AM
