Please help me ACER ASpire 4750z auto power on
  • sasser
    • Dec 2012
    • 365
    • Malaysia
    hye all profesional here. i got 1 acer aspire 4750z. the problem is when the charger is connected to laptop system power up without presssing button. when shutdown my laptop restart not totaly power off.
    my solution is replace new cmos battery--not ok this laptop power on without cmos battery when put batery cmos laptop cant power on
    3v/5v/19v all present value
    already flash bios -- still same
    check processors / ram --all good.
    check all mosfet -- no trace fault
    help me
  • spidey
    climbs
    • Dec 2012
    • 644
    • Cyprus
    Re: Please help me ACER ASpire 4750z auto power on
    reflow south.
    • sasser
      • Dec 2012
      • 365
      • Malaysia
      Originally posted by spidey
      reflow south.
      Tq spidey. I try later then post the result here
      • sasser
        • Dec 2012
        • 365
        • Malaysia
        reflow south.
        after reflow laptop cant power on only orange indicator light appear. look at the picture . any one have an idea? now my laptop cant on
        • spidey
          climbs
          • Dec 2012
          • 644
          • Cyprus
          if you heated too much it is possible. did you apply flux under it before heating ? Try reflow again, if it doesnt work you have to reball or replace with a new one.
          • sasser
            • Dec 2012
            • 365
            • Malaysia
            thanks spidey. i update latest now my laptop can turn on till window desktop. the problem before this bios chip cold solder join. so i fix with resolder back. acer give orange indicator as checker bios problem. if im wrong let me know.
            my problem now is my laptop can turn on without cmos battery. anyone help me what the problem is ? maybe im do some missing checking.
            • sasser
              • Dec 2012
              • 365
              • Malaysia
              im study the rtc power. seem like leakage for Q6001. pin 3 i got same value rtc batery. that wrong or not?
              • Francisco.s
                • 686
                • Spain
                Currents involved in that circuit, are extremely low, so voltage drop in resistance are also low, so I think are normal values.
                • sasser
                  • Dec 2012
                  • 365
                  • Malaysia
                  Ok thanks for your info francisco. Im still not found where the leakage. My laptop still outo power on cant shutdown also. Put rtc batteries cant power on
                  • spidey
                    climbs
                    • Dec 2012
                    • 644
                    • Cyprus
                    it is south bridge, if reflow didnt work, you must reball. it is the solution.
                    • Francisco.s
                      • 686
                      • Spain
                      I don't understand what you say, and what the problem is.
                      All laptops can turn on without cmos battery, but obviously all settings will lost.
                      • spidey
                        climbs
                        • Dec 2012
                        • 644
                        • Cyprus
                        No, it is not true. You cant power on AMD systems, and most of intel systems, without cmos battery installed.
                        • tomodachi
                          • Apr 2012
                          • 610
                          • Turkey
                          Yeah I agree that.
                          • Francisco.s
                            • 686
                            • Spain
                            I always disconnect the cmos battery when reprogramming bios chip, and only reconnect it when the motherboard is fully functional. Till now I haven`t any issues.
                            • sasser
                              • Dec 2012
                              • 365
                              • Malaysia
                              Agree spidey then fyi acer like 4551 aspire 4732 4810 also hav check all voltage and if your rtc batteries below 1.8v the system cant power on. After replace then system up thats my exp. But for this problem 4750z still no solution. I musy follow suggestion from spidey to reball sb
                              • Francisco.s
                                • 686
                                • Spain
                                Right now, I have a Sony vgn-nw21(cpu Intel) and an Asus x5 (cpu Amd) that works without the cmos battery, and woks perfectly well. (except date and clock)
                                Perhaps the controversy is that you have cmos battery connected, and is draining current from VCC_RTC, due to internal leakage.
                                Sometime I can read in forums what you say, but till now, it never happen to me.
                                Regards.
                                • sasser
                                  • Dec 2012
                                  • 365
                                  • Malaysia
                                  thanks for sharing your knowledge here. back to the main problem anyone can guide me what should to do. the problem auto on still happen. i got also compaq v3000 also turn on automatically when charger is pluged in with no display.
                                  • Francisco.s
                                    • 686
                                    • Spain
                                    What about reball sb?
                                    • sasser
                                      • Dec 2012
                                      • 365
                                      • Malaysia
                                      ok i will try it. reball acer sb. any update i post here thanks
                                      • aspire550z
                                        • Oct 2011
                                        • 5
                                        • TM
                                        Regards.
                                        you should try on aspire 4551....
                                          ACER Aspire Aspire E560 Aspire E6400 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire E560 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E560 boardview and Aspire Aspire E560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 03:28 PM
                                          ACER Aspire Aspire E700 Aspire E6300 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire E700 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E700 boardview and Aspire Aspire E700 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 02:30 PM
                                          ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-06-2024, 05:27 AM
                                          ACER Aspire Aspire M7200 Aspire 805 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire M7200 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7200 boardview and Aspire Aspire M7200 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
