Toshiba C655-S5128 power problems
  • johnnysnavely
    • Apr 2013
    • 7
    • usa
    Thanks for letting me join the forum! I used to repair stereo and TV in the 80's and have fixed all my electronics since then.
    A friend asked me to fix his laptop. At first, it would go through BIOS and then die as soon as it started booting from HD. I removed the HD, and verified that wasn't the problem. I had to do a scan disk and fix the Master Boot and now the HD is fine.
    Put the HD back in the computer and same thing happened - it died as soon as it start booting.
    Here's where it gets interesting. Next, I took the battery out and tried starting it up with just power brick.
    Now it won't power up at all or go into BIOS like it used to. With or without the battery!
    I think the battery is OK. The AC power light light was yellow with the battery plugged in, and after an hour it's now Green. So it'll charge the battery with the power off. But laptop is dead.
    Where do I start? (Sorry, I dont have a schematic). I did find a tutorial on how to disassemble down to the motherboard.
  • fddizon
    • Sep 2011
    • 555
    • Philippines
    Re: Toshiba C655-S5128 power problems
    Here's where it gets interesting. I took the battery out and tried starting it up with just power brick. Now it won't power up at all or go into BIOS like it used to, even with battery!
    I think the battery is OK. The AC power light light was yellow with the battery plugged in, and after an hour it's now Green. So it'll charge the battery with power off. But laptop is dead.
    try fixing the power brick first... battery i think is fully discharged.
    • johnnysnavely
      • Apr 2013
      • 7
      • usa
      Thanks, but I just now tried a known good brick and got the same results. If someone can point me to a good Toshiba power supply basics post I will try to take it from there.
      Or maybe someone had the same problem with their Toshiba laptop?
      • perette
        • Mar 2013
        • 71
        • france
        Hello.
        I would suggest to do the following
        - remove battery, unplug power supply and press start for 30 sec.
        - plug power supply and try restart.
        If nothing happens then, the problem is in the beast.
        Is this machine old? you can suspect one of the components to unsolder over time and as soon as the system switch it on, the all PC crash (I have nearly the same case with the ATI GPU of one of my machines)
        What's the model you are working on?
        best
        P
        • johnnysnavely
          • Apr 2013
          • 7
          • usa
          The model number is in the title of my post.
          Yes, I have tried the 30 sec power button trick.
          What next? Thanks
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            Would it startup on battery just fine? We might have another case of the bad capacitor made by 'nec-tokin'. There is a megathread on here just for that.
            Muh-soggy-knee
            • spidey
              climbs
              • Dec 2012
              • 644
              • Cyprus
              if you leave it in bios setup, does it works or dies after a couple of seconds ? did you unassambly the laptop ? check the mobo with a magnifier, look for a liquid trace. Also clean the cooler unit and change thermal compound. read the mobo code and write it to your reply, so i can find a schematic for you.
              • johnnysnavely
                • Apr 2013
                • 7
                • usa
                It will not startup on battery alone, or with brick, so I cannot get to BIOS setup.
                I will try to get the MOBO code tonight, thanks much spidey and ben7!
                In the meantime, it sounds like a straightforward power problem, so one of those 8 pin power ICs maybe?
                • DCJack
                  • Apr 2013
                  • 26
                  Have you tested the power supply under load? I would do some power math and figure out what value of resistor you would need to almost max out the current rating of the power supply and use an appropriate power rated resistor (more often then not a flame-proof resistor) to short the DC output of the power supply and check to see if the proper voltage shows on the volt meter.
                  If the power supply passes the load test I would the check all the FETs on the mainboard for shorts (majority of the 8-pin ICs on a laptop board are FETs). This is a simple matter as pins 1-3 are internally connected to each other as the Source, pin 4 is the Gate and pins 5-8 are the Drain. Test as you would a 3-pin FET or transistor. Be aware that some FETs will test shorted on board but when removed they test good. Also be aware that some of the 8-pin ICs are not FETs and you need to Google data sheets before removing the IC to test out of board.
                  If all the FETs pass then you need a current limiting bench power supply and find a 19v(usual laptop main power voltage) point on the board that is triggered when you press the power button. Supply 5v to that point until the power supply hits the current limit (1-2 Amps is a good number) and check for hot capacitors. On laptop boards they are the light brown looking rectangles(the gray ones are coils/inductors).
                  And that is the limit of my testing knowledge. If these test do not point you to a fault then I assume it is one of the major ICs and I do not have the skill or tools to diagnose past this point.
                  Good luck.
                  • johnnysnavely
                    • Apr 2013
                    • 7
                    • usa
                    Awesome writeup! Couldn't get to it last night, hope to tonight.
                    • johnnysnavely
                      • Apr 2013
                      • 7
                      • usa
                      Hi Spidey, the MOBO code is 6050A2355202-MB-A03-T1
                      Does that seem right? Is there any database showing common problems with this MOBO? thanks! - John
                      • spidey
                        climbs
                        • Dec 2012
                        • 644
                        • Cyprus
                        it should has a different code, this one is look like a pcb code. is it amd or intel, uma or discrete? there are 4-5 different mobos for c655.
                        • johnnysnavely
                          • Apr 2013
                          • 7
                          • usa
                          Thanks Spidey, i think it is V000225000.
                          By the way, you asked if BIOS would work for a few seconds or a long time? Before the computer died completely, I could look around in BIOS all I wanted to. But as soon as it tried to boot from HD, thats when it would shut down or go into black screen. I know Master Boot Record problem will do that, but the computer would not boot from DVD if I chose that option (it would just shut off). So I think there was a power problem then, and there is definitely a power problem now!
                          By the way, if I take the easy way out and buy a used MOBO, what is the difference between V000225000, V000225010, etc
                          • alphatech008
                            • Dec 2011
                            • 6
                            Hi johnnysnavely,
                            your laptop is having either sio chip or charging chip problem.
                            you should check sio chip and charging chip well.
                            • spidey
                              climbs
                              • Dec 2012
                              • 644
                              • Cyprus
                              i think V000225000 is a toshiba part number.
                              • PantherDave
                                by PantherDave
                                Hi all!
                                05-29-2024, 02:01 PM
                                by sam_sam_sam
                                03-31-2024, 02:12 PM
                              • megcox
                                ASUS PD551LA REV2.0 not booting after one week power off
                                by megcox
                                Hi everybody
                                My ASUS PD551LA (REV 2.0), after a week powered off with power adapter disconnected, is not booting anymore.
                                If I plug the adapter, the battery is charging, the power led lights but after pressing the power button there is no sign of life.
                                I've found the Boardview file of the motherboard and the schematic of PU551JA (that looks 99% compatible).
                                I've disconnected the battery and all devices except screen (I removed also the RTC battery, hope it's not a problem at this stage...) and checked all signals and power rails involved in the power on s...
                                10-12-2024, 03:26 AM
                              • ju123
                                Toshiba Satellite C50-A won't power down
                                by ju123
                                Hi guys,
                                So, I've been racking my brains on this one.
                                I have a Satellite C50-A which I'm repairing for a friend.
                                I recently replaced the main board due to failure.
                                Following this, absolutely everything works perfectly, except for the fact it won't power down.
                                Initially, shutting down via Windows would shut the OS down, screen would turn off (noticed the lighter black go to what looks like the darker black powered off screen as though the backlights have powered off), however the laptop was still running internally with a spinning...
                                01-07-2022, 04:40 PM
