lenovo G550 zombie laptop.
  • pocgoc
    • Nov 2012
    • 36
    • Singapore
    Hi i have a Lenovo G550 laptop.
    It has no LED lights , no charging and no sign of power.
    I checked the charger 19.34v so its okay, checked the DC Jack it is sending power to the board okay. But the gateways and capaictors have power running through it.
    Bad bios flash maybe? Or maybe a power controller chip.
    No lights on charging
    no power with charger and battery
    Model :KIWA7 LA-5082P
    datasheet link:
    http://www.scribd.com/doc/132659282/...3da3ydwhq551tq
  • pocgoc
    • Nov 2012
    • 36
    • Singapore
    Re: lenovo G550 zombie laptop.
    any tips on which compents to test first would be most welcome. PIcs
    • Tuomo
      • 163
      • Finland
      datasheet link:
      First check voltages on PQ301 and PQ302.
      • spidey
        climbs
        • Dec 2012
        • 644
        • Cyprus
        first measure rtc battery at least 2.6v needed to power up. measure current to know if standby exist, then check 3v and +5v present. measure pwr button +3.3v, if there is then press button to see 0v. unless find the schem trace back to keyboard controller ic. still no re-program bios. still no ? connect to scope check south xtal. then check clock chip xtal. ten reflow south to see if it is the problem. if yes reball it unless change keyboard controller. But if you dont have +3 +5 v let me know.
        • pocgoc
          • Nov 2012
          • 36
          • Singapore
          Okay rtc =2.61v (ok)
          Pwr button = 17.42v - pressed button 0.00v (?)
          I can't get the current ,no standby?
          • pocgoc
            • Nov 2012
            • 36
            • Singapore
            pq301
            here is the results they look fine
            • Tuomo
              • 163
              • Finland
              pq301
              Yes, they are fine.
              Next 3V and 5V always PL401 and PL402.
              • pocgoc
                • Nov 2012
                • 36
                • Singapore
                PQ304 mosfet i have noticed, that its drains 5-8 have 0 volts and source 1-3 is 19.23v and Gateway 4 is 19.23v instead of 12.95v like pq302 and pq301 mosfet which are also FDS6675BZ
                • pocgoc
                  • Nov 2012
                  • 36
                  • Singapore
                  pq304 mosfet i have noticed, that its drains 5-8 have 0 volts and source 1-3 is 19.23v and gateway 4 is 19.23v instead of 12.95v like pq302 and pq301 mosfet which are also fds6675bz
                  pl401 =0.025v
                  pl402 =0.008v
                  • pocgoc
                    • Nov 2012
                    • 36
                    • Singapore
                    RICHTEK RT8206B GQW QFN 32pin Power IC Chip PU401 is heating up and is responsible for delivering and managing 3v and 5v supply in the board. Hmm i wonder is this the origin of my problem.
                    • Tuomo
                      • 163
                      • Finland
                      pl401 =0.025v
                      pl402 =0.008v
                      PQ302 etc. are P type mosfet, if Gate is 19V they are closed.
                      Always voltages missing. Nothing works vithout those voltages.
                      Can you measure PU401 PIN 6 VIN, PIN7 LDO.
                      • pocgoc
                        • Nov 2012
                        • 36
                        • Singapore
                        PIN 7 IS 19.22V
                        PIN 6 is also 19.22v
                        • Tuomo
                          • 163
                          • Finland
                          PIN 7 IS 19.22V
                          PIN7 Ok, PIN 6 VL usually 5V have to check.
                          Can you measure PIN 1, 4, 14, 27, 28.
                          • Tuomo
                            • 163
                            • Finland
                            Yes it is very possible.
                            • pocgoc
                              • Nov 2012
                              • 36
                              • Singapore
                              Thanks Tuomo , i got it going by replacing It with new one.
                              but now i got a dark screen , it doesn't power up the back light of the LCD. Tried 2 screens no back light on either.
                              I wonder is it my LCD cable, here is my LCD /dvi /Lvcds connector pinot with voltages
                              Any help Ill be very grateful
                              • pocgoc
                                • Nov 2012
                                • 36
                                • Singapore
                                I replaced the RICHTEK RT8206B GQW QFN 32pin Power IC Chip PU401.
                                1. I got power.
                                2. It turned on but the LCD was dim.
                                3. plugged in the battery , charged but U50 got extremely hot.
                                4. RT8206B PU401 failed , started heating up again.
                                • Tuomo
                                  • 163
                                  • Finland
                                  1. I got power.
                                  5VALW go to U50, and if U50 or U50 OUT is shorted it may cause RT8206B fail.
                                  Measure U50 OUT pins resistance and C440.
                                  • pocgoc
                                    • Nov 2012
                                    • 36
                                    • Singapore
                                    C440 = 6.4 ohms
                                    U50:
                                    pin5(OC#)= 6.10kOhms
                                    pin6(out)=6.4ohms
                                    pin7(out)=6.5ohms
                                    pin8(out)=6.3ohms
                                    pin1(gnd)=0.2ohms
                                    pin1(IN)=6.5ohms
                                    pin1(IN)=6.5ohms
                                    pin4(EN)=1.9ohms
                                    • pocgoc
                                      • Nov 2012
                                      • 36
                                      • Singapore
                                      PIN 8 oc# = 6.10Kohms
                                      PIN 7 OUT = 6.5ohms
                                      PIN 6 OUT = 6.5ohms
                                      PIN 5 OUT = 6.5ohms
                                      PIN 4 EN = 1.9ohms
                                      PIN 3 IN - 6.5ohms
                                      PIN 2 IN = 6.5ohms
                                      PIN 1 GND = 0.2ohms
                                      C440 =6.4ohms
                                      • Tuomo
                                        • 163
                                        • Finland
                                        PIN 7 OUT = 6.5ohms
                                        PIN 6 OUT = 6.5ohms
                                        PIN 5 OUT = 6.5ohms
                                        PIN 4 EN = 1.9ohms
                                        PIN 3 IN - 6.5ohms
                                        PIN 2 IN = 6.5ohms
                                        PIN 1 GND = 0.2ohms
                                        C440 =6.4ohms
                                        U50 OUT pins are 5V for USB its resistance should be > 300ohm.
                                        Remove U50 and measure pins.
                                        If OUT pins still low resistance check USB connectors and C442 and C443.
                                          Lenovo Yoga Yoga 7i (16? Intel) 2 in 1 Laptop Notebook 700 Specification for Upgrade or Repair
                                          This specification for the Lenovo Yoga Yoga 7i (16? Intel) 2 in 1 Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Yoga 7i (16? Intel) 2 in 1 Laptop boardview and Yoga 7i (16? Intel) 2 in 1 Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          09-07-2024, 05:00 AM
                                          Lenovo Legion Laptop Gamer Notebook Legion 5 15ACH6H Notebook Specification for Upgrade or Repair
                                          This specification for the Lenovo Legion Laptop Gamer Notebook Legion 5 15ACH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Laptop Gamer Notebook Legion 5 15ACH6H boardview and Laptop Gamer Notebook Legion 5 15ACH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                        • thxd43
                                          Lenovo laptop does not turn on, what does this number mean in a BIOS chip?
                                          by thxd43
                                          Hello, first of all, excuse me, I am using the translator, English is not my native language.
                                          I have a Lenovo ideapad 330S - 14IKB laptop.
                                          The tablet did not recognize me when I connected it, so I checked the device manager and I realized that there were many with the exclamation mark, so one by one I began to update their drivers until the sign disappeared of admiration, I even updated the BIOS, and the laptop rebooted normally and worked, so far so good, but the tablet still did not recognize me, I read on the internet that it could be due to a...
                                          02-23-2023, 08:37 PM
                                        • Evgenii999
                                          Laptop Lenovo IdeaPad 3 15ITL05 doesn’t turn on.
                                          by Evgenii999
                                          I need your advice in diagnosing a motherboard issue on a Lenovo IdeaPad 3 15ITL05, motherboard HS45A/HS55A Rev 1.0 NM-D461 (2020-11-02).
                                          Symptoms:
                                          The laptop does not power on and does not respond to the power button.
                                          Background:
                                          According to the owner, her child was playing on the laptop when it suddenly shut down.
                                          What has been done so far:
                                          Original charger is missing; the non-original one was tested and found faulty (0 V output).
                                          Using a lab power supply (20 V, 0.5 A) — no activity on the board, no LEDs, no standby voltages....
                                          10-25-2025, 06:07 AM
                                        • JDong
                                          Problems flashing BIOS for supervisor locked Lenovo V15 G4 IRU 831A laptop
                                          by JDong
                                          There was an error... Aborting......I'm using another Linux Laptop with Zorin OS...to try and patch my Lenovo V15 G4 IRU with above specs....It originally had Windows 10/11 installed and converted to a dual boot Kali OS/Parrot OS system. I may have used the wrong lenovo_autopatcher_0.2 (I believe was posted by @knucklegrumble....I am out of ideas and flat broke so i cannot afford another fix (spent it all as an e-com entrepreneur does) any help from anyone would be GREATLY appreciated.....
                                          • Laptop Model: Lenovo V15 G4 IRU
                                          • Issue: Forgotten supervisor password.
                                          • BIOS Chip: GD25B128E (or GD25B128B
                                          07-06-2025, 10:18 PM
