IBM Thinkpad T43 hangs/can't boot when using power adapter but OK with batt
  • spintop
    • Feb 2011
    • 132
    My T43 is facing some issue recently.
    - Laptop works perfectly using the battery alone.
    - When used with the power adapter with or w/o batt, it failed to boot some times. If it did boot to Windows, it will hang after awhile.
    - The batt can charge when inserted into the laptop.
    - F2 fuse is OK
    Suspect issue with the MOSFET, but not too sure.
    Seek some advice here.
  • Tuomo
    • 163
    • Finland
    Re: IBM Thinkpad T43 hangs/can't boot when using power adapter but OK with batt
    - F2 fuse is OK
    You need schematic first, then we can try to help you.
    • spintop
      • Feb 2011
      • 132
      this should be it.
      BTW, sometimes with the power adapter the laptop will beep 1-3-3-1. but still fail to boot. again with just the battery pack everything OK.
      • spintop
        • Feb 2011
        • 132
        readings noted (refer to page 71)
        With Power adapter (rated 16V, 4.5A) only, laptop don't boot usually, sometimes it boot, sometime beep, fan is running.
        - Q36
        Pin 1,2,3 = 16.5V
        Pin 4 " = 1. (High impedance ? I am not sure what is this reading means on the meter)
        Pin 5,6,7,8 = 16.5V (VINT16)
        - Q13
        Pin 1,2,3 = 0.1V
        Pin 4 " = 0.1V (with no batt pack, this signal is disable by the controller, U61)
        With Batt pack (12V) only, laptop work perfect
        - Q36
        Pin 1,2,3 = 0.25V
        Pin 4 " = 0V (Controller disable the FET, when no power adapter)
        Pin 5,6,7,8 = 11.4V (VINT16)
        - Q13
        Pin 1,2,3 = 11.4V
        Pin 4 " = 18.6V (signal is enable by the controller, U61)
        these 2 MOSFETs seem to be working fine.
        I uncertain for the reading "1." in Q36, if this is an issue.
        This main board most passive parts are not labelled, so finding them is abit tough.
        • Tuomo
          • 163
          • Finland
          - Q36
          Pin 1,2,3 = 16.5V
          - Q13
          Pin 1,2,3 = 0.1V
          - Q36
          Pin 1,2,3 = 0.25V
          - Q13
          Pin 1,2,3 = 11.4V
          Those looks ok if those are measured values.
          Can you try another Power Adapter.
          Try measure CPU voltages during boot.
          • spintop
            • Feb 2011
            • 132
            I tried 2 different power adapter, the problem is the same.
            I read that the power up sequence is firstly VINT16 & VREG16 from the power source, then from there generate VCC3SW to start up PMH4. This will next generate the whole range of other voltages to startup the booting.
            I measured VCC3SW at a stable 3.3V, I believe this good to start the 2nd stage of voltage generation to power up the laptop.
            Any idea what ISYS and LPMODE signals are used for ? on the last page of schematics
            thanks
            • Tuomo
              • 163
              • Finland
              thanks
              Unfortunately I am not familiar with this model schematic.
              I can try looking it and try figure out how it works.
              Are you sure at there is not nec tokin type capasitors, which cause this kind problem with Toshiba?
              • Tuomo
                • 163
                • Finland
                thanks
                I guess ISYS is coming voltage and LPMODE is Low Power Mode.
                If ISYS voltage go low LPMODE is activated.
                • spintop
                  • Feb 2011
                  • 132
                  thanks !
                  I am running out of idea what is wrong in this laptop - works using battery, but cannot boot or hang on power adapter. already tried out 2 different power adapters.
                  Hope someone has a clue.
                  • spintop
                    • Feb 2011
                    • 132
                    Tuomo, how does nec tokin type capacitors looks like ?
                    • Francisco.s
                      • 686
                      • Spain
                      Have a look to this pdf.
                      • spintop
                        • Feb 2011
                        • 132
                        my laptop is back to life.
                        Found and replaced 2 components (resistor and ceramic cap) that seems to be corroded, and it worked ever since.
                        This is the second time i have this problem on the board.
                        Thanks for your help guys !!!!
                        • spintop
                          • Feb 2011
                          • 132
                          someone asked me for a photo. As I have already assembled the laptop, so i wont be opening again anytime soon. In case if u are having the same thinkpad and same issue booting up, keep a look out for cold or corroded joints near the fan area, which is my case.
                          The difficult thing is spotting them since all the components are super tiny, and i used a magnify glass too. As to why it works on battery, i am not too sure too. Maybe with charger it runs at higher volt of 16V versus 12V on batt, causing the already weaker joints to break. But i am sure given time, the weak joint will break completely and will not boot even with battery.
                          • carlven
                            • Oct 2013
                            • philippines
                            can you add pics or value of capacitor and resistor?
                            • Teban1306
                              [REQUEST] ThinkPad T14 Gen 1 (20S1) - Custom Boot Logo Modification
                              by Teban1306
                              Hello everyone!
                              I hope this is the right section for this request. I'm looking for help to modify the boot logo on my ThinkPad T14 Gen 1.
                              System Information:
                              • Model: Lenovo ThinkPad T14 Gen 1
                              • Machine Type: 20S1S4E600 (Intel i7 variant)
                              • Current BIOS: N2XET42W (1.33) - Latest version
                              • BIOS File: n2xuj25w.exe (12.98 MB) - Downloaded from Lenovo support
                              What I'm trying to achieve:
                              Replace the default "LENOVO" boot logo with a custom image during POST.
                              🔧 What I've tried:
                              09-14-2025, 11:49 AM
                            • mrfree2ita
                              ThinkPad T14s Gen 1 boot loop (instability)
                              by mrfree2ita
                              Hi all, I'm looking at what seems to be a nice puzzle
                              A ThinkPad T14s Gen 1 that stopped working more or less a month after the warranty expired. I tried to boot both Windows 10 and Debian 12 from a USB stick. In the first case, the system just reboots after showing the Windows logo for a few seconds, while I'm able to see the Linux kernel crashing if I boot the second in failsafe mode.
                              Interestingly, some times (unfortunately it's difficult to replicate) I manage to boot into Debian 12 live. Moreover, the kernel doesn't seem to crash always at the same point during...
                              05-25-2024, 03:43 PM
                              Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook X Specification for Upgrade or Repair
                              This specification for the Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon + ThinkPad USB 3.0 Pro Dock boardview and X1 Carbon + ThinkPad USB 3.0 Pro Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                              09-06-2024, 11:40 AM
