LGR41 laptop if i press power switch cannot power on...
  • lorins_core
    BlackSmith
    • Dec 2012
    • 552
    • Philippines
    LGR41 if i press power switch cannot power on...
    i do the following i check
    1. check the power switch ok
    2. check the flex board to mother board ok (flex or data cable i check ok)
    replace a good one Ok...
    i wondered this unit have power because they have a Indicate power in Light
    why not switching on i try to switch direct short the pin no5 and no6 these are the connection to power switch connected to power button...
    would you help me where are the parts malfunction...
    there is the Mother Board
    [/IMG]
  • lorins_core
    BlackSmith
    • Dec 2012
    • 552
    • Philippines
    Re: LGR41 laptop if i press power switch cannot power on...
    Follow Up pls....
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      Check on the VRM capacitors to see if the voltage comes up at all. See if the VRM is getting power at all. Find all voltage regulators on the board, and test them.
      Is it me or does that board look very burnt in the middle?!
      Muh-soggy-knee
      • spidey
        climbs
        • Dec 2012
        • 644
        • Cyprus
        find the schematic first, measure the regulator voltages also check power button for 3v, if everything is ok find the bios file and update it.if still nothing reflow keyb. controller ic. But you need a power supply unit which has adjustble current and also measure current to see whats going on..
        • lorins_core
          BlackSmith
          • Dec 2012
          • 552
          • Philippines
          Sir I Don't have a Schematic Would you like to give me? I tired to find in Google :-(....
          • lorins_core
            BlackSmith
            • Dec 2012
            • 552
            • Philippines
            Sir Would you givve to me where location. yes Already repaired in Other Service Center...
            • spidey
              climbs
              • Dec 2012
              • 644
              • Cyprus
              read the model number on the board and google it, good luck..
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • Powderfanupnorf
                Dell AL440LX power on switch circuit help required
                by Powderfanupnorf
                Hi Everyone. First official post so fingers crossed I conform and also manage to get photos to work.
                So I am requesting some help from anyone who happens to have one of these motherboards to hand and perhaps a multimeter.
                My board has a single row of header pins for all the front panel stuff (have seen others where they are grouped together differently so thats no help) and the two pins for the power on switch had been previously repaired and I am trying to make a better repair. There looks to be pad and trace damage and im happy to relocate the header pin/pins to...
                06-24-2024, 01:24 PM
                09-06-2024, 05:59 AM
              • CdDvdFlash
                LTL Acorn 5210A Trail Camera Power Switch
                by CdDvdFlash
                I have an LTL Acorn 5210A trail camera and the power switch needs replacing, there is only one site I found that sell them but they want 12 pounds each I'm in Australia so thats $24 but I see these switches are in all sorts of devices everywhere so I'm hoping to find a cheaper one, I dont know what the pinout is for these switches but I have taken apart the camera down to just the board and removed the switch and hooked up a battery pack (4x AA batteries) to see what the voltages are at the traces where the switch was. In the picture of just the switch it is currently in the off position, it moves...
                08-06-2023, 09:12 AM
              • shovenose
                Ubiquiti Unifi PoE Switch US-8-150W Power Supply Failure
                by shovenose
                Got this one for free because, well, it no worky.
                A little research and there are tons of complaints all over forums/the internet about premature failure of these switches. The observation everyone makes about these is "they run hot" and failure occurring as soon as 13 months, right out of warranty, of course.
                Upon removal of the cover I found a G0398-15011480A power supply that, when plugged in, was making a constant ticking noise. Multimeter confirmed the PSU was the issue. Output was cycling between 0 and about 20V. With output disconnected it sat around...
                08-11-2021, 01:26 PM
