Toshiba Satellite Pro® A200 ISKAA LA-3481P shutdown where is the problem
  • chrisrer
    • Dec 2012
    • 5
    • greece
    hi everyone from greece this forum is great for fixing problems good job keep trying this.
    i have this laptop and shutdown's, the work i have make is: clean cpu fan , reset bios (remove battery and soldering again),bios update, i put thermal paste cpu,gpu,etc,
    i read for another mainboards to change capacitor nec-tokin but this mainboard haven't this peace near cpu and under from mainboard have 5 capacitors 330mf maybe i change this to fix the problem?
    the hd is formatted disk,this laptop haven't battery, I am concerned when i remove the ram from one slot and put it another the latpop not start's but when i put it again to the other slot work's fine with the problem i mention..i 'll try with another ram to test it and the same problem again with slots.maybe the cpu fault with power managment and i say about capacitor's ... when the pc is power on and works fine about 3 minutes when shutdown i was install program for cpu diagnose an says to me the cpu is burning with 45 celcious temparture...i find it something else the output from dc power is 19V and 4,7 A but laptop needs 19V and 6,4A i must check this but the previous user told me tha laptop works fine ... i don't understand.....
    here is some photo's from mainboard
  • trebo
    • 514
    • Wales, UK
    Re: Toshiba Satellite Pro® A200 ISKAA LA-3481P shutdown where is the problem
    cant get pictures, or is it just me
    • chrisrer
      • Dec 2012
      • 5
      • greece
      pictures it's ok to me.
      • trebo
        • 514
        • Wales, UK
        Hello Chrisrer
        I am getting a Greek site telling me that I need to log in to see pictures, after using translation
        • chrisrer
          • Dec 2012
          • 5
          • greece
          axa....sorry.....maybe the link......i fix it
          • chrisrer
            • Dec 2012
            • 5
            • greece
            [QUOTE=chrisrer;294817]hi everyone from greece this forum is great for fixing problems good job keep trying this.
            • opamp
              • Dec 2012
              • 160
              • united states
              Find the schematic for the motherboard and check voltage and resistance on the ram slot that doesn't work.
              • chrisrer
                • Dec 2012
                • 5
                • greece
                and how about cpu temparture and shutdown? i don't know to read schematic im newbie in electronics
                • dj_ricoh
                  • 2073
                  • uk
                  can you start up in safe mode?
                  • Lilman
                    • Oct 2013
                    • Portugal
                    I have same problem with this PC... can someone please tell me witch caps we have to change?
                    thanks
                    • jtamad44
                      • Apr 2013
                      • 145
                      • israel
                      neck tokin behind the cpu if u have.
                      • Lilman
                        • Oct 2013
                        • Portugal
                        u can see in photos that its not nec tokin...
                        there are around 15 or 16 smaller caps instead nec tokin
                        thats why i need help... dont know which ones replace
                        • spidey
                          climbs
                          • Dec 2012
                          • 644
                          • Cyprus
                          on this mb, vcore mosfets are also overheating , use 0,5mm thermal pad between heatsink.
                          • kikodog
                            • Jul 2012
                            • 5
                            • portugal
                            anyone solve this? same problem here...
                            • pmv
                              • Jun 2013
                              • portugal
                              good, I solved a problem with this card replacing one of the 5 capacitors tantalum processor circuit desoldering all and check the ESR with a checker ESR capacitor.
                              good luck
                              • ok1gr
                                • May 2014
                                • greece
                                chrisrer.. miquel.. did anybody found a solution on this board?
                                • arielcom
                                  • Aug 2014
                                  • Paraguay
                                  test the adaptor connector someone the positive in the middle not adjust properly. adjust it whit a needle and test.
                                  Sorry for bad english.
                                  • Ramee
                                    • Jul 2014
                                    • 218
                                    • Israel
                                    good luck
                                    Hi
                                    What kind of SMD ESR tester do you got, can you post the picture or link where to buy?
                                    • highpulse
                                      i hate HP
                                      • May 2013
                                      • 1489
                                      • portugal
                                      Well i got the same laptop here , toshiba a200 , with the motherboard la-3481p , it was dusty inside , and my client complained it was shutting down inside , i was hopefully thinking could be the NEC , but th is machines is the one with the small capacitors , i know that some people here have replace some caps and the machine stayed ok , so now im a bit stuck , since i don't have a ESR meter to test all well tested to be sure with would be the fault here .
                                      or anyone have a suggestion for this issue?
                                      cheers
                                      • highpulse
                                        i hate HP
                                        • May 2013
                                        • 1489
                                        • portugal
                                        alltough works well on battery , just like the bloody nec problem , meanwhile i replaced the 6 tantalum capactiros , as also replaced the vcores fet for news ones , since they were allready with a arsh color .
                                        lets see later on the final test
                                          Toshiba Satellite Pro A200-1MV Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro A200-1MV can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A200-1MV boardview and A200-1MV schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                                          09-06-2024, 05:27 AM
                                          Toshiba Satellite Pro A200-16B Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro A200-16B can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A200-16B boardview and A200-16B schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                                          Toshiba Satellite Pro A200-1H4 Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro A200-1H4 can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A200-1H4 boardview and A200-1H4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                                          Toshiba Satellite Pro A200-1KQ Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro A200-1KQ can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A200-1KQ boardview and A200-1KQ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                                          Toshiba Satellite Pro A200-1K4 Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro A200-1K4 can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A200-1K4 boardview and A200-1K4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
