toshiba c660
    toshiba c660
    hi
    this laptop works only from AC , but it charges normal
    i tried new adapter, battery and bios update
    i changed the ic isl6251 with no succes
    new battery will charge but will not boot the laptop
    even if it is on AC and i remive the AC it will shutts off soon.
    the board is :la-6842p
    Re: toshiba c660
    When you remove the battery and plug in the charger only the laptop works?
      Re: toshiba c660
      yes it works normally
        Re: toshiba c660
        Dont you have a G5209S31U batt controller?
        Before that test the PQ17 and PQ19 and also PQ214 (regular transistor 100mA 50V DTC115EUA).
          Re: toshiba c660
          yes isl6251= G5209S31U, i already changed it with no succes, also on pq17 the volt from battery without ac is 11.99 on pins 1-3 and 11.7v on pin 4 on 5678 the volt is 11.99 also
          on pq 19 the volts on 1-2-3-4 is zero
            Re: toshiba c660
            I am in the middle of something right now. Please take a look at the schematics, you have a charger scheme on page 37. I will try to help you as much as i can!
              Re: toshiba c660
              PQ214 is open from all sides
              is there a way to change it from another board.
              and thanks for the schematic
                Re: toshiba c660
                Here is the datasheet for PQ214
                http://pdf1.alldatasheet.com/datashe...DTC115EUA.html
                I don't know if you can replace this digital tranzistor with a regular one. I don't think so.
                Try to find something similar in your nearest well equiped electronics component store.
                Ask for 100mA / 50V NPN epitaxial planar silicon digital transistor.
                Please somebody correct me if i am wrong.
                  Re: toshiba c660
                  i found one from another board and still have the same problem. anyway thanks for your help. and i will not take from you more time.
                  i will contact with you tomorrow... if you have time
                  sorry for bad english
                    Re: toshiba c660
                    No problem. Did you compare multimeter results between those two tranz?
                      Re: toshiba c660
                      yes it is the same
                        Re: toshiba c660
                        Try to examine tranzistors in the cirlce, PQ13 and PQ10. Or try to replace batrery controller PJP2 and PU4.
                          Re: toshiba c660
                          thank you very much for your time, i already sent back the laptop to the customer with the problem still.
                          thanks very much
                            Re: toshiba c660
                            No problem. To bad you didn't manage to resolve it, but better that you quit on it, then to lose 5-6 hours to diagnose the error and still not be able to fix it.
                            I would be glad to know when to quit. That's because im a stubborn jackass
                              Re: toshiba c660
                              you seem to be nice guy, from where u are??
                                Re: toshiba c660
                                I am stil young and not aware of the world evilness
                                Im form Croatia.
                                have to update my profile
