Laptop adapter LED flashing
  • hercooles
    • Sep 2011
    • 7
    Hello!
    I got a Shin 20V ~4.5A. Problem is on load laptop adapter's LED starts flashing. Without load 20V is measurable.
    I tested it with 19V light bulb, laptop is working wine with another charger, so 100% it is a charger problem.
    I already opened the laptop adapters case. Any ideas where should I look for the problem?
    Re: Laptop adapter LED flashing
    Check the startup cap - primary side around 10uF to 47uF.
    • hercooles
      • Sep 2011
      • 7
      Thanks for your reply. Startup caps looks OK, but I just noticed that the 450V/100uF worned out. Can I use 400 or 420V /100-150uF instead of 450V?
        It depends on if this power supply has PFC Voltage booster or not since typical power supply with PFC will be running B+ at around 400VDC. Also if the Power supply is made for 230~270VAC and without PFC, the voltage on the cap can still get very high, @270V DC on cap will be a shigh as 382V (1.414 x line voltage).
          The startup cap can fail with no bulging or obvious visible signs.
          Are you in a country with 115V AC or 230V AC?
          • hercooles
            • Sep 2011
            • 7
            Local electricity "is" 230 AC. I will check the startup caps too, but this 450V is definetly bad. In 19V 4.74A adapters i found 400V/120-150uF caps. This one is 20V/4.5A.
            Thanks for your replies Guys!
              The cap voltage is depended on the circuits design, the topology, and the requirement of the end user such as operating Voltage range.
              • aaronmarsh632
                • Nov 2010
                • 20
                I have seen a few laptops with this fault description, I have one at the moment which is doing this exact thing. Where can the 'startup cap' be found usually and does it just look like a standard cylinder shape? can anyone offer any example images of a laptop motherboard displaying this component please?
                thanks
