Acer aspire 5920 blink led light on Charger
  • primoz1
    • Oct 2010
    • 270
    • Italy-Slovenia
    I got this laptop, is complete dead, no react on power button, no react on another 100% OK battery and 100% OK power supply.
    When I plug power connector on power supply start blinked green light, any Idea what can be problem ?
    Thankyou.
  • infringer
    Badcaps Member
    • Sep 2009
    • 244
    • United Frickin States
    Re: Acer aspire 5920 blink led light on Charger
    Is your item under warranty? If yes then please do not mess with anything send it in for repair.
    If not you can try the following things...
    Try this unplug the unit then remove the battery hold the power button down for 30 seconds then just plug the unit in without the battery and hit the power button. If this does not work remove the power once again remove Ram Door Remove sticks of ram and put the top stick on the bottom and the bottom on the top. If this does not work then try to replace the CR2302 small silver battery on the motherboard but I will warn you this can be a rather tedious task not for the faint of heart. Next you could try to purchase and install a new processor and if this does not work then your motherboard may need replacement or repair. You could try disabling things 1 at a time or unplugging anything usb related that may cause a conflict also remove anything from internal and external card slots or ports one at a time to see if there is something faulty causing it not to boot.
    Try to also plug in an external monitor to make sure you are not getting any picture externally to another monitor.
    With the information you have provided there is so much it could be as you could see from this post.
    Please note: I am not responsible for any harm caused to you anything discussed is just discussion. Before you try anything discussed be sure that you have the appropriate knowledge and safety gear for the job. Like with anything education and safety are first! Do not try anything @ home without it.
    • primoz1
      • Oct 2010
      • 270
      • Italy-Slovenia
      Hi. I try reset board before I come here for advice, but this board is dead, it must be one or few shorted elements on board, but the question is, which ?
      but anyway thanks for this message maybe will help someone else.
      • tragicem
        • Feb 2012
        • Philippines
        a shorted caps on VRM area near the processor.... measure the resitance for shorted components..very common on that model...
        • primoz1
          • Oct 2010
          • 270
          • Italy-Slovenia
          Hi. I measure this 5 caps and some has readings no both sides, measured on board, without desoldering.
          Is that bad cap who has reading OHM on both sides ?
          • tragicem
            • Feb 2012
            • Philippines
            Check capacitors PC112 and PC118 near the memory slots,,, One of them or both them may be shorted
            or Sometimes PC90 and PC96 is shorted..
            • primoz1
              • Oct 2010
              • 270
              • Italy-Slovenia
              Im found bad spot, there is 3 or 4 burned elements, I think is capacitors, EV@4.7U/25V_8
              I remove this elements and nov laptop is on, but is in LOOP restarting, I must find propper caps and replace them, maybe then will work OK I hope, finger crossed
              If any idea how fix on other way, go ahed please.
              Thankyou.
              • primoz1
                • Oct 2010
                • 270
                • Italy-Slovenia
                Hi. Now I buy another board for this laptop, this is in LOOP stage, but after 5-6 reboot's show picture on external monitor, on primary no nothing.
                I susspect 3 things
                1 bad bios chip
                2 bad north or south bridge chip
                3 bad MXM II graphic card
                Any idea ?
                update I can even go on bios settings. Is possible with bios flashing fix this problem ?
                Thankyou
                • senndogg
                  • Dec 2011
                  • 383
                  • Albania
                  hi guys!
                  i wanted to say thank you to Tragicom and to this amazing forum!
                  just repaired a aspire 5920g by simply "deleting" PC112. it works! woot woot!
                  proud member of badcaps.net!
                  • primoz1
                    • Oct 2010
                    • 270
                    • Italy-Slovenia
                    Hi. I do not understand what you mean for deleting PC112 ?
                    • senndogg
                      • Dec 2011
                      • 383
                      • Albania
                      hi primoz.
                      i totally destroyed and removed capacitor PC112. maybe this is not the best way to fix things but i think PC118 will do its job.
                      i saw your case and that is a little different. in my 5920 i had not any sign of burned components. have you looked for another mobo?
                      • primoz1
                        • Oct 2010
                        • 270
                        • Italy-Slovenia
                        Hi. I got luck I got working mboard for 30 euro's, just replace and dump this in to trash
                        Thank you for info any way.
                        • jamiedean83
                          • May 2013
                          • England
                          Hi guys, have you noticed any other issues with this laptop - i.e. Not powering on but DC power LED illuminates when charger is connected (The ones around the power button on the PCB). I have checked the caps which are mentioned earlier but all appear fine and no shorts occuring. I've checked the 5v and 3.3v lines and they appear to be working also. Power button switch has a 3.3v supply which appears to drag HIGH when button is press anything else to check ? As boards appear to be cheap and probably not worth repairing.
                          • primoz1
                            • Oct 2010
                            • 270
                            • Italy-Slovenia
                            I got cheap board but I got luck, If you know read schematics here is two.
                            First check if Processor seat OK. re-seat proc
                            • eniac22
                              • 124
                              • Greece
                              I have the same problem but was made a mistake and tested with universal charger and then the PU9 burnout.
                              I have change it (PU9) with new and also have remove and test the PC112, PC118, PC90, PC74 and PC24.
                              The capacitor have the correct capacitance but can be sorted and have the correct capacitance ?
                              • artois7
                                • Mar 2011
                                • 159
                                https://www.badcaps.net/forum/showthread.php?t=14602
                                  Acer Aspire A515-57-5920 Notebook 5 Specification for Upgrade or Repair
                                  This specification for the Acer Aspire A515-57-5920 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A515-57-5920 boardview and A515-57-5920 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                  09-07-2024, 07:20 AM
                                  ACER Aspire Aspire X3910 Aspire E5700 Specification for Upgrade or Repair
                                  This specification for the ACER Aspire Aspire X3910 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire X3910 boardview and Aspire Aspire X3910 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                  09-12-2024, 03:36 PM
                                  ACER Aspire Aspire XC-886 Aspire XC i5-9400 Specification for Upgrade or Repair
                                  This specification for the ACER Aspire Aspire XC-886 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire XC-886 boardview and Aspire Aspire XC-886 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                  09-12-2024, 03:30 PM
                                  ACER Aspire Aspire XC-330 Aspire XC A4-9120e Specification for Upgrade or Repair
                                  This specification for the ACER Aspire Aspire XC-330 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire XC-330 boardview and Aspire Aspire XC-330 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                  ACER Aspire Aspire X1301 Aspire 620 Specification for Upgrade or Repair
                                  This specification for the ACER Aspire Aspire X1301 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire X1301 boardview and Aspire Aspire X1301 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                  09-12-2024, 03:28 PM
