How Much is Toshiba Satellite A215-s5837 w/cracked screen worth?
  • Paul678
    • Nov 2011
    • 402
    The owner said she had it for 4 years or so.
    It supposedly boots up ok, but you have to
    minimized the windows to avoid the cracks, so
    you can see what you are doing. She said
    she didn't try an external display, but I suspect
    it should work fine.
    Replacement screens on Ebay were about
    $90 including $10 for shipping, so about $100
    total, which is about what they go for used,
    in working condition.
    Anyone chime in?
  • retiredcaps
    • Apr 2010
    • 9271
    Re: How Much is Toshiba Satellite A215-s5837 w/cracked screen worth?
    Buying used laptops, in my opinion, is usually never a good deal.
    1) It looks like this laptop may be 4 years old so the battery is near end of life.
    2) You don't know what other abuse the laptop has been through. Was it dropped, liquid spills, taken apart, etc.
    3) Some laptops run hot (due to inadequate cooling or dust) and that shortens the life of the components.
    4) Some repairs require that you have some sort of electronic unlock code or reprogramming code after changing major components.
    Now having said the above, both my laptops at home were purchased used, but I bought both for 10% of their original value (or 90% off) and both were in perfect working condition.
    --- begin sig file ---
    --- end sig file ---
    • Paul678
      • Nov 2011
      • 402
      She said yes to $30, but I'm thinking
      of offering $20, after reading how expensive the
      replacement screens are.
      • jetadm123
        • 2169
        You've been looking at the prices for new screens. That screen is probably used on multiple Toshiba models. If you do get the laptop at the price you offer, then open up the screen enclosure and pull out the cracked screen. On the back of it you will find out the manufacturer and part number for that screen. Look for a screen under that part number. If you don't mind a used screen, then you might be able to score one at a much lower cost. If you can't get a screen at a reasonable price, then you should be able to make a few $$ if you part the thing out and sell the parts individually.
        • Scenic
          o.O
          • Sep 2007
          • 2642
          http://www.ebay.com/dsc/i.html?_nkw=...LH_TitleDesc=1
          Original screen is a 15.4" 1280x800 LG-Philips LP154WX5 (TL) (A1)
          (the stuff in brackets defines if it's glossy etc. and the revision. Not too important)
          As long as the resolution matches and it has the 30pin LVDS connector in more or less the same spot (which most of them do), it'll work. Matte or glossy doesn't matter.
          From one of the auctions:
          Compatible laptop models:
          Toshiba: A205, A215, L305, L305D, F45,A135, M45, A105, A100, A200, L45, A305
          IBM: 3000 N200, 3000 N100,
          Compaq: 6710b, 6715b, 6715s, 6720s, 6730b 6735b, 8510b, 8510w, CQ50
          HP: DV5-1000 series, G50 series
          Compatible LCD part numbers:
          LG-Philips LP154WX4, Samsung LTN154AT01, Samsung LTN154X3-L05, Sharp LQ154K1LB1C, Sharp LQ154K1LA1C, LG-Philips LP154W01, AU Optronics B154EW08, LG-Philips LP154WX4 TL E2, Samsung LTN154X3-L06, LG-Philips LP154WX4 TL C8, Samsung LTN154AT10, Samsung LTN154AT07, LG-Philips LP154WX5 TL A2
          edit: cheapest I've found: http://cgi.ebay.com/250958909868
          • Paul678
            • Nov 2011
            • 402
            Wow, thanks.
            $31 is a hell of a lot better.
            But you're absolutely positive this one is compatible?
            It looks like it:
            http://www.247laptoplcd.com/servlet/...top-lcd/detail
            As long as it has the following:
            Display Size
            15.4" widescreen
            Display Type*
            WXGA with TruBrite® Technology
            Display Resolution
            Supports 720p content, 1280x800
            Right? I'm planning to pick the laptop up tomorrow for $20......
            • Scenic
              o.O
              • Sep 2007
              • 2642
              It's a fairly standard LCD (for laptops at least). 15.4", 1280x800, single CCFL for backlight. The only other super-common one is 15.6" 1366x768, which are mostly LED backlit (newer laptops ; incompatible due to size, resolution and LED backlight)
              "TruBrite" is usually just a marketing BS term for those nasty glossy screens.
              If you have the laptop, the easiest to do would be to open the top part up and look what panel model was originally in there, then strip anything in brackets after the model number (like this (TL) (A1) stuff) and search for it on ebay.
              Even if the auctions have really ridiculous prices, take a look regardless. Most of them conveniently list compatible LCD models which you can search for (and usually get one heck of a lot cheaper.. as you can see in my previous post lol)
              • Paul678
                • Nov 2011
                • 402
                So you're 100% sure the LTN154X3-L03 will work?
                And what's wrong with glossy screens? They seem fine to me,
                and in fact, the blacks appear darker.....
                Thanks for your help.....
                • Paul678
                  • Nov 2011
                  • 402
                  Also, isn't it dangerous to be shipping these ultra fragile
                  LCD screens? unless they pack them REALLY well.....
                  Perhaps I'll get insurance....
                  • Scenic
                    o.O
                    • Sep 2007
                    • 2642
                    Like i said.. if you get the laptop tomorrow, look what panel model is in there from the factory. A lot of them are interchangeable (same specs, just from a different manufacturer).
                    Unless the seller is dumb enough to ship it in a normal padded envelope (which happened to me once.. cracked panel of course), it should be fine in a small packet.
                    Being bumped around isn't too bad, but any form of bending = insta-death
                    • Paul678
                      • Nov 2011
                      • 402
                      Ok, thanks for the info.
                      But Christ, now the lady calls me and tells me she cannot
                      find the charger! They are $8.35 on Ebay.
                      Guess I'll offer her like $15 tomorrow, and hope she still bites....
                      • Scenic
                        o.O
                        • Sep 2007
                        • 2642
                        For the specs this thing has, that's pretty much a ripoff for $30 already.. now talking her down to $15? I'm outta here..
                        Actually just wanted to post some infos about the LTN154X3-L03 as i happened to find one in my pile of LCDs, but yeah.. not this way..
                        • Paul678
                          • Nov 2011
                          • 402
                          Well, that was my original question:
                          How much do you think it's worth? What do you think is a fair price?
                          I've never had a laptop, so I have no idea what they are worth....especially
                          broken....
                            Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook Specification for Upgrade or Repair
                            This specification for the Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A40-C-1P5 boardview and Satellite Pro A40-C-1P5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                            09-06-2024, 06:10 AM
                            Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook Specification for Upgrade or Repair
                            This specification for the Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-C-17C boardview and Satellite Pro R50-C-17C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                            09-06-2024, 05:40 AM
                            09-06-2024, 05:27 AM
                            Toshiba Satellite Pro Satellite Pro R50-EC-11J Notebook Specification for Upgrade or Repair
                            This specification for the Toshiba Satellite Pro Satellite Pro R50-EC-11J Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-EC-11J boardview and Satellite Pro R50-EC-11J schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                            09-06-2024, 08:10 PM
