DELL Vostro 1400
  • scobie_21
    • Jul 2011
    • 144
    DELL Vostro 1400
    I have a Dell 1400 that wont power up Im getting a short on pc78 an pq18,and more caps under the processor and when I remove process some are still shorted other are not. Im not experienced on Mb repair.
    Any pointers would be great
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: DELL Vostro 1400
    With issues like that, including a picture of the affected area is usually a good idea so that we know what you are looking at.
    What makes you believe the problem is in that area and what are the symptoms of the laptop?
    • scobie_21
      • Jul 2011
      • 144
      Thanks for the reply. This MB I was told had a bad DC jack upon inspection the jack was found to be OK with 19v to the motherboard.
      The board will not power up adn I was just measuring various areas and found quite a few caps short around the processor, when the cpu's removed some are not short anymore but some are. I was hoping somebody had seen something like this before and give me some things to check.
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        Right, but it's still possible that the charging/power circuit can be faulty.
        Those caps likely filter power to the CPU and/or northbridge. They are essentially in parallel with the CPU and northbridge, and CPUs usually have a very low resistance, thus explaining why some of the "shorted" caps were no longer shorted when the CPU was removed. The other "shorted" caps could be in parallel with something else, or there may indeed be one that is faulty, causing all of them to appear as shorted.
        Again, it's hard to give advice without knowing what we're looking at. This could be a unique problem or it could also be a standard problem.
        • severach
          • Aug 2007
          • 1055
          Put your DMM on diode, install the CPU, and test the caps that appeared shorted with the CPU in. If your DMM shows 0.000 then it is not suitable for testing motherboard shorts. If it shows 0.008 or above then it can tell the difference between an actual short and something that is almost a short. North bridges can test at 0.025-0.060.
          sig files are for morons
          • scobie_21
            • Jul 2011
            • 144
            I will do that, excellent info thank you .
            • ravi_1617
              YY Solutions
              • Jan 2012
              • 347
              • India
              Hi!
              Dell vostro 1400 turning on and off 6.5 seconds .off for 1 sec on than again on.
              on adapter power only.
              on batter turns on and off not on it self.
              battery charging fine.
              all coils have power according to schematic.
              cpu is also heating after long run .
              fan not spinning any time
              • playit
                laptop 19v short circuit dell vostro 1400 motherboard ,need help in repair .
                by playit
                the comon problem they say , the charger will shut off power once plugged to laptop , i dont have battery, its long gone ago , i use it for backup with adapter and vga port to external monitor(yes no screen lcd) in case my desktop needs fix . one thing for sure i could say the clr resistor - r010 beeps ,short at both sides , the checked all the coils , the 3 coils together gives all of them beeps short along with their respective capacitors . i dont have voltage ampere injection dc machine as in videos i have seen they see where its getting hot and they remove the short and replace components...
                02-25-2025, 08:15 AM
                DELL Vostro 3671 Vostro 3600 i5-9400 Specification for Upgrade or Repair
                This specification for the DELL Vostro 3671 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3671 boardview and Vostro 3671 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...
                09-12-2024, 03:44 PM
                DELL Vostro 3471 Vostro 3400 i3-9100 Specification for Upgrade or Repair
                This specification for the DELL Vostro 3471 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3471 boardview and Vostro 3471 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...
                DELL Vostro 3470 Vostro 3400 i3-8100 Specification for Upgrade or Repair
                This specification for the DELL Vostro 3470 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3470 boardview and Vostro 3470 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...
