acer nitro 5 not working on battery mode
  • yaso143
    • May 2021
    • 49
    • philippines
    hello i have a issue in a acer nitro 5 laptop is turning on using the charger charging light turns on and when you remove the charger the laptop turns off i also replace it with a known good battery but still same issue
    do you have any ideas what part of the board i should look
  • mon2
    • 14664
    Re: acer nitro 5 not working on battery mode
    Hey. Recently returned from Davao. Always wanted to go zip lining - got a chance to do this at Eden Park. Wife was not happy.
    Review the sticky above by @Piernov on chargers. Respectively inspect the first 2 dcin mosfets that follow the power adapter connector. Often these mosfets will become defective. Remove all power. Meter in resistance mode. Check the resistance across :
    Source & drain
    Source & gate
    Gate & drain
    A low resistance means the mosfet is leaky and needs to be replaced.
    • yaso143
      • May 2021
      • 49
      • philippines
      Yes it's the first mosfet s-d 0hms s-g 1.2ohm d-g 1.2ohms
      Btw the mosfet is a Nikos pk5n2ea what mosfet can i use for substitute I can't find any sources online
      • mon2
        • 14664
        1) must be N-channel type
        2) source drain voltage should be 30v or higher
        3) physically the same size as the original
        4) be able to support high current so look for a low resistance on Rds value
        Donor boards are an option of alternative parts.
        Here is someone selling out of Manila but is expensive:
        https://www.lazada.com.ph/products/5...&pdpBucketId=8
        • yaso143
          • May 2021
          • 49
          • philippines
          Thnks really appreciate the help
          • yaso143
            • May 2021
            • 49
            • philippines
            hello just an update on this the unit is now working on battery mode but when i plug the charger both blue light and amber light blinks and the laptops shows it charger then the charge indicator disappear in windows
            the amber light and blue light blinks i have replaced the high side and lowside mosfet and the bq chip still same issue do you have ideas or how would you approach this kind off issue
            • mon2
              • 14664
              Check the usual 2*Dcin mosfets that are between the power adapter and the charger IC. Check the voltage to ground of each pin of these mosfets.
              source (1-2-3)
              gate (4)
              drain (5-6-7-8)
              post each measurement.
              • yaso143
                • May 2021
                • 49
                • philippines
                1st mosfet without battery + dc in (Source 20v Gate 26v Drain 20v ) 2nd mosfet without battery +dc in(source 20v gate 26v drain 20v)
                1s mosfet with battery +dc in (source 0.7v drain 20v gate 0.7v )(2nd mosfet with batter +dc in (source 0.7v drain 15.94v gate 0.9v) both amber light ang blue light blinks but the unit turns on and works but its not charging the laptop
