HP Envy 13" X360. Not getting AC power.
  • Indycanard
    • Oct 2011
    • 13
    I've been troubleshooting a failed laptop for a few months now. It's a personal project and I thought it would be easy. Not so much I'm figuring out. The motherboard is a DAYODPMBAFO, I found a schematic for QUANTA Y0DP REV 1A DAY0DPMBAF0 (HP ENVY X360 13-Y023CL), although my board is Rev F.
    Symtoms:
    Neither A/C power or battery charge light turn on when plugged in. Laptop does boot into windows with battery power, however the battery icon shows no charging or presence of the ac adapter.
    Both input mosfets appear good. I can measure the 19V past both mosfets. In checking the bq24780S Charge IC, plugged in (without and with the battery connected), I get the following voltages at the bq24780S:
    See attached for measurements and schematic.
    I have replaced the bq24780S charge IC chip.
    Additionally, when I have the battery and Adapter both connected, the PQ21 mosfet gets extremely hot. I replaced hoping that would resolve my issue, however the new mosfet also gets hot. I'm unsure where to look now. I see I have fluctuating voltages, and the ACOK signal is going from 0 to 2.4V with the same frequency as the other measured voltages are swinging.
    Bad input mosfet? It looks like they are working well, except for the gate voltages are fluctuating with the ACOK signal.
  • Techtiger
    • Oct 2014
    • 1601
    • france
    Re: HP Envy 13" X360. Not getting AC power.
    are you using the original adapter? upload the schematic section. BQ REGN is connected to ACOK with an R1 R2 divider. It should be 0-3.3V max on your platform; 1.84V is less (with the adapter only). Trace it back to two components to test with a multimeter in diode mode without power
    • Techtiger
      • Oct 2014
      • 1601
      • france
      There are multiple faults with the measurements. For PQ21, the gate threshold value is high +21V, which will pass to the battery terminals (4, 5, 6). What supply are you getting for the drain and source? The battery is not detected by the Master and Slave. It may be a bad battery. What supply do you get for PQ4, PQ5, S, D, and G
      • Indycanard
        • Oct 2011
        • 13
        All these measurements are with adapter plugged in with battery connected.
        PQ21
        D 11.5-15
        S 11.5-13V
        G 12.5 (not sure how I measured 21V before). Seems stable at 12.5V now
        PQ4
        D 11-15V
        S 11-15V
        G 11-15V
        PQ5
        D 11.5-15
        S 11.5-15
        G 11.3-21V
        REGN6V (pin 24 of Charger IC) = 6.05V
        ACIN (ACOK - Pin 5 of Charge IC) = 0V to 3V (alternating)
        Note: charger is original (and I have a second identical, same issue). Battery will boot laptop, and is holding a charge. I have a second battery, same result.
        • Techtiger
          • Oct 2014
          • 1601
          • france
          test PQ4 and PQ5 for S D G supply without a battery update? Afterward test PQ21 for S D G supply without AC adapter update ? for ACIN test on PR106 and PR107 using the multimeter's resistance mode for update?. Is the voltage alternating on the input side of PR106?
          • Indycanard
            • Oct 2011
            • 13
            Without Battery:
            PQ4
            D 19.49V
            S 19.54V
            G 17.88V
            PQ5
            D 19.49V
            S 19.42V
            G 21.77V
            PQ21
            D 19.92V
            S 19.42V
            G 19.81V
            ACIN 1.83V (steady) (common to PR107 and PR108)
            PR106 => This revision does not have a PR106 populated. I wish I has a schematic for this Rev F. However PR106 on previous Revs connected to PU12, pin 3. Measuring that pin finds 0 volts. I'm thinking you were asking about PR107 and PR108 (resistors connected to ACOK).
            PR107 resistance:84K
            PR108 resistance: 85K
            Without Adapter
            PQ21
            D 11.22V
            S 11.21V
            G 12.55V
            REGN6V (pin 24 of Charger IC) is still = 6.05V
            ACIN (ACOK) = 0V (steady)(common to PR107 and PR108)
            • Indycanard
              • Oct 2011
              • 13
              One further data point. During my initial evaluation, I found PQ21 becoming very hot. I desoldered it and removed it to replace it. While PQ21 was removed, I plugged in to AC and the power/charge light illuminated. I did not try to boot the board, but I suspect it would have.
              Not positive if it was white (AC Power) or orange (Charging), however with PQ21 reinstalled, the light was dark.
              • Techtiger
                • Oct 2014
                • 1601
                • france
                Regarding the measurements for PQ21, when only the adapter is connected, the power supply should cease at the drain. However, in your case, the power supply is crossing over to the battery when the battery is connected. At this moment, the two power supplies will conflict with each other, which is why PQ21 is experiencing a leak again (hot)
                • Techtiger
                  • Oct 2014
                  • 1601
                  • france
                  As for the details you have uploaded, without PQ21, the (Mob) has to boot the SIO, and the BQ Master & Slave have to identify whether an adapter is present (AC) and the power/charge light is illuminated. After that, remove PQ21 and power the Mob without the battery. Update?
                  • Indycanard
                    • Oct 2011
                    • 13
                    Are you recommending I again remove PQ21 and try to power up the mob? Any idea why "the power supply is crossing over to the battery when the battery is connected."?
                    • Techtiger
                      • Oct 2014
                      • 1601
                      • france
                      Yes, you can power the Mob without the PQ21 without the battery. There may be a faulty component in the BQBATDRV line, or you may have to flash the BIOS, etc
                      • Indycanard
                        • Oct 2011
                        • 13
                        I removed PQ21. As suspected, the laptop powered on and booted to windows.
                        I measured PQ21 pads (with PQ21 removed)
                        PQ21
                        D ~19.5V
                        S 0 V
                        G 0 V
                        I then plugged in battery (still without PQ21 reinstalled):
                        PQ21
                        D ~19.5V (AC voltage)
                        S ~12.21V (Batt Voltage)
                        G ~12.21V
                        I was surprised to see the Gate at 12.21V. It isn't coming from BQBATDRV. According to the schematic, PC248 (0.01U/50V) capacitor connects the S to G. Could PC248 be my problem? Is it shorted out?
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          What was the original part number for PQ21? The replacement fet is same or any other mosfet? If not same, mention the replacement part number.
                          • Indycanard
                            • Oct 2011
                            • 13
                            Schematic identifies PQ21 as FDMS7698
                            Markings on original removed MOSFET is 6370 GV5S1C
                            I replaced removed original MOSFET with a FDMS7698.
                            Currently still removed as I consider replacing PC248 if it would resolve my issue.
                            • Indycanard
                              • Oct 2011
                              • 13
                              After letting this repair sit for quite a while, I thought I would take one last try to repair this MB. I finally found the bad capacitor! It was on the 5V usb circuit (current limiting IC circuit) for the USB-C port. I removed that cap, and now the laptop is charging and otherwise back working. I haven't replaced the cap, just removed it and left it off.
                              • mon2
                                • Dec 2019
                                • 13835
                                This is one capacitor that should be present and serves as an in-rush current limiter for the USB's VBUS power rail. From the USB spec, this capacitor should be 120uf or higher. Suggest the voltage rating of this cap to be 16v or higher.
                                • Indycanard
                                  • Oct 2011
                                  • 13
                                  Thank you for the quick response. I'm going to replace this capacitor then, and need a hand deciphering the value. The schematic shows "220U/6.3V/ESR35_3528". I got it all figured out except the ESR value. would that be 35 mOhms? I can't find any 35 ohm at Mouser. If mOhm, then this capacitor at Mouser: T55B227M6R3C0035. Does that seem right?Click image for larger version
                                  • mon2
                                    • Dec 2019
                                    • 13835
                                    Correct - the table below the text confirms the mOhms. The lower this value, the better the quality of the cap.
                                      HP ENVY x360 ENVY x360 - 15-dr1011na Hybrid (2-in-1) 15 Specification for Upgrade or Repair
                                      This specification for the HP ENVY x360 ENVY x360 - 15-dr1011na Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 - 15-dr1011na boardview and ENVY x360 - 15-dr1011na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                      09-06-2024, 12:18 PM
                                      HP ENVY x360 ENVY x360 Convert15-dr1013na 7PW22EA Hybrid (2-in-1) Specification for Upgrade or Repair
                                      This specification for the HP ENVY x360 ENVY x360 Convert15-dr1013na 7PW22EA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 Convert15-dr1013na 7PW22EA boardview and ENVY x360 Convert15-dr1013na 7PW22EA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                      09-06-2024, 11:17 AM
                                      HP ENVY x360 ENVY x360 Convert 15-ds0502saBundle 6TD07EA Hybrid (2-in-1) Specification for Upgrade or Repair
                                      This specification for the HP ENVY x360 ENVY x360 Convert 15-ds0502saBundle 6TD07EA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 Convert 15-ds0502saBundle 6TD07EA boardview and ENVY x360 Convert 15-ds0502saBundle 6TD07EA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                      HP ENVY x360 ENVY x360 15-cn0755nd Notebook Specification for Upgrade or Repair
                                      This specification for the HP ENVY x360 ENVY x360 15-cn0755nd Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 15-cn0755nd boardview and ENVY x360 15-cn0755nd schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                      09-06-2024, 06:51 AM
                                      HP ENVY x360 ENVY x360 - 15-cn0008ng Hybrid (2-in-1) Specification for Upgrade or Repair
                                      This specification for the HP ENVY x360 ENVY x360 - 15-cn0008ng Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 - 15-cn0008ng boardview and ENVY x360 - 15-cn0008ng schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                      09-06-2024, 06:50 AM
