Toshiba No power bad charger ic?
  • kalilinux25
    • Mar 2018
    • 2085
    • ZAMBOANGA SIBUGAY
    LAPTOP: toshiba c55-c1924
    serialnumber : not visable anymore
    MOTHERBOARD: DABLQMB16B0 REV B
    ISSUE No power
    no power consumption on dc supply
    check cahrger ic
    ISL88731
    1-NC
    2-ACIN
    3-VREF
    4-ICOMP
    5-NC
    6-VCOMP
    7-NC
    8-ICM
    9-SDA
    10-SCL
    11-VDDSMB
    12-GND
    13-ACOK
    14-NC
    15-VFB
    16-NC
    17-CSON
    18-CSOP
    19-PGND
    20-LGATE
    21-VDDP
    22-DCIN
    23-PHASE
    24-UGATE
    25-BOOT
    26-VCC
    27-CSSN
    28-CSSP
  • Techtiger
    • Oct 2014
    • 1601
    • france
    Re: Toshiba No power bad charger ic?
    ISSUE No power
    check cahrger ic
    ISL88731
    1-NC
    2-ACIN
    3-VREF
    4-ICOMP
    5-NC
    6-VCOMP
    7-NC
    8-ICM
    9-SDA
    10-SCL
    11-VDDSMB
    12-GND
    13-ACOK
    14-NC
    15-VFB
    16-NC
    17-CSON
    18-CSOP
    19-PGND
    20-LGATE
    21-VDDP
    22-DCIN
    23-PHASE
    24-UGATE
    25-BOOT
    26-VCC
    27-CSSN
    28-CSSP
    You have not provided the ISL88731 pin voltages
    • kalilinux25
      • Mar 2018
      • 2085
      • ZAMBOANGA SIBUGAY
      1-NC -
      2-ACIN – 4.0V
      3-VREF – 3.1V
      4-ICOMP -0V
      5-NC -
      6-VCOMP – 0V
      7-NC -
      8-ICM – 0V
      9-SDA -0V
      10-SCL- 0V
      11-VDDSMB- 0V
      12-GND -
      13-ACOK- 0V
      14-NC- 0V
      15-VFB- 0V
      16-NC- 0V
      17-CSON – 0V
      18-CSOP – 0V
      19-PGND – 0V
      20-LGATE – 0V
      21-VDDP – 5V
      22-DCIN – 19V
      23-PHASE -1.5V
      24-UGATE -1.7V
      25-BOOT – 6.0V
      26-VCC – 5.0V
      27-CSSN -19.8V
      28-CSSP – 19.8V no 3v and 5v on coils
      RT6575AGQW
      CS2- 0V
      FB1-0V
      LDO3-0V
      FB2-0V
      CS2-0V
      EN2-0V
      PGOOD-0V
      PHASE2-0V
      BOOT2-1.4V
      UGATE2-0V
      LGATE2-0V
      VIN-5.0V
      LD05-0V
      BYP1-0V
      LGATE1-0V
      UGATE1—0V
      BOOT1-0V
      PHASE1-0V
      VCLK-0V
      EN1-0V "check all pins no shorted to gnd also" no low resistance
      • Techtiger
        • Oct 2014
        • 1601
        • france
        For ISL88731, ACOK 0V should be a clue that this line is connected to the voltage divider R1 and R2 with Pin 21 (VDDP 5V). trace it back
        • Techtiger
          • Oct 2014
          • 1601
          • france
          For RT6575AGQW, VIN should not be +5V. What voltage are yougetting for the +B line? Can you provide the voltage readings for the (+19v Line)2 Mosfet terminals: S, D, and G? upload a picture of the motherboard near the DC circuit on both sides. make sure RCTVCC line is fine
          • kalilinux25
            • Mar 2018
            • 2085
            • ZAMBOANGA SIBUGAY
            Thanks mate for the guide ive found that the 1st mosfet in the output side im getting 4v only so Ive decided to change it 6431a msofet, now unit is fully working thanks for the insight
              09-06-2024, 05:27 AM
            • flat-earther
              ASUS X54H laptop thinks it's always charging even with charger unplugged
              by flat-earther
              The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
              Windows also shows ''Plugged in'' when charger is not connected.
              This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
              Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
              If I let battery run out and say it has 3% Windows will...
              06-24-2025, 09:32 AM
            • zioricci
              Toshiba Satellite P855 charger disabled after a while
              by zioricci
              after a little operating time of my Toshiba laptop, ranging from about 20 to 45 minutes, the Power light goes off, the power supply switches from the charger to the battery and in fact the voltage of both gates of the 2 initial mosfets are at 0V so the 19V does not reach the PL201 inductor and the power comes only from the battery.
              However, when i close the cover to turn off the laptop, the charger starts working again, charges the battery and the Power light turns on in amber color but after about 20 minutes the charger is disabled and the power light...
              05-05-2023, 02:34 PM
              09-06-2024, 05:59 AM
