Problème avec Ports USB HP pavilion 15-bc402nf.DAG35MMB8C1
  • baata1
    • Nov 2022
    • 17
    • france
    Good morning,
    HP Pavilion laptop PC Portable model: 15-bc402nf.
    Motherboard reference: DAG35MMB8C1 REV:C
    I have a problem with USB ports and Bluetooth; they are not detected by either Windows or Ubuntu.
    In the device manager I have this message: xHCI USB compatible Host Controller.
    No success with all updates and bios flashing.
    I would like your help and you can send me the diagram of this card, that would be nice of you.
    Bonjour,
    Pc portable HP pavilion Notebook model:15-bc402nf.
    Référence carte mère : DAG35MMB8C1 REV:C
    J'ai un problème avec les ports USB et le Bluetooth; ils ne sont détectés ni par Windows ni par Ubuntu.
    Dans le gestionnaire de périphériques j'ai ce message : Contrôleur d'Hôte compatible xHCI USB.
    Sans succès avec toutes les mises à jour et flashage du bios.
    Je souhaiterai votre aide et vous pouvez me communique le schéma de cette carte ça sera sympa de votre part.
  • Techtiger
    • Oct 2014
    • 1601
    • france
    Re: Problème avec Ports USB HP pavilion
    Originally posted by baata1
    Good morning,
    https://www.badcaps.net/forum/showth...ht=DAG35MMB8C1
    • baata1
      • Nov 2022
      • 17
      • france
      Good morning,
      This is not the correct reference for my motherboard.
      Thanks again.
      • Techtiger
        • Oct 2014
        • 1601
        • france
        demonter the laptop find out in USB port if you are getting +5V
        • baata1
          • Nov 2022
          • 17
          • france
          Indeed I have a voltage of 5V at the USB output, I still have the error in the device manager. They are still not detected.
          • Techtiger
            • Oct 2014
            • 1601
            • france
            Have you tried with a keyboard USB if the Num lock led Working or not ?
            • baata1
              • Nov 2022
              • 17
              • france
              No, I haven't tried it with a keyboard, but I tried it with a mouse, it turns on but doesn't work.
              • baata1
                • Nov 2022
                • 17
                • france
                I will try tomorrow with a keyboard and I will let you know.
                Thanks again.
                • mon2
                  • Dec 2019
                  • 13863
                  If the mouse is not detected then the keyboard will probably not work either. Both are HID devices and natively supported by all operating systems.
                  Remove all power. Meter in diode mode.
                  Red meter probe to ground, yes red.
                  Black meter probe to D+ pin on the USB connector.
                  What is the voltage?
                  Repeat for D- pin connector. Compare the readings to a known good USB port measurement of any logic board.
                  • Techtiger
                    • Oct 2014
                    • 1601
                    • france
                    Follow the instructions of mon2
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      Re: Problème avec Ports USB HP pavilion 15-bc402nf.DAG35MMB8C1
                      Besides voltage readings, resistance to GND reading on D+/D- on usb ports?
                      • baata1
                        • Nov 2022
                        • 17
                        • france
                        Good morning,
                        I just tried as you indicated in your post; I connected the keyboard unfortunately the green light is absent it does not work.
                        • baata1
                          • Nov 2022
                          • 17
                          • france
                          Good morning,
                          I have just taken the measurements as you indicated in your message: in diode mode D- = 0.427 and D+ = 0.426.
                          Voltage mode Pin 1 = 5Volt.
                          D- = 0.033 Volts.
                          D+ = 0.044 Volts.
                          THANKS.
                          • baata1
                            • Nov 2022
                            • 17
                            • france
                            Hello, I need the HP Pavilion bios file Laptop model: 15-bc402nf.
                            Motherboard reference: DAG35MMB8C1.
                            Thank you so much.
                              • 20391
                              Thank you so much.
                              Reminder: rules and organization of this section - https://www.badcaps.net/forum/showthread.php?t=117483
                              RULES UPDATE for BIOS requests/offers *AVOID BANNING, READ BEFORE POSTING* - https://www.badcaps.net/forum/showthread.php?t=103570
