Chromebook recovery failed - how to fix it
  • volinakis
    • Jan 2021
    • 2743
    • N/A
    So I had a Asus C433T Chromebook enrolled and after I modified bios I had to reinstall Chromium. I made a USB recovery stick with Chromebook Recovery Utility but I got "an unexpected error has occurred ..." message. I did try with another USB stick, etc. etc. -all steps found on internet about this issue and nothing worked.
    Finally I found a site where they suggested to try with an older image and ... it worked!
    What I did:
    - when “Chrome OS is missing or damaged” message appeared I pressed Tab key and found: read only firmware id: Google_Rammus. xxxxx.xxx.x.
    - On "https://chrome100.dev/#recovery-images" I found older images by boards, in my case Rammus, downloaded one released soon after the date from the laptop's sticker (in my case 2020-05, I chose one released in 2020-06)
    - made USB recovery stick choosing "Use local image" in Chromebook Recovery Utility
    - after successfully recovery I did an update to OS, it restarted and also made an update to firmware (bios) and all is working well.
    I hope this is useful for ppl having the same problem with recovery.
    • 31077
    Re: Chromebook recovery failed - how to fix it
    mind if i ask what the bios patch was for?
    usually bios patching is done to install Linux afterwards.
    • volinakis
      • Jan 2021
      • 2743
      • N/A
      laptop was enrolled to a school account, I disabled enrollment and enabled developer mode - if this is what you asked.
      After updating Chromium OS to latest release, it restarted and a message with "apply critical firmware update" appeared on screen and I supposed it was a bios update, I didn't remove chipset bios to read it again to see if there is a newer version.
        • 31077
        i didnt know the android stuff was in the bios!
        • alaminp
          • Jan 2022
          • 21
          • saudi arabia
          https://chromewebstore.google.com/de...hdmidojbmbodfm
