X395 will not boot fan spins
  • zomi
    • Nov 2011
    • 510
    lenovo x395 ryzen
    20nms2t900
    turn it on fans spins then the cpu proceeds to get very very warm
    then fans come on to cool it
    does not post keyboard not lighitng up..
    any suggestions ?
  • Herby94
    MacBook Pro A1707 Won’t Boot – No Display, Fans Spin Briefly
    by Herby94
    I’m currently having an issue with my MacBook Pro (A1707). It doesn’t power on or make any sounds.
    • The charger is a generic third-party unit that had a loose connection at the AC input (127VAC). I fixed it, and now it delivers 20VDC to the laptop.
    • When connected, the fans spin for about 30 seconds before shutting off.
    • No display, no audio, and no signs of life during this time.
    Any ideas? Could this be a logic board issue, or is the charger still a problem? Thanks in advance!...
    08-07-2025, 08:59 AM
  • emil_t
    RTX3090 working fine but fans not spinning
    by emil_t
    Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
    04-12-2024, 06:54 AM
  • privato89
    Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
    by privato89
    I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
    Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
    Let's begin:
    Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
    03-26-2024, 06:37 AM
  • survivalbloke
    Macbook A1398 - no startup chime, no boot, but have fans and CPU warm
    by survivalbloke
    Macbook A1398 - had repeating loop of startup chime with no actual boot. Just startup chime, then restart, start up chime, then restart, etc. I pulled the battery and cleared BIOS. It will now power up, fans on, CPU warming, but no startup chime and no boot. I reflashed the BIOS chip but the same thing happening. Where should I go from here?
    06-14-2023, 11:45 AM
  • joesmoe91
    Dell Precision 5530 15" died to blown chip. Replaced chip and now only get momentary fans, lights, no screen or boot
    by joesmoe91
    My Dell Precision 5530 turned off suddenly when I was running Matlab and wouldn't turn on, show any lights, fans, and/or any signs of activity at all. I opened the case, removed the battery and looked at the board with a thermal camera while the AC adapter was connected. I saw that PU1252 was >120C so figured the chip had died on me Got the part number off the attached schematic (see Mouser link below) and replaced the chip. After replacing the chip the board (connected to AC adapter) was able to briefly power on, spin the fans a little bit, and turn on the front led lights....
    02-22-2024, 07:38 PM
