Acer Nitro 5 Dead
  • jasonr2000
    replied
    Re: Acer Nitro 5 Dead
    Check for 3.3v on battery connector first, with adapter plugged in. That way we can get an idea where to start measuring.
    im getting the following on the battery connector 0.27v
    Does 19V crosses after first dc-in mosfet?
    yes its passing the first dc-in mosfet.
  • jasonr2000
    replied
    Originally posted by Roti
    Measure the voltages and resistances from all coils. Is the motherboard LA-H501P? How much current does the motherboard take when plugged in?
    there are the readings for the resistance
    hi thanks for the reply I have my meter set to 2000 ohms
    and get the following readings
    PL301 34 ohms
    PL501 my meter shows it counting up then 1 (I think means out of range)
    PLB1 my meter shows it counting up then 1 (I think means out of range)
    PL1101 30 ohms
    PCV36 my meter shows it counting up then 1 (I think means out of range)
    PLW1 144 ohms
    PLV2 26 ohms
    PLV3 24 ohms
    PCV139 33 ohms
    PLH1 52 ohms
    PLA1 35 ohms
    PLZ4 34 ohms
    PLZ3 32 ohms
    PLZ2 33 ohms
    PLZ1 33 ohms
    PLG1 37 ohms
    PCZ47 my meter shows it counting up then 1 (I think means out of range)
    PLM1 311 ohms
    UV49 measures 440 ohms pins 5 6
    UV49 measures pin 1 no reading pin 2 1356 ohms
    UH2 measures pin 1 no reading pin 2 646 ohms
    UH2 measurers pin 5 27 ohms pin 6 571 ohms
    all the reaadings was done with my meter set to 2000 ohms
  • jasonr2000
    replied
    yes its the LA-H501P motherboard.
    and ok ill check for that thanks
    thanks ill check for that also today
  • mcplslg123
    replied
  • Th3_uN1Qu3
    replied
  • Roti
    replied
  • jasonr2000
    started a topic Acer Nitro 5 Dead
    Acer Nitro 5 Dead
    hi guys I have the above laptop
    Acer Nitro 5 AN515-45
    its dead as a dodo.
    im not sure where to begin checking for shorts.
    can anyone help ??
    many thanks
    Jason
