asus x409dl run 3vs and 5vs problem
  • ahmarzo
    • Mar 2015
    • 173
    • india
    have asus x409dl motherboard with no 3 vs and 5vs coming on pq8801 and pq8806.gate voltage is not coming on both transistor ans 12vs is not coming on pd8801 and pr8801,
  • ahmarzo
    • Mar 2015
    • 173
    • india
    Re: asus x409dl run 3vs and 5vs problem
    here is the link for boardview https://www.badcaps.net/forum/showth...57#post1248857
    • ahmarzo
      • Mar 2015
      • 173
      • india
      Anyone plz guide me solving this problem
      • mon2
        • Dec 2019
        • 14677
        Remove all power. For each power rail that is missing, check their resistance to ground. Post each measurement.
        • ahmarzo
          • Mar 2015
          • 173
          • india
          Thanks for reply 3vs to ground is 724 ohm and 5vs is 840 ohms .THE LAPTOP power on and 3v and 5v always voltage is present but it doesnt get converted to +3vs and +5vs.
          • Bonzas
            • 474
            • Indonesia
            Check pin 5 PD8701, 12vs generated from here. Remove PC8724
            • mon2
              • Dec 2019
              • 14677
              Attaching partial schematics of perhaps a similar logic board.
              • bokarnold28
                • Jan 2021
                • 10
                • philipines
                please share schematic
                • lazaro.089
                  Asus Zephyrus M16 / GU603ZW problem
                  by lazaro.089
                  Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
                  CPU: Core i9-12900H
                  Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
                  Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
                  The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
                  08-26-2025, 06:33 PM
                • AtelierRepa
                  ASUS X712JA problem
                  by AtelierRepa
                  I have a problem with the bios, let me explain.
                  With BIOS 1, the pc takes +- 30 seconds to display the ASUS logo (black screen) and to boot.
                  I did a clear ME, my black screen problem for 30 seconds at boot is solved, it gives me directly the display and boots quickly.
                  My problem is that now, once the charger is plugged in and I put a slight load on the processor, it bogs down to 0.39GHz...
                  The only solution is to unplug the charger to get the cpu back up to speed. But as soon as I plug in the charger, it goes straight back down....
                  06-15-2024, 04:33 AM
                • pkslowk
                  Debug Card Error Code and Solution
                  by pkslowk
                  Sr. Motherboard Debug Error Code Solution
                  1 Intel 845 E9 Bios Related Problem
                  2 Intel 845 D4 CPU Socket Related problem
                  3 Intel 845 37 Bios Related Problem
                  4 Intel 845 7C Bios Related Problem
                  5 Intel 945GCPE 34 Bios Related Problem
                  6 Gigabyte 845 2 Ram Related Problem
                  7 IBM Server A6 A7 Ram Mismatch Problem
                  8 Asus 845 29 CPU Related Problem
                  9 Lenovo I946 97 C-Mos Jumper related
                  10 Gigabyte 845 A0 CPU Related Problem
                  11 Asrock G31M-VS D7 Bios Related Problem
                  12 Compaq 845 BD-70G B0 CPU Socket Related problem...
                  01-28-2021, 12:51 PM
                • greg1985
                  Asus dabkxmb18b0 rev.b bios problem
                  by greg1985
                  Hi. I bought a damaged Asus motherboard, model dabkxmb18b0 rev.b. The problem with the motherboard was a faulty processor.
                  I replaced the processor, but it arrived without a BIOS chip. I found one post on the forum, but my problem is
                  I don't know which chip to program, and I don't have a schematic. Does anyone know which BIOS chip models are compatible with this motherboard? If so, please let me know. Thanks.
                  10-20-2025, 11:34 AM
                • boticario
                  problem with asus tuf A17 FA707NUR
                  by boticario
                  I’m trying to recover an ASUS TUF Gaming A17 FA707NUR (Ryzen + RTX 4050, 2023 model).
                  The laptop powers on, fans spin, but the dGPU (NVIDIA) is not properly initialized — sometimes it shows up in Device Manager with Code 43, sometimes black screen.
                  After several BIOS downgrades/upgrades (versions 300, 301, 303) and EC resets, it thinking looks like the EC firmware (IT5570VG-256) might have a persistent fault or flag stored in flash.
                  I already extracted the BIOS .CAP files and DXE sections with UEFITool and IFRExtractor, but I couldn’t find...
                  10-18-2025, 04:37 PM
