Dell Inspiron 15 3537 Compal LA-9982P
  • ziko07
    • Jun 2021
    • 99
    • Somewhere
    Hi , I have this laptop with no picture problem, also mo picture on external monitor via hdmi port.
    All coil voltage present, IC for LVDS has all voltages.
    Any tips?
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: Dell Inspiron 15 3537 Compal LA-9982P
    What voltage are present with coil reference? Have you Test with a work RAM ? is the DRAMRST Signal present on ram slot pin 30 ?
    • ziko07
      • Jun 2021
      • 99
      • Somewhere
      Yes tested with working RAM voltage on ram ok,also that half ram voltage ok,DRAMRST should be what voltage,ir need to test with oscilloscope?
      Tnx
      P.S No any voltage on that pin
      • Sametbey
        • Jan 2021
        • 229
        • Turkey
        The operating voltages of the RAM socket were measured on the Dell 5521 model. might help.
        Last edited by SMDFlea; 08-15-2023, 08:41 AM. Reason: image posted to badcaps from external link
        I'm not happy to be so strong. because it's not humanly
        • Techtiger
          • Oct 2014
          • 1602
          • france
          Sametbey good JOB
          • ziko07
            • Jun 2021
            • 99
            • Somewhere
            Thanks, I also found on net samething about pin 30
            • ziko07
              • Jun 2021
              • 99
              • Somewhere
              I did some measurment, DRAMRST# is missing
              DDR_PG_CTRL 1.35v
              0.675V_DDR_VTT_ON 4.88v, is this normaL? because I see 0.675v named net but voltage diveder looks ok
              Here images for measurment
              To have DRAMRST# voltage I guess need to be present some other signal,but not know which one. DRAMRST# goes from CPU
              • Techtiger
                • Oct 2014
                • 1602
                • france
                DDR_PG_CTRL 1.35v
                check the Ram slot pin 203 voltage if its +0675VS the move on, for 0.675V_DDR_VTT_ON 4.88v this is ok since @R2351 is not in used so V-Divider
                check RD3 470 with out power resistance, what is the voltage on J510 J511 VS
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Just bringing it to notice-This mb wont post unless edp cable with screen is plugged in.
                  • ziko07
                    • Jun 2021
                    • 99
                    • Somewhere
                    RD3 is ok,j510,j511 voltage present pin203 ram ok. All ram voltages ok except dramrst#. I saw other boards ,before dramrst# must have ok signal dram_pwrok,but not have on this board so named signal,maybe other named so if you have sch please find it.PLT_RST also present 3v2
                    Tnx
                    • Techtiger
                      • Oct 2014
                      • 1602
                      • france
                      is the Edp câble plugged in as mcplslg123! Mentions?
                      • ziko07
                        • Jun 2021
                        • 99
                        • Somewhere
                        No, just hdmi,but servicer bring no picture laotop problem.if not lcd connected will affect dramrst#?
                        • Techtiger
                          • Oct 2014
                          • 1602
                          • france
                          Tnx
                          You have not given the readings RD3 j510,j511 pin203
                          • Techtiger
                            • Oct 2014
                            • 1602
                            • france
                            Nop what is the voltage U2303 all pin
                            • ziko07
                              • Jun 2021
                              • 99
                              • Somewhere
                              I put measurements of u2303 above in attachment
                              Post #6
                              Pin2 = 1.36v
                              Pin5 = 1 35v
                              Pin4 = 4.88v
                              Its 7407 ic hex buffer
                              In input 1.36v
                              On output 4.88v, strange but on my inafe in post6 0.675c_ddr_vtt_on is connected to 5valw through voltage divider actually r2351 missing so its not divider as you wrote above
                              Tnx
                              • mon2
                                • Dec 2019
                                • 14552
                                7407 = open drain buffer. This means the output voltage does NOT have to be the same as the input voltage. Instead, when there is a low on the input, the output will be a low voltage.
                                If the input is a high voltage ('1' state); the output will float open and an external pull-up resistor will define the output voltage. Respectively, it is safe to have the output pulled-up to a higher voltage than the input range.
                                The exact datasheet for the 7407 will offer full details.
                                Being an OD buffer, '0' = '0' (input to output); '1' = 'Z' (high impedance unless the external pull-up resistor is present).
                                • ziko07
                                  • Jun 2021
                                  • 99
                                  • Somewhere
                                  Thanks MON2 for info
                                  • Techtiger
                                    • Oct 2014
                                    • 1602
                                    • france
                                    Merci
                                    • ziko07
                                      • Jun 2021
                                      • 99
                                      • Somewhere
                                      I guess no more tips
                                      Thanks to all tried to help
                                      Regards
                                      • ziko07
                                        • Jun 2021
                                        • 99
                                        • Somewhere
                                        Finally picture comes ON (on broken lcd tested)
                                        Very big thanks to "techtiger"
                                          DELL Inspiron 3671 Inspiron 3000 i3-9100 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 3671 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3671 boardview and Inspiron 3671 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          09-12-2024, 03:36 PM
                                          DELL Inspiron 5680 Inspiron 5000 i5-8400 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 5680 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 5680 boardview and Inspiron 5680 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          09-12-2024, 03:30 PM
                                          09-12-2024, 03:28 PM
                                          DELL Inspiron 5680 Inspiron 5000 i3-8100 Specification for Upgrade or Repair
                                          DELL Inspiron 3668 Inspiron 3000 i5-7400 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 3668 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3668 boardview and Inspiron 3668 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
