HP Spectre X360 battery ???
  • guizmo1967
    • Sep 2022
    • 77
    This laptop have been laying around for more than a year because it was not working and I did not have the tools at the time to repair it. But now I do and that's exactly what I did this week.
    I changed the first mosfet (was shorted) and the BQ chip, now the laptop is working. When I plug the charger, the light goes amber for 2 seconds then solid white. A solid white means the charger is plugged in and the battery is fully charged but I doubt it because it has not been plugged for more than a year ??
    If I remove the charger and push the power button, nothing happen as if the battery was completely drain but the light is solid white when the charger is plug in !!
    My question is:
    Is the battery too low to be recharge or is there something else I can do to revive it or there is another problem ?
    Thank you !
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: HP Spectre X360 battery ???
    The dc jack light goes from amber to white if battery is faulty and/or fully charged.So battery being faulty is the most likely scenario here.
      NVDC charger configuration...
      11-05-2024, 03:28 PM
      ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
      Highly Integrated Narrow VDC Battery Charger for Notebook Computers
      The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
      for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
      Narrow VDC applications where the system power source is
      either the battery pack or the regulated output of the charger.
      This makes the max voltage to the system equal to the max
      battery voltage instead of the max adapter voltage. Operating
      at lower system voltage can improve...
      11-05-2024, 04:43 PM
    • flat-earther
      how to prevent a connected charger from draining battery when not charging?
      by flat-earther
      I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
      So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
      but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
      So the battery is backfeeding the charger and being drained.
      How can I prevent...
      08-07-2025, 01:04 PM
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
      Bauer tool battery pack charging with a HERCULES charger modification
      The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
      Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
      05-06-2023, 12:17 PM
