Lenovo Flex 5-14ARE05 - bricked.
  • twonk9098
    • Aug 2018
    • 75
    Hi Everyone,
    I have a Lenovo Flex 5 -14ARE05.
    The Esc and Caps Lock lights are on, black screen, fans kick in when required and the laptop charges.
    From what I have read on here these seem to be the same symptoms that others on here are getting therefore re flashing their bios to cure the problem.
    I have tried flashing my bios and a number of bios's from another thread on this site only to end up with exactly the same symptoms, nothing changes no matter which bios I flash.
    I am using the CH431A V1.7 which allows me to select 1.8v without an adapter. This I have also confirmed with a multimeter.
    My bios chip is a MX25U12873F and my logic board is a LC55-14A.
    Can anybody help me with this issue?
    Many thanks
  • twonk9098
    • Aug 2018
    • 75
    Re: Lenovo Flex 5-14ARE05 - bricked.
    Update,
    Iv'e checked the inductors on the logic board and I am measuring the following voltages.
    12v, 5v, 3.3v, 1.2v, 0.8v.
    The CPU does get warm and the fan kicks in to cool it down again.
    I have also noticed that pressind Caps lock on / off does nothing, the light stays on.
    If I press FN + Space the Caps lock light goes off however I cannot get it to turn back on. FN + Esc toggles the ESC light on and off.
    Thank you
    • mon2
      • 14664
      Attach a USB mouse / USB thumbdrive with a LED onboard. Does the LED flicker during power on boot cycle? If yes, then it is possible the unit is booting and attempting to use the USB device.
      • twonk9098
        • Aug 2018
        • 75
        I have does this. The light on the USB Flickers for about 6 seconds, then becomes on and stable. After a further second or so it starts to flicker again for around 2 seconds and then stays on. There is no more activity after this.
        Thank you
        • koby058
          • Jan 2017
          • 387
          • israel
          I would have try an external screen, with and without LVDS connected
          • twonk9098
            • Aug 2018
            • 75
            Thanks Mon2 and Koby however I have done both to no avail.
            I have bought a new chip and restored the original bios on to it. This also made no difference therefore my next step was to try a bios reinstall from USB.
            This time the USB activity led flickers for about 5 minutes before turning off. Again though nothing changes after this either.
            Thanks for your help an suggestions.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              DRAMRST# status? Ram on board or via slot? What is the consumption on DC supply?
              • twonk9098
                • Aug 2018
                • 75
                Thanks for all your help guys.
                Upon further inspection I found the tiniest corrosion on two of the pins on the EC chip. After cleaning I noted that both pins were no longer attached to the pads due to the corrosion.
                I jumpered both pins to their respective areas on the logic board and the laptop came back to life.
                I restored the original bios so I have ther serial number and windows keys also.
                Again thanks for all your suggestions and help.
                Regards
                  Lenovo IdeaPad Flex 5 Hybrid (2-in-1) Flex Specification for Upgrade or Repair
                  This specification for the Lenovo IdeaPad Flex 5 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Flex 5 boardview and Flex 5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                  09-07-2024, 07:20 AM
                  09-07-2024, 06:38 AM
