Acer Predator Helios 300 FH52M LA - J891P Rev 1b
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Acer Predator Helios 300 FH52M LA - J891P Rev 1b
    Are you sure EC_ON is measuring 5V? You can try de soldering DB2/3/4. Just desolder them and fix them on one pad so that you dont loose the parts. However,problem does not seems related to db2/3/4 to me but no harm in trying.Measur voltage on pin7/8/9/11/12 of PUM1 after triggering.
    • tblazers
      • Jun 2023
      • 27
      • New Zealand
      oh yes correction EC_ON is 3.3V
      Okay maybe i wont touch DB2/3/4 for now.
      PUM1
      ac only
      pin7 14mV
      on trigger
      Pins
      7 30mv
      8 really quick jump to 1.5-2 V
      9 13.4V
      11 5.1V
      12 5.1V
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Pin7 & 8 is enable and pin9 is Timer ON(TON). There should be resistor connected to pin9 of high value (400K-750K). Check its value as per schematics preferably out of circuit. This resistor should get 19V on one end and there should be 08-.09v approx on the other end of resistor(IC side). confirm your findings.
        • tblazers
          • Jun 2023
          • 27
          • New Zealand
          Thanks for your help
          I am getting 13.4 V on the resistor PRM6 on Pin 2, Pin 1 is 19.6 V, this resistor does read 470K Ohm while on board.
          seems odd if it is suppose to be 0.08V
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            OK resistor PRM6 is not working as you have enables missing on pin7-8. What is resistance to GND on pin7 & 8 of PUM1? The resistance should be measured without any power source connected and better if you measure after 5 mins of disconnecting power so that circuit can discharge properly. To me, it seems like some shorting in SLP_S3/S5 probably.
            • tblazers
              • Jun 2023
              • 27
              • New Zealand
              #26
              Thanks,
              Interestingly I have
              Pin 7 ~365K Ohm
              Pin 8 ~1.1M Ohm
              Where else could i check in SLP_S3 for a short.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                #27
                UQ1 & UQ2-voltage on pin 8-9 & 13-14 for the brief moment when it remains on? Resistance to GND on these pins for both load switch?
                • tblazers
                  • Jun 2023
                  • 27
                  • New Zealand
                  #28
                  UQ1
                  Pin 9/8 on trigger very quick 3.3V
                  Resistance to ground >2mohm
                  Pin 13/14 on trigger very quick 5V
                  Resistance to ground 7.5ohm
                  UQ1
                  Pin 8/9 on trigger 0v
                  resistance to ground 300Kohm
                  Pin 13/14 on trigger 0V
                  Resistance to ground 340ohm
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    #29
                    I beleive the lower measurements are for UQ2 and its typo. Going by your measurements for UQ1,pin13-14, you have a short to GND on +5VS line. Remove UQ1 and inject voltage on pin13-14 to findout what is short. You need a dc power supply to do that. Voltage injection should not be more then 1V.
                    • tblazers
                      • Jun 2023
                      • 27
                      • New Zealand
                      #30
                      Yes correction bottom measurements are for UQ2,
                      Sounds i wassnt dure 7ohms would be considered a short, but I will inject 1V on the +5vs line.
                      Is it necessary to remove UQ1 when doing this ?
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        #31
                        Yes, you should remove UQ1 and then again measure resistance to gnd on pin13-14. If it still remains at 7 ohms,inject voltage to find out what is short. If the resistance climbs up significantly after removing UQ1,then this itself is faulty.
                        • Sephir0th
                          • Oct 2020
                          • 1289
                          This is actually a cool finding. If the +5VS stays at 7 Ohms after removal of UQ1 and if we consider +1.8VS being a issue too, then we immediately end up in the range of the Audio Codec, UA1 and I have to revise my theory of a defective PCH.
                          FairRepair on YouTube
                          • tblazers
                            • Jun 2023
                            • 27
                            • New Zealand
                            #33
                            Apologies for not listening to the jedi's fully
                            But i went on a slightly different route before i removed UQ1. I decided to desolder JPQ2 to isolate the 7 ohm, once +5Vs and +5Vs_out were decoupled the 7ohm disappeared on the UQ1 side, and the 7ohm remained on +5Vs line.
                            So injected on that line and found that the resistor near PUV1 is warming up (PRV42). But also PUV1 is warming up slightly too
                            Resistance across PRV42 is 3.4ohm while on board which i think is correct.
                            Could this resistor be the issue or would PUV1 be faulty?
                            Injected 1V on the +5Vs line and it is drawing 135mA.
                            Maybe we are close to the end of this saga haha
                            • Sephir0th
                              • Oct 2020
                              • 1289
                              Remove PRV42 to prove. Altwrnatively, in this case even the knowledge on which side of the 2.2Ohms resistor is the lower resistance to GND present should give the clue.
                              Either way, you're probably on the right track here.
                              • tblazers
                                • Jun 2023
                                • 27
                                • New Zealand
                                #35
                                What's the point of a resistor like this it's like a fuse type wire with such low resistance?
                                Yes I will remove it tomorrow but
                                The resistance to gnd is lower on the puv1 side (5ohms),
                                So either PUV1 or the Cap on the same side, could the badcaps prophecy be fulfilled.. we'll find out tomorrow
                                • Sephir0th
                                  • Oct 2020
                                  • 1289
                                  A Capacitor usually shorts out completely so probably not the case with 5 Ohms to GND. It is PUV1.
                                  And yes, resistor purpose is likely to act like a very slow blow fuse. Actually it even didn't work in this case ( lol )
                                  • mcplslg123
                                    • Jun 2015
                                    • 7262
                                    • india
                                    #37
                                    Good to see you inching closer to fault.Remove PUV1 and check resistance to GND again on +5VS line. However, i'm afraid to say GPU may be dead as well.
                                    • tblazers
                                      • Jun 2023
                                      • 27
                                      • New Zealand
                                      #38
                                      I haven't removed yet, but just wondering why would you expect the GPU to be dead, if i find that PUV1 is faulty how can i confirm GPU health before replacement of PUV1?
                                      • Sephir0th
                                        • Oct 2020
                                        • 1289
                                        You simply can't confirm right now. The usual task is to replace and see.
                                        • tblazers
                                          • Jun 2023
                                          • 27
                                          • New Zealand
                                          #40
                                          Removed PUV1 and short on +5VS is gone, will have to order a UP9512QQKI
                                          and see if it works
