Acer Nitro 5 3valwp short 1ohm
  • Thomas8607
    • Feb 2021
    • 30
    • Hungary
    Hi all!
    I have an acer nitro 5 notebook. The 1,05v, 1,8v and 3valwp were short.
    I injected 3v on 3v rail and the pch was hot,i desoldered it.
    The 1,8 and 1,05v are ok now, but the 3v still shorted.
    The 3v to ground resistance is 1ohm (not zero).
    Where do i find the fail?
    I have schematic and boardview too.
    Thanks!
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Acer Nitro 5 3valwp short 1ohm
    Should'nt have injected more then 1V. Injecting 1V again on the shorted rail doesnt heats up anything? My doubt goes towards EC. Howver, i'm not very hopeful if 1.05V/1.8V and 3.3V rail were all shorted together as chances of cpu getting hit is also very high.
    • Thomas8607
      • Feb 2021
      • 30
      • Hungary
      I will try injecting again, with 1v.
      I injected 3v to 3v rail, so with 1v nothing happened.
      I hope, that the cpu survive this.
      Thanks!
      • Thomas8607
        • Feb 2021
        • 30
        • Hungary
        I've found a hot component. UL1, this is the LAN power supply ic, I've removed it. Now i'm measuring 11,8ohm resistance on 3valw.
        EC isn't warm
        This resistance is low.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Yes, resistance is still way below normal. This imples there are other shorted components also. This may lead you to rabbit hole with such kind of simultaneous shorting on different rails. Voltage injection is the only way you can findout shorted component and there lies the catch as you cant inject more then 1V. Dc supply with 10A helps a bit in such scenarios.
          • Thomas8607
            • Feb 2021
            • 30
            • Hungary
            There are some components on 3v rail,
            I will try these desoldering
            Um1 wlan
            Uk1 touchpad
            Uk2 fingerprint?
            Um2?
            Uq1?
            Pj1001
            There is a problem with voltage injection, the ohm law.
            1V/10ohm = 0,1A this is 0,1W power
            Or not?
            • Thomas8607
              • Feb 2021
              • 30
              • Hungary
              Sound ic was dead 😀
              Now i'm measuring 140ohm. This is low too ☹️
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Remove all usb controller/diodes,sound,lan,card reader chips and then measure resistance to GNd again on the affected rail.
                • Thomas8607
                  • Feb 2021
                  • 30
                  • Hungary
                  I've removed all active components, or jumper(amper measurement point) and measured all resistors, which are connect to +3valw rail. I haven't found failed components.
                  (usb controller is on 5valw)
                  I'm measuring 240ohm,but it is without pch. If i will solder the pch, then it is more resistance? (i measure low resistance, because the pch isn't on the motherboard)?
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Without the PCh soldered, resistance to GND on +3VALW rail should be in Kohms. So there is still faulty component.
                    • whaldsz
                      • Apr 2013
                      • 395
                      • Philippines
                      Remove the coil at +3VALWP and check which side is shorted. It is possible that the 240 ohms resistance you get is from the IC Regulator, or any of the capacitors along that rail.
                      • Thomas8607
                        • Feb 2021
                        • 30
                        • Hungary
                        I've tried it, almost same resistance (more 20ohm).
                        • Sephir0th
                          • Oct 2020
                          • 1260
                          You got clear advises, so it should be okay to expect you being way more clear with your answers, otherwise nobody will understand you.
                          And it seems like you still need to realize that you're probably dealing with multiple bad components on the 3.3V rail und you have to get rid of all of them till the 3.3V rail has a healthy resistance to GND again.
                          FairRepair on YouTube
                          • Thomas8607
                            • Feb 2021
                            • 30
                            • Hungary
                            Sorry if I write something wrong, my English is bad. I may have said the wrong thing, or they mean it.
                            I removed and measured the following components and the resistance value did not change. I'm sure I'm missing something, but I can't figure out what.
                            I measured these:
                            Q10, Q11, Q12, Q13 next to SIO
                            PR1009 10K
                            RH3 10K
                            RH200 10K
                            RH201 10K
                            RH25 1K
                            RH26 1K
                            RH27 1K
                            RH29 100K
                            RH55 1K
                            RH56 8K2
                            RH183 10K
                            RH251 2K2
                            RH252 2K2
                            RH253 2K2
                            RH254 2K2
                            RH63 499OHM
                            RH64 499OHM
                            RH215 2K2
                            RH216 2K2
                            RH217 2K2
                            RH218 2K2
                            RB78 10K
                            R38 100K
                            R37 100K
                            I removed and measure resistance on 3valw:
                            UL1
                            UM1
                            UH2
                            UM2
                            UK1
                            UQ1
                            PCH
                            I soldered these jumpers apart:
                            PJ1001
                            JPB1 (SIO)
                            PJ2501, PJ2502
                            PJ302
                            There must be a faulty part that I missed
                            Thank you everyone!
                            • whaldsz
                              • Apr 2013
                              • 395
                              • Philippines
                              You've done a lot!
                              You haven't removed PU301, have you? How about the capacitors prior to +3ALWP? You can also inject up to 3.3v at PL301 then check (via thermal scanner) which one is heating up.
                              • Thomas8607
                                • Feb 2021
                                • 30
                                • Hungary
                                If i've cutted the jumper between 3valwp and 3valw, then i've measured kohm range on 3valwp (on pl301), also capacitors are good.?
                                I tried lift up coil too.
                                Thank you!
                                • Thomas8607
                                  • Feb 2021
                                  • 30
                                  • Hungary
                                  I will remove the next capacitors:
                                  CH10
                                  CH36
                                  CH39
                                  CH38
                                  CH41
                                  CH42
                                  CH40
                                  CL16
                                  CM15
                                  CK3
                                  C56
                                  C59
                                  CQ7
                                  PC307
                                  PC308
                                  PC309
                                  PC310
                                  PC311
                                  PC312
                                  PC1114
                                  PC1807
                                  PCH14
                                  Or the MLCC capacitors fault not 200ohm?
                                  • Thomas8607
                                    • Feb 2021
                                    • 30
                                    • Hungary
                                    Or these ICs?
                                    The PCH shorted the 1,05 and 1,8V
                                    Maybe these ics are bad?
                                    I measure a good resistance at the output of their coil, but on the byp pin is the 3valw.
                                    • Thomas8607
                                      • Feb 2021
                                      • 30
                                      • Hungary
                                      Since it was at the mechanic before me, I looked at the 19v rail as well. After the second FET, I measured 36 ohms. I tried injecting 1V but nothing happened. I raised it to 5V and the ipa disappeared from the 1.05v reg ic. I removed the IC and the 19vb rail and the 3valw (3.56kohm) rail were also fine.
                                      Also i have some bad components:
                                      Sound ic
                                      Lan ic
                                      Lan voltage enable ic
                                      Pch
                                      1,05v reg ic
                                      Charger ic
                                      Now are good all of voltage rails resistance.
                                      • Thomas8607
                                        • Feb 2021
                                        • 30
                                        • Hungary
                                        I removed Pch, with the power supply there was 5v, after pressing the power button, 3.3v, 1.8v and 1.05v also appeared.
                                        After soldering a new sr40b pch, the resistances are good. Switched on the notebook, the pch again in short circuit (3.3v, 1.8v and 1.05v 0ohm).
                                        The pch is an aliexpress purchase, from a reliable source.
                                        What could be wrong?
                                        Thank you for your help!
                                        LA-H501P
