Data Recovery Question PCIe Samsung Apple SSD
    No photos found.
  • a_p3rson
    Apple Watch Charging Controller Schematics / Boardview - 820-02601
    by a_p3rson
    Hi there,
    I'm looking for anyone who might have information on Apple's embedded Apple Watch charging daughterboard, ID 820-02601. This is currently used by Anker in their Apple Watch charging products, but likely by other Apple partner brands as well.
    You can see the board referenced in ChargerLab's teardown of the Anker Y1811 3-in-1 MagSafe cube - they discuss the "Apple Watch wireless charging circuit" about 2/3rds down the page. It's not pictured, but the board ID reads 820-02601-A, which sure sounds like Apple.
    This daughterboard uses an interesting...
    04-21-2025, 11:41 PM
  • reformatt
    Intel iMacs, 3rd party SSD failures and Fusion setups
    by reformatt
    I thought I'd throw out some of my personal experiences in the last 12 months with Intel iMacs, 2.5" SATA SSD drives and Fusion drive data recoveries.
    As a backgrounder, Apple never fitted a 2.5" SSD's to these iMacs. Apple's SSD option was a system of 32GB NVMe blade drive (NGFF connector) and Seagate 1TB 2.5" HDD, married together in software to become a Fusion drive. Non Fusion systems have just the 1TB Seagate HDD.
    So, the most common reason an iMac comes across my bench is because it's either ridiculously slow, or it fails to boot at all. The most...
    12-18-2024, 10:34 PM
  • Deeloc
    How to flash SSD 1tb WALRAM controller SM2259XT2G flash samsung NAND V6
    by Deeloc
    I have a 1tb WALRAM SSD (Photo)
    Controller SM2259XT2G (photo)
    Samsung memory (photo):
    Part Number K9DVGB8J1B DCK0
    Name V-NAND V6
    Type TLC
    The SSD itself is detected as 1gb, but is not initialized.
    There is a Sata to USB adapter
    A lot of SMI MPTool, did not flash it. compare flash fail (17)
    K9DVGB8J1B is not listed anywhere
    What to flash?​...
    06-05-2024, 08:32 AM
    09-07-2024, 05:50 AM
  • master3112
    ASUS ROG Strix- G513IH-HN008, G513-6050A3249301- MB-A04 (A4) damaged Embedded Controller
    by master3112
    I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
    When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on...
    10-29-2024, 09:32 PM
