Mac air a1465 fan spin but no boot
  • smic717394
    • Jun 2017
    • 95
    • Spain
    Hi guys, I have a Mac air 1465 2015, fan spin but no image. After inspecting the main board, I found no corrosion even the test points are nice and shiny.The boards its so clean looks new. Anyways PPBUS_G3H is present 8.6V, PP3V42 is present 3.42V, the CPUVR is present 1.8V and the cpu gets warm, 3V present, 5V present. Since its start fine all the s5, s4,... must be present. I checked the s0 power rails at some points and they there.
    I also programed the flash rom U6100 with few firmware I found on the web, but the same result. Checking with the thermal camera there are 2 heath spots more than the rest, nothing over the limit about 40 degrees , one is the U7400 that is a TPS51916 that is a ram powersuply. checking the voltage near the ram and there is the 1.3v. I also reflow all the chips, with no improvements.
    The other chip that gets hot is the U3900 that is a BCM15700 IC, I think this is the camera memory ic. Now this hets warm but on one side only towards one edge.
    So basically the laptop comes on, at start I get the green then orange light on the charger, the fan spins but normally not at full speed, the battery charges fine, the light get green after the batter is fully charged, and it can start from the battery as well. Apparently everything ok, but no chime or image.
    I tried to reset the PRAM but it doesn't react. If I power it from the PSU 18.5V I see it takes about 0.441amp and if I connect the ssd goes to about 0.500 or something like this.
    The only thing I see wrong on the visual inspection is the stud where the m2 drive should be screwed is been rip of the board, but I don't see major damage.
    I'm starting to think that is a bad cpu. Any thought will be appreciated.
  • dellxps15
    • Feb 2014
    • 1598
    • italy
    Re: Mac air a1465 fan spin but no boot
    report resistance on cpu vcore. on air should be around 22 omh.
    also it could be bad u1950 when u have cpu voltage but no boot.
    • smic717394
      • Jun 2017
      • 95
      • Spain
      To measure the vcore, is on sny of the 2 coils, the cpu side?
      • mon2
        • 14667
        Either side is ok. A coil is essentially a long run of wire.
        • smic717394
          • Jun 2017
          • 95
          • Spain
          Vcore is 7.85 ohm
          U1950 has.
          Pin 1: 3.337
          Pin2: 3.337
          Pin3: 3.429
          Pin5: 3 429
          Pin6: 3.429
          Pin7: 3.429
          Pin8: 3.429
          • smic717394
            • Jun 2017
            • 95
            • Spain
            Vcore is 10.71 ohm
            U1950 has.
            Pin 1: 3.337
            Pin2: 3.337
            Pin3: 3.429
            Pin5: 3 429
            Pin6: 3.429
            Pin7: 3.429
            Pin8: 3.429
            • dellxps15
              • Feb 2014
              • 1598
              • italy
              remove heatsink. check if pch get hot, but dont stay without heatsink and power on more then 5 -6 seconds. just check quickly if pch get hot then remove power.
              ps: i5 or i7 cpu ?
                Acer Spin Spin 511 R753TN Chromebook Specification for Upgrade or Repair
                This specification for the Acer Spin Spin 511 R753TN Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 511 R753TN boardview and Spin 511 R753TN schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                09-07-2024, 02:20 AM
                Acer Spin Spin 3 SP313-51N-58JR Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                This specification for the Acer Spin Spin 3 SP313-51N-58JR Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 3 SP313-51N-58JR boardview and Spin 3 SP313-51N-58JR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                09-06-2024, 09:30 PM
                Acer Spin Spin 3 SP313-51N-58LR Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                This specification for the Acer Spin Spin 3 SP313-51N-58LR Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 3 SP313-51N-58LR boardview and Spin 3 SP313-51N-58LR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                Acer Spin Spin 3 SP314-54N Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                This specification for the Acer Spin Spin 3 SP314-54N Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 3 SP314-54N boardview and Spin 3 SP314-54N schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                09-06-2024, 07:50 PM
                Acer Spin SPIN 1 SP111-33 Hybrid (2-in-1) 1 Specification for Upgrade or Repair
                This specification for the Acer Spin SPIN 1 SP111-33 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SPIN 1 SP111-33 boardview and SPIN 1 SP111-33 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                09-06-2024, 08:40 AM
