HP ProBook 4440s ONLY charges when OFF
  • orientalsniper
    • Apr 2013
    • 459
    Hello all, has anyone encountered this issue? I've read the usual suspect is AD_ID or LIMIT_SIGNAL (in this case) but I'm measuring 7V. I suspect it is the power jack, but there's continuity between the center pin and the pin #3 of the cable.
  • mon2
    • 13994
    Re: HP ProBook 4440s ONLY charges when OFF
    https://h30434.www3.hp.com/t5/Notebo...f/td-p/5875274
    • orientalsniper
      • Apr 2013
      • 459
      Tried disabling the driver and still the same, but my symptom differs from his, the jack only turns on amber/orange LED when the laptop is off, when the laptop is on, it doesn't have the white or amber LED, it's as if the ac/dc adapter is not plugged in, but Window says it's plugged in.
      • maxsim86
        • Apr 2014
        • 21
        • malaysia
        mybe u need try to use live linux
        • mon2
          • 13994
          Link or post the schematic for this laptop in the schematic forum.
          The power adapter is not the proper rated model for this laptop or the laptop circuit is detecting the adapter to be under powered. When the laptop is off, the battery charging is able to continue and vice-versa. Unable to perform both tasks to keep the laptop powered and charge the battery.
          • orientalsniper
            • Apr 2013
            • 459
            Same effect booting with PartedMagic.
            The adapter is original, but I also tried another adapter.
            Schematic ---> https://www.badcaps.net/forum/showth...09#post1012109
            Last edited by Vesko356; 06-12-2023, 03:26 PM. Reason: Attached schematic removed and replaced with link.
            • mon2
              • 13994
              Measure the voltage to ground of VOLTAGE_ADC with the power adapter plugged in.
              • orientalsniper
                • Apr 2013
                • 459
                Measuring PIN 3 of D2703 (VOLTAGE_ADC) I'm getting 1.45V
                Also, I notice when I plug in the adapter, the led in the dc jack turn on white for 1 second.
                To clarify, the laptop doesn't charge when I turn it off, I have to unplug ac/dc adapter then remove battery and then plug in the adapter, if I turn off the OS, it won't charge until I do that procedure.
                • mon2
                  • 13994
                  Measure the voltage to ground of each pin on mosfet PU4002.
                  Source (1-2-3)
                  Gate (4) = ACDRV
                  Drain (5-6-7-8)
                  Do not remove the battery - leave in both, the adapter and the battery.
                  For this mosfet to enable, the gate voltage must be ~25 volts.
                  This boosted gate voltage must be stable at all times to confirm the logic board is being powered by the external power adapter. Otherwise, the battery is powering the logic board.
                  • orientalsniper
                    • Apr 2013
                    • 459
                    Source (1-2-3)
                    Gate (4) = ACDRV
                    Drain (5-6-7-8)
                    With battery + adapter:
                    19.3v
                    25v
                    19.15v
                    Just adapter:
                    19.7v
                    25.67v
                    19.7v
                    I have to add that when I plug in the adapter, although it doesn't charge the battery, the battery doesn't discharge, but the dc jack led is off.
                    • mon2
                      • 13994
                      If you remove the battery and use only the power adapter, does the DC jack led remain on?
                      Does the laptop function with only the power adapter?
                      Test with a known good battery. Grab one from Amazon. You can always return it if it is not required.
                      • orientalsniper
                        • Apr 2013
                        • 459
                        I'm not with the laptop at the moment, but it can work without the battery, just power adapter.
                        I forgot to state that I already ordered a generic battery off of eBay. So it's been tested with 2 power adapters and 2 batteries (generic).
                        I have to see if the led remains on if I remove the battery.
                        • orientalsniper
                          • Apr 2013
                          • 459
                          Just tested it, while off:
                          I remove the battery, put it back in, plug in power adapter: white (full ) or amber (charging) led turn on.
                          But if I remove the battery while the power adapter is plugged in: the led turns off immediately.
                          • orientalsniper
                            • Apr 2013
                            • 459
                            Bumping, would appreciate if anyone can help.
                            I tried with a new dc in jack and the symptoms are the same.
                            I tried flashing a new bios with clean ME too.
                            Even Windows says the adapter is plugged in, but the dcin jack has no LED on.
                            Most strange thing is that the laptop's screen react (brighten and dim) when the adapter is plugged/unplugged.
                            • orientalsniper
                              • Apr 2013
                              • 459
                              It charges now, I was running the HP Battery Check.
                              When I first ran it, it said adapter plugged in. Ran the tool a second time and it showed charging, so it was like huh? Looked at the dc jack and it was amber!
                              I kinda suspect it was the ME clean combined with the HP Battery Check tool.
                                HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                                This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                09-07-2024, 07:12 AM
                                09-07-2024, 06:40 AM
                                HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                                This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                09-07-2024, 05:50 AM
                                HP ProBook Prenosni računalnik ProBook 445R G6 Notebook 400 Specification for Upgrade or Repair
                                This specification for the HP ProBook Prenosni računalnik ProBook 445R G6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Prenosni računalnik ProBook 445R G6 boardview and Prenosni računalnik ProBook 445R G6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                09-06-2024, 10:51 AM
