Default HP X360 ( FAROE _DIS_X32_MB_MV 18742-1) no charging
  • mon2
    • Dec 2019
    • 14659
    Re: Default HP X360 ( FAROE _DIS_X32_MB_MV 18742-1) no charging
    Yes, these PCB measurements are now excellent.
    You must replace mosfet #1. Mosfet #2 appears to be ok.
    Solder the first mosfet back and continue to check after your rework. If the mosfet readings remain high, the mosfet and soldering are good.
    Then solder back the 2nd mosfet. Measure again.
    Then power up to test the logic board.
    • kingskie
      • Oct 2014
      • 249
      • indonesia
      ok @mon2, i have to buy the mosfet. later i will update the result.
      thanks alot
      • kingskie
        • Oct 2014
        • 249
        • indonesia
        update,
        after changing 1st mosfet all seems ok. got light when power on with power supply.
        but when i check the battery status in windows it says charging but not increasing. but when i turn off while still connected to power supply and wait for couple minutes and turn on again, check the battrery status it is increasing.
        maybe i should check with orinigal power adapter?
        • mon2
          • Dec 2019
          • 14659
          Good to hear of your progress.
          Yes, test with the original and with the recommended power rated adapter. This is the first suggestion.
          Also consider to test with a known good battery if there is still a fault.
          • kingskie
            • Oct 2014
            • 249
            • indonesia
            customer tried himself and no return.
            case closed. thanks @mon2
            • coasterghost
              Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
              by coasterghost
              For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
              Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
              Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
              System Hardware:
              Processor: AMD Ryzen 7 PRO 5850U
              Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
              09-08-2025, 10:46 PM
            • pb1911nt
              MacBook Pro A2251 - 820-01949 Voltage Drop and unkown issues.
              by pb1911nt
              Hello forum,
              I'm still relatively new to the world of electrical repairs.
              I have a Macbook here that I can't figure out
              When the battery is gone, the USB input consumption goes up to 20 V and 0.06A. But it breaks down after about 2-3 seconds and you can also hear a small ticking on the logic board. But I can't pinpoint it exactly.
              I removed the logic board and took a few measurements.
              But I can't really figure it out.
              At first I thought the infamous CD chip was defective - but then of course you read more on the internet...
              09-07-2025, 11:35 AM
              HP ProBook x360 Pro x360 Fortis 11 inch G9 Notebook PC Hybrid (2-in-1) Specification for Upgrade or Repair
              This specification for the HP ProBook x360 Pro x360 Fortis 11 inch G9 Notebook PC Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pro x360 Fortis 11 inch G9 Notebook PC boardview and Pro x360 Fortis 11 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
              09-07-2024, 05:50 AM
