Crazy Laptop problem - HP Envy x360
  • John Jenson
    • Dec 2018
    • 32
    Re: Crazy Laptop problem - HP Envy x360
    Originally posted by mon2
    Yes, it will be fine.
    Just wondering because this laptop uses BitLocker to encrypt the data and I don't want to lose data. Of course I will definitely back up the data before I do it; I just don't want to have to do a reinstall.
    • mon2
      • 14746
      No experience in that area so what for other comments.
      • reformatt
        • Feb 2020
        • 1541
        Dump your Bitlocker recovery key from Windows settings or via manage-bde command prompt to a txt file on usb etc. Bios updates usually suspend encryption anyway, but always safe to have your key regardless.
        • John Jenson
          • Dec 2018
          • 32
          Okay, replaced the BIOS. Did not fix the problem.
          • John Jenson
            • Dec 2018
            • 32
            So no one has any ideas on what could be the problem? Could I possibly be the first one to ever have this problem with an HP laptop?
            • reformatt
              • Feb 2020
              • 1541
              Normally things like this it's a failed power button. CMOS reset the laptop turns itself on, so power button response would be next thing to check. You'd probably need a schematic to see what is going on around the EC if that checks out.
              • John Jenson
                • Dec 2018
                • 32
                It's obviously not the power button based on the symptom.
                If I hold the power button down when it's running, the computer powers off. If I hit it again, it boots and the power button lights. It's just if I do a normal Windows shutdown, it turns off and won't come on again (charging light goes out as well). I've searched around this forum and no one has ever had such a problem.
                I would love to get this schematic, but from where?
                • John Jenson
                  • Dec 2018
                  • 32
                  I believe I've found the problem. I was measuring switching supply voltages with my multimeter and measured 5v, 3.3v and then I measured a 4v. 4v seems like an odd ball voltage, so I broke out the scope and found a square wave on the coil. This circuit is the charge controller. Apparently the ISL9538B charge controller is acting funny. I'll have to wait 3 weeks to replace it due to China delivery.
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    #29
                    Apparently the ISL9538B charge controller is acting funny-Can you elaborate a bit more why you think so?
                    • John Jenson
                      • Dec 2018
                      • 32
                      I thought I did that already. I was getting a square wave on the coil instead of a smooth voltage.
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        #31
                        Did you measured booth sides of the coil with scope?
                        • John Jenson
                          • Dec 2018
                          • 32
                          You know I did. I was getting the same phase signal on both sides, which is why I said the circuit was acting funny.
                          I also checked the inductor (2R2) with an LCR meter to not only make sure it wasn't open, but to make sure it was still 2.2uh. I removed the inductor so I could check the dual MOSFETs, which appeared to be okay and for good measure, I (because I had so much time on my hands) swapped the 2R2 inductor with the one in the 5v circuit and there was no change. The 5v still worked and the charging power supply still put out a square wave. There is a lot more testing I would do if I could get my hands on schematics; but since there aren't any, I am left with my own intuition.
                          As far as the ISL9538B. I was able to get a limited datasheet for that chip, however, there are no pin numbers as it seems to be privileged information that you need secret clearance to obtain. I tried getting a full datasheet from Renesas Electronics Corporation. I had to register on their site and then after filling out all the info, waiting and activating my account, I then tried to get the datasheet only to be told that I with be contacted in 24 - 48 hours if I qualify to obtain such secret info. I guess this company is paranoid that I'm going to reverse engineer their products and put them out of business.
                          I could buy another chip on ebay for about 6 times the price and get it within the week, which I would do if I was in such a big hurry to get this fixed, but since I'm a week away from going on a 2 week vacation, I ordered from China as it will be here when I return. I ordered 10 pieces of the chip and another 10 pieces of the dual MOSFET, just in case.
                          I'll definitely come back here and update you all with my results.
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            #33
                            @John, see people with different levels of skills come here-some have a good grasp but some are really novice. Its difficult to guess the skill levels of the OP unless and otherwise he/she is regular on the forum. thats why i wanted to make sure your conclusion is right. Lets wait for the chip.
                            However, it'll be nice if you measure UG/LG/Phase pins with DSO. I think we can expect a peak of 24V approx on UG with pulse on DSO.
                            • John Jenson
                              • Dec 2018
                              • 32
                              A little background on me: I started out as an electronic technician back in the 80's and slowly evolved into a self taught embedded systems engineer. I was designing embedded systems with 8051's and derivatives in assembly language and ANSI C. Worked for a few big companies and then went solo after 2008. I've fixed a lot of things in my days, including laptops, although fixing laptops was never my specialty; which is why I came here, where I can expect technicians who do specialize in them.
                              I measured those voltages at the gates of the MOSFETs and they looked healthy. I wanted to really check the circuit with respect to phase, but because the datasheet didn't show any pin numbers and the circuit eventually died completely in midst of my testing , it kind of stopped me. Yeah, I could have buzzed out some of the pins with a continuity tester, but it really wouldn't buy me much at that point. I am pretty convinced the chip is bad and will replace it once it gets here and if need be I could replace a MOSFET or two as well.
                              • John Jenson
                                • Dec 2018
                                • 32
                                I replaced the charging chip and the two dual MOSFET's. The charging circuit is back to the way it was when I suspected it (before I killed it), but the laptop still has the same problem. I shouldn't have jumped the gun on the charging circuit, but I assumed it was supposed to work just like other switching supplies where the voltage on the coil will always be a stable voltage. However, this charging chip is a boost/buck converter (using 4 MOSFET's). When battery power is low, it goes into buck mode (only 2 MOSFET's are switching) and the voltage on the coil is stable (like other 2 MOSFET switching circuits), but when the battery is (almost) fully charged, it goes into boost/buck mode, where there are pulses on the coil as all 4 MOSFET's are firing; this is normal for this circuit. I couldn't get the full schematic with the pinouts for the ISL9538, but I found out the ISL9238 is electrically the same and I was able to use the datasheet for that as it was available. So the charging circuit was working correctly the whole time until I killed it, probably with a slip of a probe. At least I learned something about these boost/buck circuits that (I assume) aren't very common on laptops; and can share that with others.
                                Now I'm back to the original problem. I guess the next thing I will try is to physically reprogram the BIOS. Anyone have a BIOS for this board? Or do I have to repost it in another thread? I will be getting a RT809F programmer today, which should (hopefully) be able to reprogram this BIOS.
                                  VIP Moderator
                                  • Aug 2018
                                  • 4386
                                  • Bulgaria 🇧🇬
                                  #36
                                  Yes, you must request this at the "BIOS Requests ONLY!" subsection.
                                  https://www.badcaps.net/forum/forumdisplay.php?f=40
                                  Reminder: rules and organization of this section
                                  https://www.badcaps.net/forum/showthread.php?t=117483
                                  Become a Badcaps supporter
                                  Thanks to all supporters.​
                                  • todenkopf
                                    • Oct 2014
                                    • 49
                                    • UA
                                    #37
                                    Check resistor dividers on CSOP/CSON pins. Unplugging the battery you're kind of resetting some OVC protection and it looks to me that the problem lies in incorrect measurement of the current by the charger IC.
                                    • TheDando
                                      HP Envy X360 2-in-1 Laptop 15-fh0023dx Bios Needed
                                      by TheDando
                                      Laptop Name:HP Envy X360 2-in-1 Laptop 15-fh0023dx
                                      Model : 15-fh0023dx
                                      Motherboard Model : PM51 LA-M798P
                                      Serial : CND4040BKW
                                      ProdID : 7H1T1UA#ABA
                                      Laptop seems to boot on but no image on screen and caps lock is unresponsive...
                                      10-29-2025, 06:45 PM
                                    • Loki_Fido
                                      BIOS request for HP ENVY x360 2 in 1 Laptop 13-bf0***** PLEASE
                                      by Loki_Fido
                                      Hi ya folks,
                                      Hope everyone's having a good day.
                                      I have a HP ENVY x360 2 in 1 Laptop 13-bf0002TU with nothing on the screen.
                                      The laptop starts but no display. Connecting to an external monitor give me nothing too. Ive attached my original backup bios
                                      Make HP ENVY x360 2 in 1
                                      Model 13-bf0002TU
                                      S/N CND3171C5T
                                      Prod ID 6L2F0PA#ABJ
                                      I looked up at this site before writing this request. And there was a link. But i couldn't download any files from it.
                                      Any moderator could look it up, if possible? It says, "Invalid file specified"...
                                      06-16-2025, 08:02 PM
                                    • serious_electron
                                      Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                                      by serious_electron
                                      Hello Everyone!
                                      I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                                      06-28-2025, 02:57 PM
                                      HP ENVY x360 ENVY x360 15-cn0755nd Notebook Specification for Upgrade or Repair
                                      This specification for the HP ENVY x360 ENVY x360 15-cn0755nd Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 15-cn0755nd boardview and ENVY x360 15-cn0755nd schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                      09-06-2024, 06:51 AM
                                    • Bowline
                                      by Bowline
                                      06-11-2025, 10:13 AM
