Asus GL504GS
  • Dana24
    • Jan 2022
    • 18
    • Netherlands
    Asus GL504GS
    Working on a Asus Gl504GS mainboard.
    the laptop has no sound anymore tried anything in windows but still no luck.
    the realtek driver is also not shown in windows and it doesnt even play in the BIOS sounds.(startup logo sound)
    i founded one shorted CAP near the Realtek ALC3288 IC removed but still no luck.
    what should i do next? just replace the IC ?
    i do measure 5V in near by the IC. and the short is gone.
  • Dana24
    • Jan 2022
    • 18
    • Netherlands
    Re: Asus GL504GS
    up anyone?
    • mon2
      • Dec 2019
      • 14663
      Re: Asus GL504GS
      Is the (Iggy?) Azalia codec heating up ?
      What is the history of this unit? Any liquid damage near the audio section?
      What is the voltage to ground of AMP_SLEEP# ?
      Check each of the power rails that are shown in the schematic for this device.
      Each one is present and within the proper range?
      • Dana24
        • Jan 2022
        • 18
        • Netherlands
        Re: Asus GL504GS
        thanks for the reply ! no liquid damage, the Azalia Codec is not heating up there was a Shorted CAP wich was heating up near the Codec i removed the cap and the short was gone. i havent placed a new one yet might that be it ?
        • mon2
          • Dec 2019
          • 14663
          Re: Asus GL504GS
          The heat may have been only due to the shorted cap.
          Which cap was shorted?
          If this signal is a logic low = 0 volts, then the amp is being requested to enter sleep mode.
          • Dana24
            • Jan 2022
            • 18
            • Netherlands
            Re: Asus GL504GS
            I will measure the voltage once again and look up the cap i removed it.
            saddly im not at the office till tonight so i will updated it later on the day. thanks in advance
            • Dana24
              • Jan 2022
              • 18
              • Netherlands
              Re: Asus GL504GS
              on the amp sleep i see 0 volt.
              • Dana24
                • Jan 2022
                • 18
                • Netherlands
                Re: Asus GL504GS
                i replaced the cap but still no luck, i cant find the CAP on the manual and dont have boardview for this mainboard.
                • Dana24
                  • Jan 2022
                  • 18
                  • Netherlands
                  Re: Asus GL504GS
                  Up
                  • mon2
                    • Dec 2019
                    • 14663
                    Re: Asus GL504GS
                    This is an active low signal since the net name has a '#' suffix.
                    So with a 0 volt = low digital signal, the amp is being requested to turn OFF.
                    Remove all power, meter in resistance mode, check the resistance to ground of this enable signal.
                    What is the resistance reading ? If the resistance is not a low value, then the driver of this signal is controlling this amplifier status.
                    Check your BIOS settings. Any option for audio enable / disable ?
                    If the audio codec is not being detected, check the power rails for this device. Check the series ferrite beads that are used to filter the power rails that may be damaged due to an excessive current draw so now, the audio codec is not being powered so cannot be enumerated. If the codec was toasty hot, likely it is damaged and will need to be replaced.
                    Check the voltage to ground measurements on Q3003A
                    PS: What is the version of your board? Is it 2.0 or 2.1 ?
                    • Dana24
                      • Jan 2022
                      • 18
                      • Netherlands
                      Re: Asus GL504GS
                      thanks in advance.
                      Í will check the power rails and voltages one more time and the resistance.
                      in bios is the audio enabled, i tried disabling it and re-enabling but no luck.
                      • Dana24
                        • Jan 2022
                        • 18
                        • Netherlands
                        Re: Asus GL504GS
                        Resistance of AMP-sleep : .972m
                        Q3003A : Pin 1 2.5V
                        Pin 2 : 0
                        pin 3 : 0
                        pin 4 : 2.5v
                        pin 5 : 5v
                        pin 6 : 0
                        • mon2
                          • Dec 2019
                          • 14663
                          Re: Asus GL504GS
                          Confirm the pin #1 voltage. It should be the same reaching the codec for amp_sleep#. If you have a voltage here at pin #1 then it should be the same at the codec.
                            ASUS ROG GL504GS-ES056 Notebook Strix Specification for Upgrade or Repair
                            This specification for the ASUS ROG GL504GS-ES056 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL504GS-ES056 boardview and GL504GS-ES056 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                            09-06-2024, 09:17 AM
                            ASUS ROG GL504GS-ES129T Notebook Strix Specification for Upgrade or Repair
                            This specification for the ASUS ROG GL504GS-ES129T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL504GS-ES129T boardview and GL504GS-ES129T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                            09-06-2024, 09:06 AM
                            ASUS ROG GL504GS-ES081T Notebook Strix Specification for Upgrade or Repair
                            This specification for the ASUS ROG GL504GS-ES081T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL504GS-ES081T boardview and GL504GS-ES081T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                            09-06-2024, 07:29 AM
                            ASUS ROG GL504GS-ES056T Scar II Notebook Strix Specification for Upgrade or Repair
                            This specification for the ASUS ROG GL504GS-ES056T Scar II Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL504GS-ES056T Scar II boardview and GL504GS-ES056T Scar II schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                            09-06-2024, 07:25 AM
                            ASUS ROG Scar II GL504GS-ES111T Notebook Strix Specification for Upgrade or Repair
                            This specification for the ASUS ROG Scar II GL504GS-ES111T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Scar II GL504GS-ES111T boardview and Scar II GL504GS-ES111T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                            09-06-2024, 07:18 AM
