HP Pavilion x360 intermittent trackpad & keyboard only in windows
  • AJ847.63e
    • Aug 2020
    • 171
    • Africa
    Just wanted to see if anyone else is experiencing this as after googling it I found quite a few users expecting it but unfortunately no fixes. I've got a hp pavilion x360 that I've had for a little over a year now and after replacing the ssd and reinstalling windows 10 last week now suddenly the keyboard and trackpad don't want to work sometimes in windows.
    I've isolated it to only windows. Every time I boot into the bios it works fine. Sometimes when rebooting windows they will work, sometimes they won't I have to use the touch screen to enter my pin and to use the system no matter what I do it won't come back until I reboot the system like 4 or so times than finally it will come back to working again.
    I've tried all the usual solutions like uninstalling and reinstalling drivers, rolling back windows updates, disabling than enabling the devices in device manager, nothing solves it. I can see online this seems to be quite a common issue but no one seems to have a solution to it. I even contacted HP and they had no freaking clue apart from the steps mentioned above they want me to send it in for repairs despite it being pretty obvious it's not a hardware fault.
    Thanks for your assistance.
  • AJ847.63e
    • Aug 2020
    • 171
    • Africa
    Re: HP Pavilion x360 intermittent trackpad & keyboard only in windows
    Sorry forgot to mention this isn’t the first machine I’ve had doing this either. About a month ago I fixed the exact same model with a no power issue and it also had a intermittent trackpad & keyboard but the customer didn’t care as he uses externals anyway and desperately needed to get his uni assignments done. Seems to be a serious flaw with HPs drivers but because this is a old machine it’s not receiving updates anymore so it doesn’t look like this will ever get fixed.
    • mon2
      • 14685
      How does it behave if in Windows safe mode?
      Link or post a schematic.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Try loading Win7 for test purpose.
        • AJ847.63e
          • Aug 2020
          • 171
          • Africa
          I haven't had a look for schematics for this as I don't have the board out, and usually you need that to find them. This was just a simple ssd swap so I'd rather not take the board out and introduce more variables unless i absolutely have to.
          Haven't tried 7 so I'll give that a shot next week and report back. As for win 10 safe mode same behaviour as normal windows.
          One thing that's strange though is according to hps website if you hold down the esc key while booting that should take you to the bios but with this one it doesn't it just loads windows every time. I can get it into the bios though, and I can even load the hardware diagnostics tests using f11 if i remember right so other key combos are working.
          One other thing I was thinking is would it be worth downloading synaptics drivers from their website directly and trying to install those? HP doesn't have any newer drivers but I was hoping sometimes you can bypass this by going straight to the actual manufacturer of the parts website instead.
          • Kambi13
            • Aug 2022
            • 134
            • Portugal
            Have you tried to put back the original M2 Drive? Try to make a clone of the original drive and then use hp restore feature to put it back to factory settings. Also You can try to disable secure boot from UEFI settings and reinstall OS again.
            • AJ847.63e
              • Aug 2020
              • 171
              • Africa
              Unfortunately I can't put back the original m.2 as it failed, that was the reason this laptop came in. Secure boot was originally enabled so I had to disable and clear the keys before reinstalling windows.
              I'm thinking it's a recent windows update that's caused this issue. When I did a reinstall of 22h2 everything was fine, spent a few hours re installing drivers and copying old data from the customers old laptop to this one everything was fine until I decided to fully update windows and the final optional cumulative update seems to be what caused the issue but when I use the recovery mode to roll back updates it's not resolving the issue. I'm thinking I have to do a fresh wipe and re install again.
              • mon2
                • 14685
                Try the suggestions in this thread:
                https://answers.microsoft.com/en-us/...2-7bcb93816af1
                • AJ847.63e
                  • Aug 2020
                  • 171
                  • Africa
                  This can be closed off the issues resolved itself somehow. Left the laptop on sleep Thursday arvo with the keyboard and trackpad not working came back Tuesday morning to find the laptop off. Turned it back on and now no matter what I do I can't get the original fault to reproduce. Multiple reboots and both the keyboard and trackpad are fine. Guess the Easter bunny decided to fix it for me
                  Freaking Microsoft!!!
                  Thanks for the advice everyone.
                  • DrewPhillips
                    Upgrading XP to Windows 10 in 2025 - HP Pavilion HP-A550Y
                    by DrewPhillips
                    I am contemplating upgrading an old HP Pavilion HP-A550Y from Windows XP to WIndows 10. This machine has a 3 GHz Pentium 4 "Prescott" processor. I have some additional RAM to add. Have plenty of HDD space. I have several questions on how to best proceed at this late (for Windows 10, anyway) date.
                    Where is a good place to get a copy of Windows 10 and the activation key? Would I use 32 bit or would I use 64 bit version? Is it possible to do a fresh installation of Windows 10 these days and not an upgrade? If upgrading, is it possible to go from XP to 10 directly and without...
                    02-07-2025, 01:35 PM
                    HP Pavilion x360 Pavilion x360 - 15-dq1004na Hybrid (2-in-1) 15 Specification for Upgrade or Repair
                    This specification for the HP Pavilion x360 Pavilion x360 - 15-dq1004na Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion x360 - 15-dq1004na boardview and Pavilion x360 - 15-dq1004na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                    09-06-2024, 12:18 PM
                    HP Pavilion x360 Pavilion x360 - 14-cd0007na Hybrid (2-in-1) 14 Specification for Upgrade or Repair
                    This specification for the HP Pavilion x360 Pavilion x360 - 14-cd0007na Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion x360 - 14-cd0007na boardview and Pavilion x360 - 14-cd0007na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                    09-06-2024, 09:37 AM
                    HP Pavilion x360 Pavilion x360 Convertible Laptop PC 14-dh0500sa Hybrid (2-in-1) 14 Specification for Upgrade or Repair
                    This specification for the HP Pavilion x360 Pavilion x360 Convertible Laptop PC 14-dh0500sa Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion x360 Convertible Laptop PC 14-dh0500sa boardview and Pavilion x360 Convertible Laptop PC 14-dh0500sa schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...
                    09-06-2024, 09:23 AM
                    HP Pavilion x360 Pavilion x360 Convertible Laptop PC 14-dh0500na Hybrid (2-in-1) 14 Specification for Upgrade or Repair
                    This specification for the HP Pavilion x360 Pavilion x360 Convertible Laptop PC 14-dh0500na Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion x360 Convertible Laptop PC 14-dh0500na boardview and Pavilion x360 Convertible Laptop PC 14-dh0500na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...
