Acer E5-575 no charging, new battery
  • A1yn88
    • Mar 2014
    • 111
    Hello.
    I have an Acer E5-575, motherboard DAZAAMB16E0 REV. E, from a client. He said that he changed the battery on the laptop.
    After was discharged the battery could no longer be charged, so it was sent to the warranty where they sent it charged saying that there is no problem with it.
    I checked the switch on the case and the reset switch, I tried with another power supply.
    The orange LED lights up, and it shows that it is charging, in Windows, but in fact, it is not charging. If there is current in the battery, as it is now, the battery and the charger work together and separately, only the battery does not charge.
    Any suggestions?
    Thank you.
    BQ24780S
    1-ACN=23,76
    2-ACP=23,76
    3-CMSRC=23,69
    4-ACDRV=29,35
    5-ACOK=3
    6-ACDET=2,66
    7-IADP=0
    8-IDCHG=0
    9-PMON=0
    10-PROCHOT=0
    11-SDA=3,29
    12-SCL=3,29
    13-CMPIN=0
    14-CMPOUT=1,1
    15-BATPRES=0
    16-TB_STAT=3,43
    17-BATSRC=14,85
    18-BATDRV=14,85
    19-SRN=14,85
    20-SRP=14,85
    21-ILIM=0,9
    22-GND= -
    23-LDODRV=0
    24-REGN=6,09
    25-BTST=17,37
    26-HIDRV=15,85
    27-PHASE=15,85
    28-VCC=23,54
  • mon2
    • 14664
    Re: Acer E5-575 no charging, new battery
    Locate the charger IC. Meter in dc volts mode (30v or higher scale is ok).
    What is the top side marking of the charger IC.
    Carefully measure the voltage to ground of each pin of the charger IC. Have both, the adapter and battery connected.
    Post each measurement and the pin numbers.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Are you sure about ACN/ACP measurements? It should be 19V approx. Try with another multimeter or replace the battery of your multimeter. With such readings,every suggestion will be suspicious. Same for CMSRC/ACDRV
      • A1yn88
        • Mar 2014
        • 111
        The above measurements were made with the power supply and the battery, the laptop being turned off. These measurements are when the laptop is on.
        1-ACN=19,24
        2-ACP=19,24
        3-CMSRC=19,24
        4-ACDRV=25,04
        5-ACOK=3,00
        6-ACDET=2,65
        7-IADP=0
        8-IDCHG=0
        9-PMON=0
        10-PROCHOT=1
        11-SDA=3,29
        12-SCL=3,29
        13-CMPIN=0
        14-CMPOUT=0
        15-BATPRES=0
        16-TB_STAT=3,42
        17-BATSRC=14,85
        18-BATDRV=14,85
        19-SRN=14,85
        20-SRP=14,85
        21-ILIM=0,82
        22-GND= -
        23-LDODRV=0
        24-REGN=6,09
        25-BTST=16,33
        26-HIDRV=16,50
        27-PHASE=15,45
        28-VCC=19,00
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Sure about pin10 measurement?
          • A1yn88
            • Mar 2014
            • 111
            Yes, 1,012V
            • A1yn88
              • Mar 2014
              • 111
              I replaced the BQ24780S chip and it works.
              Thank you.
              • abrahim110
                [Help Needed] Acer Aspire 5 A517-52G โ€“ Removed Onboard RAM, Now Working But Battery Not Charging
                by abrahim110
                ๐Ÿงต [Help] Acer Aspire 5 A517-52G โ€“ Onboard RAM Removed, BIOS Mod Done, Battery Not Charging
                I have an Acer Aspire 5 A517-52G-53NB laptop.
                The onboard (soldered) RAM was faulty, so I physically removed the chip.
                I also successfully modified the BIOS using the SPD Removal Tool โ€“ the laptop now boots fine and works with an 8โ€ฏGB DDR4 SO-DIMM installed.
                โœ… System status:
                • BIOS mod is done (SPD removed)
                • Laptop boots to Windows normally
                • RAM is detected and stable
                โŒ Problem:
                The battery is not charging:
                • Power adapter
                08-06-2025, 06:15 AM
              • titomno2
                Acer A315-41G similar to AN515-42, AC OK Battery OK but not charging
                by titomno2
                Hi guys,
                I currently trying to figure out why the laptop of my friend did not charge.
                It is a Acer AN515-42 (Ryzen 5 2500U), I manage to make it works on AC and battery but no charging.
                At first it was not working on Battery, I discovered that PQ201 was knocked off and replace it => work on battery precharged on another computer.
                I also checked the small resistors between PQ312 and PQ201 and even if they are ugly values are OK.
                My issue, when I plug the charger computer off, it drains 0.25A during few seconds with amber light on (charging) then amber light blinks...
                06-11-2024, 11:52 AM
              • Julian Bailey
                HP ProBook 445 G8 Battery not charging
                by Julian Bailey
                Hi all
                We have in a HP ProBook 445 G8 laptop with AMD Ryzen 7 CPU. When power is connected the power LED light blinks 5 times then stops. Normally HP laptops will blink this LED 10 times as it does a self test when the AC adaptor is inserted. So there must be some sort of short somewhere.
                The battery doesn't charge, and is erratic on the MM voltage. Bench PSU LED pulsates when the battery is connected also. So the fault must be on the charging circuit?
                I have gone around the board with a MM and cant find anything
                Windows shows the battery fine,...
                10-11-2024, 10:34 AM
              • Source Code
                Acer Nitro 5 not charging but working with battery
                by Source Code
                Hello Everyone
                First I must say I am trying to learn electronics. I have an Acer Nitro 5. Board is LA-861P. The laptop does not charge but when it has battery life it would power on and work fine. I have use a multimeter to check the charger and I get 19v.
                Input on PBQ3 mosfet is 19v but no output or very low voltage. The voltage on PCZ65 and PCZ48 is 2v and it keep dropping after putting the charger for a few second. Battery pin would give like 0.200v declining.
                If I put the laptop off for like 2-3 months it would start charging again but I need to do this...
                11-17-2024, 12:44 AM
              • serious_electron
                Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                by serious_electron
                Hello Everyone!
                I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                06-28-2025, 02:57 PM
