Lenovo IdeaPad Flex 5 14IIL05, ticking sound
  • LaPCon_IT
    • Sep 2022
    • 81
    • Malta
    Hello people
    Unfortunately I'm looking for help again. This time the patient is: Lenovo IdeaPad Flex 5 14IIL05. Board LC55-15C 19792-1.
    I've bought it completely dead. Shorted main power rail. I found faulty U7205 - NX20P5090UK and PU4501 - TPS51393PRJER. Short's gone. Power suply shows oscillating current, around 20-40 mA. Laptop does not react for power switch and there is a ticking soung from the board.
    I traced 20V from jack to PU4403 - dual mosfet FDMS3600. Input of this mosfet is the last place where 20V is stable. On the output it's only 3.4-3.5V, oscillating. Pictures
    Suspecting PU4401 - BQ25710 being faulty, I replaced it but with no effect. Now, I have no idea where to look
    I've checked both mosfets. They are ok.
  • mon2
    • Dec 2019
    • 14634
    Re: Lenovo IdeaPad Flex 5 14IIL05, ticking sound
    Attach the power adapter.
    Carefully measure the voltage to ground of each pin of the charger IC (BQ / pu4401)
    Post each measurement.
    • LaPCon_IT
      • Sep 2022
      • 81
      • Malta
      Pin - voltage
      1 - 19.63
      2 - 19.52
      3 - 19.52
      4 - 3.28
      5 - 0
      6 - 1.57
      7 - 6.0
      8 - 0
      9 - 0
      10 - 0
      11 - 0
      12 - 0.2-0.3
      13 - 0.2-0.34
      14 - 0.08-0.13
      15 - 1.57
      16 - 0.04-0.14
      17 - 1.2
      18 - 3.5
      19 - 3.3-3.7
      20 - 3.3-3.7
      21 - 0.7-0.8
      22 - 3.3-3.7
      23 - 3.4-3.5
      24 - 3.4-3.5
      25 - 5.94
      26 - 0.05-0.14
      27 - 0
      28 - 0
      29 - 0.13-0.22
      30 - 5.9-6.3
      31 - 3.4-3.6
      32 - 3.4-3.6
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Resistance to GND on CLR, no power attached? Resistance mode measurement for dc-in mosfets between
        01.pin1-4
        02.Pin1-8
        03.Pin4-8
        • LaPCon_IT
          • Sep 2022
          • 81
          • Malta
          01.pin1-4
          02.Pin1-8
          03.Pin4-8
          Sorry, I don't get it.
          • LaPCon_IT
            • Sep 2022
            • 81
            • Malta
            OK, I think I know now. So I believe there are two CLR resistors: PR4419 and PR4402. Resistance is in Mohms on both.
            DC-in mosfets (PU4408, PU4407):
            PU4408:
            pin1-4: 147 kohm
            pin1-8: Mohm
            pin4-8: Mohm
            PU4407:
            pin1-4: 100 kohm
            pin1-8: Mohm
            pin4-8: Mohm
            • mon2
              • Dec 2019
              • 14634
              Many of the voltage readings of pu4401 are not in range.
              Can you confirm the voltage to ground of pin 28 = REGN?
              It should be ~6v and matching pin 7 voltage. Suspecting this is a measuring error since pin 7 is ~6 volts and is sourced from the REGN pin.
              Remove all power. Meter in resistance mode.
              What is the resistance to ground of 19V_DCBATOUT ?
              • LaPCon_IT
                • Sep 2022
                • 81
                • Malta
                Sorry, my mistake. Pin 28 has 6V. I double checked all pins and results are the same.
                • mon2
                  • Dec 2019
                  • 14634
                  Share the resistance to ground of the main power rail. No power in resistance mode checks.
                  • LaPCon_IT
                    • Sep 2022
                    • 81
                    • Malta
                    Mohms
                    • mon2
                      • Dec 2019
                      • 14634
                      Resistance is fine on the main power rail.
                      Suspects are the DCin mosfets and the charger IC.
                      Check the resistance of the first DCin mosfet pair. There are 2 mosfets inside this single package.
                      This is PU4403.
                      Check the HIGH side mosfet and LOW side mosfet in the same way.
                      Meter across the mosfet pins as follows:
                      Pins 2 & 1 (gate)
                      Pins 2 & 9
                      Pins 9 & 1 (gate)
                      Then repeat for the low side mosfet:
                      Pins 7 & 8 (gate)
                      Pins 7 & 9
                      Pins 9 & 8 (gate)
                      The next dual mosfet @ PU4405 should be checked in the same way.
                      • LaPCon_IT
                        • Sep 2022
                        • 81
                        • Malta
                        PU4403
                        Pins 1-2: Mohms
                        Pins 2-9: Mohms
                        Pins 9-1: 114k
                        Pins 7-8: 100k
                        Pins 7-9: Mohms
                        Pins 9-8: Mohms
                        PU4405:
                        Pins 1-2: Mohms
                        Pins 2-9: Mohms
                        Pins 9-1: 114k
                        Pins 7-8: 101k
                        Pins 7-9: Mohms
                        Pins 9-8: Mohms
                        • mon2
                          • Dec 2019
                          • 14634
                          The resistance is low.
                          Remove the 2nd dual mosfet and then check the resistance of the 1st dual mosfet that is still on the board.
                          Check the resistance of the removed mosfet while it is on your work table.
                          Post the readings again.
                          • LaPCon_IT
                            • Sep 2022
                            • 81
                            • Malta
                            OK, removed PU4405
                            PU4403
                            Pins 1-2: Mohms
                            Pins 2-9: Mohms
                            Pins 9-1: 114k
                            Pins 7-8: 97k
                            Pins 7-9: Mohms
                            Pins 9-8: Mohms
                            PU4405:
                            Pins 1-2: OL
                            Pins 2-9: 30k and growing
                            Pins 9-1: OL
                            Pins 7-8: OL
                            Pins 7-9: 1k and growing
                            Pins 9-8: OL
                            • mon2
                              • Dec 2019
                              • 14634
                              For PU4405, these are the measurements with the mosfet removed and being tested on your work table?
                              • LaPCon_IT
                                • Sep 2022
                                • 81
                                • Malta
                                Yes
                                • mon2
                                  • Dec 2019
                                  • 14634
                                  These are very low readings. Search out and replace this and also the first mosfet. Purchase a few spares - they should be available on Aliexpress.
                                  Share a link for a quick review before proceeding. The same shop should also have spare charger ICs. Each part will not be too expensive.
                                  • LaPCon_IT
                                    • Sep 2022
                                    • 81
                                    • Malta
                                    I have replaced them with AON6912A. They are not the same but similar enough I think. Result is the same - no change. And before you ask: I've also replaced PU4401 - twice. Perhaps the problem is somewhere else.
                                    • mon2
                                      • Dec 2019
                                      • 14634
                                      Yes, the mosfets look suitable for the replacement.
                                      Remove mosfet @ PU4409 (battery mosfet) and test again.
                                      • LaPCon_IT
                                        • Sep 2022
                                        • 81
                                        • Malta
                                        No change. Besides I have discovered that 3D3V_RTC_AUX is 4.8V. Is it good? With borrowed thermal camera I've also discovered EC getting warm at one point. After removing it ticking sound stopped. All oscillating voltages are now stable. I will order new EC and let you know.
                                          Lenovo IdeaPad IdeaPad Flex 5 14ALC05 Notebook 5 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IdeaPad Flex 5 14ALC05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Flex 5 14ALC05 boardview and IdeaPad Flex 5 14ALC05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 04:10 AM
                                          Lenovo IdeaPad IdeaPad Flex 5 14ALC05 Notebook Specification for Upgrade or Repair
                                          Lenovo IdeaPad Flex 5 Hybrid (2-in-1) Flex Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad Flex 5 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Flex 5 boardview and Flex 5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                          09-07-2024, 07:20 AM
                                          09-07-2024, 06:38 AM
