Hi guys i have a 820-00840 board here according to my USB C amp meter showing 5 volts and 0amp draw. I have PP3v3_G3H present on output of U6990 on UL6995 Coil. Also have enable from U7000 PM_EN_P3V3_G3H on pin 10 of U6990. On both CD32's the big caps close to it I got PP3v3_G3H present. On PPBUS_G3H diode mode 0.313v and Resistance is 1.549K around there.No corrosion on the board no history. is it possible it might have a dead SMC ? hoping you guys can maybe help point me in the right direction or have me check anything i missed. Thx
Macbook Pro A1708 2017 5v 0amp draw
Tags: None
Re: Macbook Pro A1708 2017 5v 0amp draw
Hi PPBUS_G3H = 0v
SMBUS_SMC_5_G3H_SDA = 3.4v
SMBUS_SMC_5_G3H_SCL = 3.4vComment
Remove fuse F7000. Power up again and check the voltage to ground of PPBUS_G3H.
If still 0 volts, remove all power.
Meter in diode mode.
Red meter probe to ground.
Black meter probe to F7000 pad #1. Reading?
Repeat with F7000 pad #2. Reading?Comment
Okay voltage on PPBUS_G3H = 0v
Diode Readings :
F7000 Pad 1 = 0.545v
F7000 Pad 2 = 0.312vComment
U7000 is a suspect. Post pics of this area.
What is the voltage in to this buck boost regulator?
Confirm the resistance of the current loop circuits on this regulator without power to the board.
The resistance checks must match the schematic values.
Is the SMC area clean and without corrosion ?Comment
I think you are right about it being U7000 as the suspect. It was working fine then a few days ago I had previously removed it and borrowed it to resurrect and troubleshoot 2 other boards i had.So maybe the other board may have killed it . Or it finally died because of all that hot air from removing and reballing and stuff.I will order some replacement ones and i'll report back if successful. thanks again monU7000 is a suspect. Post pics of this area.
Hi mon I just thought i'd report back.It was indeed the SMC.Looks like it was a bad SMC.I changed the SMC and it started back working again as normal. 20v and taking amps .And i have picture. Thanks again for the help.Comment
by soflesHello there
I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
...11-21-2024, 05:25 AM -
by CG_DionysosHello,
I am looking for the boardview file and the matching schematics (PDF) for the following MacBook Pro:- Model: A1707
- 15-inch, Mid 2017
- 3.1 GHz Core i7
- 16 GB RAM
- Radeon Pro 560
- 1 TB SSD
- Board number: 820-00928-A
Thanks in advance!
Greetings from Germany...-
09-16-2025, 06:43 AM -
by stefanbsThe laptop is Apple Macbook A1534 2017 with board 820-00687-А. The USB-C tester shows no voltage, there is 820-00244-А board available. I looked at both schematics, all connector signals seem to be the same. Did someone try to fit 820-00244-А board in A1534 2017?05-11-2025, 01:08 AM
by Sergio KubCould someone help me?
I have a Macbook Air A1466 EMC 3178 - 2017, board 820-00165 and sometimes the boot interrupts with an image of a folder and a question mark.
Could it be the BIOS? -
Could it be the BIOS? - Loading...
