Lenovo Yoga 530-14ikb, no charging, NM-B601
  • hopkok
    • Oct 2014
    • 178
    • Slovakia
    Hi masters, I have on bench strange Lenovo Yoga. It is working from charger and it is working from charged battery too. But if battery is connected and I plug charger in, not charging and works from battery. Not opening first mosfet, N1 point in schematic has 0V and N2 point has battery voltage, around 7,6V.
    BQ24780s changed but the same.
    voltage on BQ24780, battery connected:
    VCC-19V
    ACN-7.7V
    ACP-7.7V
    CMSRC-0V
    ACDRV-0V
    ACOK-3.3V
    ACDET-2.7V
    REGN -> 6 V
    BTST -> 7.4V
    Any help really appreciiated, many thanks in advance.
  • mon2
    • Dec 2019
    • 14299
    Re: Lenovo Yoga 530-14ikb, no charging, NM-B601
    Remove the PQ312 mosfet = 2nd DCin mosfet.
    Power up again and check the voltage of N1 test point.
    • hopkok
      • Oct 2014
      • 178
      • Slovakia
      N1=0V
      • mon2
        • Dec 2019
        • 14299
        Remove the 4k resistor (PR310) that is between the ACDRV pin and the gate pins of the DCin mosfets.
        Power up again -> measure the voltage to ground of the ACDRV pin pad (PR310, pin #2).
        Is the voltage on ACDRV now ~25 volts ?
        Remove all power.
        Meter in resistance mode.
        Check the resistance across the first DCin mosfet as follows:
        source (1-2-3) & drain (5-6-7-8) ; pick one pin from each group
        source (1-2-3) & gate (4)
        gate (4) & drain (5-6-7-8)
        Post each measurement.
        Also...post the resistance values of the first mosfet. Need to check if this mosfet is defective.
        • hopkok
          • Oct 2014
          • 178
          • Slovakia
          2nd mosfet needs to be attached back to board before this step?
          • mon2
            • Dec 2019
            • 14299
            No. Leave it off.
            • hopkok
              • Oct 2014
              • 178
              • Slovakia
              Remove all power.
              Power up again -> measure the voltage to ground of the ACDRV pin pad (PR310, pin #2). Voltage on PIN 2 is 0V
              • mon2
                • Dec 2019
                • 14299
                Remove all power. Meter in resistance mode.
                Measure the resistance from N1 test point to pin #3 (CMSRC) on the charger IC. What is the measurement?
                Check the resistance to ground of the same ACDRV pin (PR310, pin #2).
                Next, place the meter in DIODE mode.
                Red meter probe, yes red to ground.
                Black meter probe to the same ACDRV pin (PR310, pin #2).
                Updated the wrong post ... do post the mosfet checks for the first mosfet. Need to confirm it is not defective.
                Can you post a pic of the charger IC placement? It should be soldered down properly.
                • hopkok
                  • Oct 2014
                  • 178
                  • Slovakia
                  Sorry, now have to leave office, here is 19:30. I always soldering under SCOPE, it is soldered 100 percent good. It was same with old IC. Will post measurements as soon as possible. Many thanks for try to help. See you soon.
                  • hopkok
                    • Oct 2014
                    • 178
                    • Slovakia
                    Resistance from N1 test point to pin #3 (CMSRC) on the charger IC -> 4,2Kohms
                    Check the resistance to ground of the same ACDRV pin (PR310, pin #2) -> no resistance
                    Black meter probe to the same ACDRV pin (PR310, pin #2) ->0,646
                    source (1-2-3) & drain (5-6-7-8) ; pick one pin from each group ->11,5Mohms
                    source (1-2-3) & gate (4)->no resistance
                    gate (4) & drain (5-6-7-8)->no resistance
                    Anyway, I checked these DC in mosfets in diode mode before, no shorts...
                    • mon2
                      • Dec 2019
                      • 14299
                      Remove all power. Check the resistance of the mosfets at PQ316 and also the battery mosfet at PQ314.
                      • hopkok
                        • Oct 2014
                        • 178
                        • Slovakia
                        Resistace S-D, S-G and D-G same measuring as 1st DC in mosfet?
                        • mon2
                          • Dec 2019
                          • 14299
                          Yes. Suspecting that one of the other mosfets is leaking and forcing the charger IC to turn off ACDRV.
                          • hopkok
                            • Oct 2014
                            • 178
                            • Slovakia
                            PQ316
                            S-D-> 280Kohms
                            S-G-> 62Kohms
                            D-G-> 1,2Mohms
                            PQ314
                            S-D-> 4,3Mohms
                            S-G-> 0,48Mohms
                            D-G-> 1,2Mohms
                            • mon2
                              • Dec 2019
                              • 14299
                              PQ316 is too low on the measurements.
                              Can you remove it and then check the same resistance when the part is on your work table?
                              This part may be shorted.
                              • hopkok
                                • Oct 2014
                                • 178
                                • Slovakia
                                if I put red probe to S and black on D (in resistance mode) and vise versa, getting different readings, 280Kohms VS 4,4 Mohms... PQ316
                                • mon2
                                  • Dec 2019
                                  • 14299
                                  Can you test now without this mosfet installed? The battery should have a pre-charge on it.
                                  Just checking if the adapter and battery still fight it out on your logic board or not.
                                  • hopkok
                                    • Oct 2014
                                    • 178
                                    • Slovakia
                                    Do you mean take PQ316 off and do same measuring?
                                    Anyway, can this be ITE issue? I tried to read with SVOD 4 and not recognized...?
                                      • 21123
                                      You might have to power the board once .
                                      ITE series not detected in svod Solution.https://www.badcaps.net/forum/showthread.php?t=66674
                                      • hopkok
                                        • Oct 2014
                                        • 178
                                        • Slovakia
                                        motherboard powering up itself after charger connecting...
                                          Lenovo Yoga Yoga 6 13ALC7 Notebook 700 Specification for Upgrade or Repair
                                          This specification for the Lenovo Yoga Yoga 6 13ALC7 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Yoga 6 13ALC7 boardview and Yoga 6 13ALC7 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-07-2024, 05:00 AM
                                          Lenovo Yoga Yoga 7i (16? Intel) 2 in 1 Laptop Notebook 700 Specification for Upgrade or Repair
                                          This specification for the Lenovo Yoga Yoga 7i (16? Intel) 2 in 1 Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Yoga 7i (16? Intel) 2 in 1 Laptop boardview and Yoga 7i (16? Intel) 2 in 1 Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          Lenovo Yoga Yoga 6 13ALC7 Notebook Specification for Upgrade or Repair
                                          Lenovo Yoga YOGA Book Hybrid (2-in-1) Book Specification for Upgrade or Repair
                                          This specification for the Lenovo Yoga YOGA Book Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the YOGA Book boardview and YOGA Book schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                          09-06-2024, 08:10 AM
