Dell Inspiron 3585 CAL51 LA-F121P
  • mon2
    • Dec 2019
    • 14631
    Re: Dell Inspiron 15 5570 Plugged in not charging
    PR5: 2.168Ω
    Not mistyped It is indeed a 2K resistor
    So this should be written as 2.168K = ~2.2k or ~2K2 ohms.
    From the measurements on PD1, it may be ok since the voltage is ~3v. This ~3v is from the pull-up after PQ1 to park this line to ~3v.
    Common failures on the PS_ID line are @ PD1 and PQ1. More after picking up junior...
    • Eniaro
      • Mar 2021
      • 76
      Originally posted by mon2
      PD1 is a dual line unidirectional TVS diode for 5 volts.
      The part will be passive and remain out of circuit unless a transient event spikes the voltage higher than 5 volts. Then it will shunt the event to ground to protect the line from damage.
      Datasheet is attached. It is a common part that can be replaced by many other vendors.
      From where do you purchase your parts?
      Is there a Mouser or Digikey part that is similar? I can't seem to find it
      • mon2
        • Dec 2019
        • 14631
        Re: Dell Inspiron 3585 CAL51 LA-F121P
        This one should do the trick.
        5 volt working voltage.
        SOT-523 package.
        https://www.digikey.ca/en/products/d...2B3T-7/2918773
        and another one here:
        https://www.digikey.ca/en/products/d...02BXTG/5032246
        • Eniaro
          • Mar 2021
          • 76
          I ordered the little fuse and it's larger than what's installed. I decided to harvest one from Compal AAL15 LA-D071P : PD3
          With that done and replacing PQ1 it seems to be charging except... The PC no longer powers on. The light code is 2 Amber 1 White = CPU Failure
          Maybe it has something to do with the RC639 resistor? I'm going to remove it and see what happens
          • Eniaro
            • Mar 2021
            • 76
            New RC639 Resistor no RC639 resistor... no change 2 Amber 1 White
            Went from a pc that doesn't charge and runs slow, to won't power on... I'm lost
            • dana.repouille
              • Feb 2023
              • 39
              Re: Dell Inspiron 5570 CAL60 LA-F114P
              @Mon2
              I have taken resistance and voltage readings from a fully functional CAL60 LA-F114P motherboard (Inspiron 5570/5770). Could you please review my findings below, and in the three attachments I have uploaded? I would appreciate your feedback.
              On the edge of the CAL60 LA-F114P motherboard (under DC_IN)
              between PQ1 and PD2 (absent) there are five resistors:
              PR5, 2.2K-ohm (nearest the edge of the board)
              PR1, 33-ohm
              PR3, 100K-ohm
              PR6, 15K-ohm
              PR4, 10K-ohm (between PQ2 and the missing PD3)
              Measurements for each component of the PS_ID circuit:
              PL3 BLM15AG102SN1D_2P, 0.5-ohm
              1 to Power jack, ~3.3V
              2 to PD1/PR3/PQ1-1-Drain, ~3.3V
              PD1 TVNST52302AB0_SOT523-3, 0.8V voltage drop in diode mode
              1 to GND
              2 to PL3/PR3/PQ1-1-Drain, ~3.3V
              3 N/C
              PR3 100K_0402_1%
              1 to PL3/PD1/PQ1-1-Drain, ~3.3V
              2 to PR6/PQ2-2-Base, ~0.4V
              (voltage divider for PQ2-2-Base)
              PR6 15K_0402_1%
              1 to PR3/PQ2-2-Base, ~0.4V
              2 to GND
              PQ1 FDV301N-G_SOT23-3
              1-Drain to PL3/PD1/PR3 (~3.3V)
              2-Gate to PQ2-1-C/PR4 (~5V)
              3-Source to PR1 (~3.3V)
              PQ2 MMST3904-7-F_SOT323-3
              1-Collector to PQ1-2-Gate/PR4 (~5V)
              2-Base to PR3/PR6, ~0.4V
              3-Emitter to GND
              PR4 10K_0402_1%
              1 to +5VALW (5V pull-up)
              2 to PQ1-2-Gate/PQ2-1-Collector
              PR1 33_0402_5%
              1 to PQ1-3-Source (~3.3V)
              2 to PR5/MEC1416 pin 36 (~3.3V)
              PR5 2.2K_0402_5%
              1 to PR1/MEC1416 pin 36 (~3.3V)
              2 to +3VALW (3.3V pull-up)
                DELL Inspiron 3585 Notebook 3000 Specification for Upgrade or Repair
                This specification for the DELL Inspiron 3585 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3585 boardview and 3585 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Inspiron 3585...
                09-06-2024, 12:36 PM
                09-06-2024, 08:55 AM
                09-06-2024, 08:20 AM
                09-06-2024, 07:50 AM
