Alienware 17R2 dead, no power, no charging
  • Tend0
    E.E.C.S
    • Oct 2021
    • 92
    • Burkina Faso
    I just received an Alienware for repair, the pc seems to have been tweaked before.
    I did an inspection and some components are missing. the pc does not turn on, after the tests on the main rack I have the 19v from the charger to the drain of the pq707 and to the pq701and :
    PQ707 : Source= 17,46V ; Gate=19,52V ; Drain= 19,52V
    PQ701 : Source= 17,46V ; Gate=19,52V ; Drain= 19,52V
    PQ702 : Source= 17,46V ; Gate=14,18V ; Drain= 16,96V
    PR702:16,96
    I don't understand why the voltage at the main line is 16.96.
    Is it because missing of pr726, pr725 and pc722 and pc723 or a leaking MOSFET? Thanks for the help have a nice day
    Some images, board view and schematic in attached!!!!
  • mon2
    • Dec 2019
    • 13830
    Re: Alienware 17R2 dead, no power, no charging
    Remove all power. Meter in resistance mode.
    Check the resistance across the mosfet pins to see if the mosfet is shorted. A low resistance = defective mosfet.
    Start with the 2nd DCin mosfet @ PQ702.
    source (1-2-3) & drain (5-6-7-8)
    source (1-2-3) & gate (4)
    gate (4) & drain (5-6-7-8)
    Often, it is the 2nd mosfet that gets damaged.
    Then proceed to also check the first mosfet (pair?) @ PQ701 & PQ707.
    Post the measurements of each.
    Also of interest are the voltage to ground measurements of the charger IC.
    Meter in DC volts mode; 30v or higher is ok.
    Check:
    REGN ; pin 24
    ACOK ; pin 5
    ACDET ; pin 6
    VCC ; pin # 20
    Your gate voltage on the mosfets is low so suspecting that you have a leaky mosfet in the first 3.
    • Tend0
      E.E.C.S
      • Oct 2021
      • 92
      • Burkina Faso
      Meter in resistor mode; 600k
      PQ702
      source (1-2-3) & drain (5-6-7-8) OL
      source (1-2-3) & gate (4) 103 k
      gate (4) & drain (5-6-7-8) OL
      PQ701
      source (1-2-3) & drain (5-6-7-8) 61,6k
      source (1-2-3) & gate (4) OL
      PQ707
      source (1-2-3) & drain (5-6-7-8) 65,6k
      source (1-2-3) & gate (4) 66k
      gate (4) & drain (5-6-7-8) 0,1k
      Meter in dc mode; 60v
      REGN ; pin 24 : 6,04v
      ACOK ; pin 5 : 17,18v
      ACDET ; pin 6 : 2,36v
      VCC ; pin # 20 : 0,60v
      Missing PWR-3.3VALWP/5VALWP IC
      • mon2
        • Dec 2019
        • 13830
        Some errors in measuring. Can you confirm?
        VCC cannot be 0 volts if REGN voltage is 6v.
        ACOK appears to be too high. Check again.
        Remove pq702 and then measure the other mosfets again. Each mosfet has a low reading but may be due one bad seed in the bunch.
        • Tend0
          E.E.C.S
          • Oct 2021
          • 92
          • Burkina Faso
          Yes sir VCC is pin 28 or not pin 24
          ACOK ; pin 5 : 00v
          ACDET ; pin 6 : 1,53v
          VCC ; pin # 28 : 16,53v
          Mosfets mesure with removed PQ702
          PQ701
          source (1-2-3) & drain (5-6-7-8) 56,8k
          PQ707
          source (1-2-3) & drain (5-6-7-8) 400k
          source (1-2-3) & gate (4) 56,2k
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            PQ707 needs to be replaced.
            • tofik
              MOSFET equivalent K8A60DA
              by tofik
              Hello guys,
              I have a shorted MOSFET K8A60DA with the following characteristics:
              Type Designator: TK8A60DA
              Marking Code: K8A60DA
              Type of Transistor: MOSFET
              Type of Control Channel: N -Channel
              Maximum Power Dissipation (Pd): 45 W
              Maximum Drain-Source Voltage |Vds|: 600 V
              Maximum Gate-Source Voltage |Vgs|: 30 V
              Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
              Maximum Drain Current |Id|: 7.5 A
              Maximum Junction Temperature (Tj): 150 °C
              Total Gate Charge (Qg): 20 nC
              Rise Time (tr): 25 nS
              Drain-Source
              07-19-2023, 05:18 AM
            • gpx
              HP 250 G5 (LA-D704P with a Core i7-6500U) won't POST
              by gpx
              Hi everyone, I am hoping for a little help with an HP 250 G5 with motherboard LA-D704P with a Core i7-6500U. I am new to board repair but keen to learn.
              I am sorry this post is quite long but I was trying to systematically work my way through things.
              I don't know the history of the board – I bought it as part of a job lot.
              I have attached a number of photos of both sides of the board. I cannot seem to find a schematic or boardview online.
              When plugged in to DC power the power LED lights and the battery seems to charge. It will not...
              06-18-2021, 10:39 AM
            • Jane
              How do you test MOSFET in laptops ?
              by Jane
              I tried to use this method:
              Testing an N-channel MOSFET:
              Step 1: Discharge the Gate (turn off the MOSFET)
              Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
              Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
              Step 2: Charge the Gate (turn on the MOSFET)
              Now, place the red probe on the Gate (G) and the black probe on the
              09-27-2024, 03:31 AM
              Alienware 13 R3 Notebook Specification for Upgrade or Repair
              This specification for the Alienware 13 R3 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 13 R3 boardview and 13 R3 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Alienware 13 R3 Notebook...
              09-06-2024, 06:42 AM
