Asus K450J No light on display
  • redbond
    • Oct 2019
    • 12
    • Portugal
    Hello !
    I have a Asus K450J with a motherboard SV41JN MB 13320-1 and the problem is that the display don't have light, i tested with another display, i think the motherboard is not supplying the display.
    Can someone help me ?
    Thank you !
  • rediii
    h???, spurrrn
    • Mar 2018
    • 499
    • somewhere in europe
    Re: No light on display
    display has no backlight, i guess? but if you use a flashlight there is picture on screen? first and easiest step is to check the backlight fuse or 0-ohm resistor near the lcd connector. and never replace a display without disconnecting every power source (no ac adaptor nor battery).
    • redbond
      • Oct 2019
      • 12
      • Portugal
      No backlight but i can see the windows logo if i use a flashlight !
      I will try that man thank you !
      • rediii
        h???, spurrrn
        • Mar 2018
        • 499
        also you should check the cable. if nothing helps you need to do some measurements.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Re: Asus K450J No light on display
          Are you sure mb is posting?? Check whether usb keyboard numlock glows or not on toggling it. I've seen many people here troubleshooting edp connector for no display even when mb is not posting. So make sure its posting. If its posting, we can proceed to troubleshoot.
          • rediii
            h???, spurrrn
            • Mar 2018
            • 499
            he can see the windows logo on screen so it should post
            • alrieFRED
              ExComonicado
              • Feb 2021
              • philippines
              when dealing this kind of problem, you should check whether the voltage which is the main power rail is present on the LVDS connector,. check for 19v on the pins,. as for 3.3v is good because you have picture but without BL...there should be a FUSE.. check them as well..
              • redbond
                • Oct 2019
                • 12
                • Portugal
                Can someone help me get the schematics of the motherboard ?
                • mon2
                  • 14660
                  Asus schematics are often in the witness protection program but you will have to post this request in the forum above this area. Someone may have access to the sacred files.
                  Otherwise, post clear and zoomed pics of the area for a review.
                  Also share any other silk screen markings on the logic board that may help to identify the schematic / boardview files.
