Asus N705U no power
  • bouny56
    • Jan 2023
    • 67
    • france
    Asus N705U no power
    Hello
    Sorry for my poor english and my little electronic level
    Resolve my first laptop problem with this forum , i have now a second one with classic problem for lot's of you i think
    Please can you help me?
    model: Asus N705u
    Motherboard x705UN
    The laptop don't wake up
    I put 19v adapter, 19 come to first mosfet ok but nothing out and nothing on the gate
    No short circuit after it, no short after the main resistance too , nothing get hot with the thermal camera and 1,5v inject
    I try to get the IC charge controler
    it's a BQ24790S
    Here is the voltage
    ACn 0
    acp 0
    smsrc 0
    acdrv 0
    acok 6
    acdet 2,95
    iadp 0
    IDCHG 0
    PMON 0
    PROCHOT 0
    SDA 0
    SCL 0
    CMPIN 0,195
    CMPOUT 6
    batpres 0
    tb_stat 0
    batsrc 0,148
    batdrv 0
    srn 0,148
    srp 0,148
    ilim 0
    gnd 0
    LODRV 0
    regn 6
    btst 5,98
    hidrv 0,148
    phase 0,148
    vcc 18,83
    regn resistance 56kohm
    I try to understand, if i want the first mosfet open i need 25 or 26v on acdrv yes?
    Thank for your help
  • bouny56
    • Jan 2023
    • 67
    • france
    Re: Asus N705U no power
    Maybe i've find , i think the second mosfet stay open , because i have a beep for continuity with my multimeter , so the ic charge shut the power ?
    • mon2
      • Dec 2019
      • 14677
      Hi. Yes, ACDRV should be ~25v to enable the 2*DCin mosfets (N-channel).
      Remove all power. Meter in resistance mode.
      Measure the resistance across the mosfet pins.
      Source (1-2-3) & Drain (5-6-7-8)
      Source (1-2-3) & gate (4)
      Gate (4) & Drain (5-6-7-8)
      Post each measurement and the scale used on the meter. If the resistance is low, the mosfet is defective.
      Yes, often the 2nd DCin mosfet gets damaged and needs to be replaced.
      Also, locate and remove the ~4k ohm series resistor in ACDRV. Do not lose the resistor.
      After removing the resistor, what is the ACDRV voltage on the charger IC? Is it now ~25v ?
      • bouny56
        • Jan 2023
        • 67
        • france
        Hello thx for helping me
        first mos :
        source to drain 10,6m ohm
        source to gate 10,9 m ohm
        gate to drain : 256k ohm
        i search after the 4k ohm resistor don't find it for now
        • mon2
          • Dec 2019
          • 14677
          This is too low of a reading for a good mosfet.
          Can you now measure the same pins on the 2nd mosfet?
          It is possible that the 2nd mosfet is making the 1st mosfet look defective since they share the GATE pin voltage.
          Post each measurement.
          Suggestion is to flux and carefully remove the 2nd mosfet (not the first) off the logic board.
          Then with NO POWER, measure the resistance between the pins of the first mosfet. Do you now have a higher resistance between gate and drain pins?
          What are the topside markings of each of these mosfets?
          Attached is a partial schematic of an Asus X705UV logic board - yours may be similar.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            2nd dc-in mosfet is shorted.
            • bouny56
              • Jan 2023
              • 67
              • france
              Hello
              sorry for my late answer
              I change the second mosfet and everything work now fine
              Thx mon2 and mcplslg123 for help
              have a nice day
              • Scotchmist
                Asus GA502D keeps blowing mosfet
                by Scotchmist
                I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
                I have removed the mosfet and can run the laptop no problem
                The MOSFET is FDPC5018SG
                Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
                08-24-2024, 02:23 PM
              • MicroSMD Lab
                ASUS ROG Zephyrus GPU Mosfet repeat failure
                by MicroSMD Lab
                The board number is GU502DU. I repaired this a couple weeks ago and it came back with the same issue, same mosfet failed (PQH9201). I'm hoping that the GPU was spared this time.
                I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
                01-10-2024, 06:36 AM
              • someonenotyou
                ASUS G513R - cannot remove MOSFET
                by someonenotyou
                Hi.
                I have a ASUS G513R laptop with shorted MOSFET (MP86959GMW-Z 45A).
                I tried to preheat the board to 200C brom the bottom and with rework station set to 400C I flowed it for about 2min. The MOSFET does not come off.
                Of course, I did not force it, but tried to lift it up with tweezers.
                Is it possible, that these MOSFETs are glues to the board? Or it got welded to the board from the short? It looks intact, no signs of blowing up.
                10-10-2025, 11:05 AM
              • someonenotyou
                ASUS K570U (X570UD) low resistance after EC change
                by someonenotyou
                Hi.
                I have a ASUS K570U (board model X570UD) which had a bad EC (IT8995E-128 DXS). I ordered 2 new EC chips on AliExpress.
                After I changed first chip and powered it on, nothing happened, and I found out that there was a short on +3VA_EC. I desoldered the EC and checked +3VA_EC on board, it had kOhms (cant remember exact number). Then I checked the GND and +3VA_EC on the EC chip itself and they were shorted.
                Now, I soldered on the second chip and made measurements on all the pins (I have not powered the board with the new chip yet). And I found these pins...
                07-04-2025, 05:54 AM
              • Timp74
                Odd MOSFET only on some ASUS x99/x299/z370 motherboards..
                by Timp74
                Hi All,
                Could anyone comment on the purpose of the MOSFET circled in red in the attached photo of an ASUS ROG X299 Extreme VRM?
                I'm trying to fix an ASUS motherboard(WS x299 SAGE) with a similar VRM where this MOSFET has burnt out along with one of the IR3555m driver chips. From looking at photos of motherboard VRMs on the internet, it seems only some ASUS motherboards have a MOSFET like this. Although I've seen some photos of ASUS z370 boards where it's not populated. The MOSFET is usually a NTMFS4C06N. It has its drain connected to the output of the Vcore VRM, and on...
                08-13-2021, 01:11 PM
