Re: [help]asus gl703ge dead, no shorts!
Pin 12 is 19V. You've either put that on the LDO 5V rail, or to the gate of PQ62.
If your VREG3 and VREG5 are present, then you have power to your EC and it's not producing S5_ON. If other pre-requisites are there, then that leaves the EC as likely to have sustained damage.
You've learnt the hard way that you don't probe pins of a QFN buck converter when it's powered. Check your +1.05V rail for a short too, as this kind of SNAFU usually results in a dead PCH.
