[help]asus gl703ge dead, no shorts!
  • phantomEVO
    • Mar 2013
    • 507
    Hi! i have an asus gl703ge totallt dead.
    no shorts connected to power bench
    i've not 3,3 nor 5v...
    you can donwload boardview/schematic here
    https://www.badcaps.net/forum/showthread.php?p=1052820
    pu28 has not 3,3 and 5v out...it has voltage in, but i have no en1 and en2
    en1 and en 2 are "s5_on" and are coming from Ec IT8987...
    is it 8987 preprogrammed? should i try to change it?
    thanks
  • mon2
    • 14657
    Re: [help]asus gl703ge dead, no shorts!
    Remove all power. Measure the resistance to ground of these missing power rails. Need to check if the output coils of PU28 are being shorted.
    Post each measurement.
    • phantomEVO
      • Mar 2013
      • 507
      pl21 and pl22 output (+5v_s5 and +3_s5) are not shorted
      so what's next?
      i've 5v on ldo 5 and 3v on ldo 3
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        S5_ON will be released by EC if all basic requiremnts of EC is met. So i'll suggest to check basic requirement of EC like VCC/AVCC/VSTBY/Vbat/EC_RST#/RSMRST#/AC_IN etc. IT8987E is programmable.
        • phantomEVO
          • Mar 2013
          • 507
          So it Could be an EC problrm?
          I have not voltage on vcc of ec
          • mon2
            • 14657
            What is the voltage to ground of +3VPCU ?
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              VCC of EC is powered by +3VPCU as @mon2 has already highlighted. Go with his advice. However, with VCC being present, EC is not supposed to release S5_ON. Basic checks most often solves a problem.
              • phantomEVO
                • Mar 2013
                • 507
                3,2v present (pin 50) but no vcc on pin 11 of it8987
                • phantomEVO
                  • Mar 2013
                  • 507
                  how is it possible? -.-'
                  • mon2
                    • 14657
                    These are separate sequenced power rails.
                    Review the voltages on PU30. This part is the creator of the +3V that is missing on pin 11 of the ITE EC.
                    Post all voltage measurements to ground on PU30.
                    • reformatt
                      • Feb 2020
                      • 1488
                      You won't get anything out of PU30 till you have S5_ON from the EC to enable 3V_S5.
                      Review pg56 of the schematic which has the power sequencing. As @mcplslg123 stated, go through your pre-requisites first for the EC by paying attention to the sequence. Check signals +3V_RTC, RTC_RST#, AC_IN, +3V_PCU. Also pay attention to EC_WRST# (which should be high).
                      S5_ON is pulled up to +3VPCU_KBC by KR30, it will only be low if the EC is pulling it down (or there is problem in this part of the cct). If the above signals are ok, then I'd be looking at reprogramming the EC. It does load it's EC from the main BIOS, but I think this may only happen when the EC is blank.
                      • phantomEVO
                        • Mar 2013
                        • 507
                        i have not any voltage on pu30..
                        3,3v +3V_RTC on R1052
                        3,3v RTC_RST# on r1029
                        3,2v 3VPCU on r869
                        0v EC_WRST# on kr6
                        • mon2
                          • 14657
                          0v EC_WRST# on kr6
                          This is an active LOW signal since there is a # symbol as a suffix.
                          This means that with a 0v on this signal line, the EC is being parked in RESET mode. This line must return to a logic '1' = ~3v to allow for the EC to boot up its firmware. Often the ECs contain an internal 8051 microcontroller to perform the assorted tasks.
                          • phantomEVO
                            • Mar 2013
                            • 507
                            so, what could i do?
                            • reformatt
                              • Feb 2020
                              • 1488
                              EC_RST# is connected to a simple delay circuit to ensure EC reset doesn't go high till about 100ms after +3VPCU_KBC appears (time constant is 0.1).
                              So obviously check the impedance of this line to ground for a short etc. If good, check continuity of KR6 to +3VPCU_KBC, and to pin 14 of the EC.
                              • phantomEVO
                                • Mar 2013
                                • 507
                                i made a mistake: EC_WRST#is 3,2v, but i confirm i have 0v on pin 11 of EC (vcc)
                                ps i've found that PD3 is not present (burnt trace) and pq21 was replaced
                                i have 19v on the power jack, after second mosfet (pq21) i have 17,7 and not 19...i don't know if it is normal
                                • mon2
                                  • 14657
                                  Follow the suggestions on post #11.
                                  Measure each voltage in the top-down order. Post where the sequence stops.
                                  • phantomEVO
                                    • Mar 2013
                                    • 507
                                    I have read 200 Times page 56, i have also stamp this schemstic…but i don’t understand how to read it…
                                    I don’t understand the order of those power output
                                    Please Help me to understand!!
                                    • mon2
                                      • 14657
                                      Each is a signal that must go from low to high before the next line below it can do the same.
                                      So start with the top line.
                                      If this line is say at 0 volts, then the next signal below it cannot work.
                                      Starting with the top line, measure the voltage to ground. Stop if you see the a signal stuck at 0 volts.
                                      We know that you have a valid voltage at +3VPCU so check the next line.
                                      What is the voltage to ground of NBSWON# ?
                                      • phantomEVO
                                        • Mar 2013
                                        • 507
                                        NBSWON# 2,4v
                                          ASUS ROG GL703GE-EE057T Notebook Strix Specification for Upgrade or Repair
                                          This specification for the ASUS ROG GL703GE-EE057T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL703GE-EE057T boardview and GL703GE-EE057T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 09:00 AM
                                          ASUS ROG GL703GE-EE013 Notebook Strix Specification for Upgrade or Repair
                                          This specification for the ASUS ROG GL703GE-EE013 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL703GE-EE013 boardview and GL703GE-EE013 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 08:27 AM
                                          ASUS ROG GL703GE-GC053T Notebook Strix Specification for Upgrade or Repair
                                          This specification for the ASUS ROG GL703GE-GC053T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL703GE-GC053T boardview and GL703GE-GC053T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 07:58 AM
                                          ASUS ROG GL703GE-PS71 Notebook Strix Specification for Upgrade or Repair
                                          This specification for the ASUS ROG GL703GE-PS71 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL703GE-PS71 boardview and GL703GE-PS71 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                          09-06-2024, 07:33 AM
                                          ASUS ROG GL703GE-WH72 Notebook Strix Specification for Upgrade or Repair
                                          This specification for the ASUS ROG GL703GE-WH72 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL703GE-WH72 boardview and GL703GE-WH72 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
