[help]asus gl703ge dead, no shorts!
  • reformatt
    • Feb 2020
    • 1488
    Re: [help]asus gl703ge dead, no shorts!
    Pin 12 is 19V. You've either put that on the LDO 5V rail, or to the gate of PQ62.
    If your VREG3 and VREG5 are present, then you have power to your EC and it's not producing S5_ON. If other pre-requisites are there, then that leaves the EC as likely to have sustained damage.
    You've learnt the hard way that you don't probe pins of a QFN buck converter when it's powered. Check your +1.05V rail for a short too, as this kind of SNAFU usually results in a dead PCH.
    • phantomEVO
      • Mar 2013
      • 507
      refotmatt....i have s5_on resoldering "the original" pu28!!!!!
      and now
      s5_on 2,5v
      3v_s5 0.9v
      5v_s5 0,5v
      vreg3 3,3
      vreg5 0,5 (IMPOSSIBLE TO UNDERSTAND BUT WITH OTHER IC I HAVE 5,5V!!)
      • reformatt
        • Feb 2020
        • 1488
        For a RT6575DGQW, you need to use the TPS51225C as a substitute. There are two versions of the Richtek chip (C/D) and 3 versions of the TI chip (no suffix/B/C).
        Both versions have the LDO's as always on. Just check the datasheets, all that info is there.
        Have no explanation why you have no S5_ON. Only going off what you are telling me.
        • phantomEVO
          • Mar 2013
          • 507
          my original ic is
          5x=5h
          u19
          the replaced chip is
          51225c
          i've soldered another 51225c: same thing, no s5_on,but 5v on vreg5...as soon as i put the original ic, s5_on appear again, but i have 0,5 on vreg 5....
          is it normal that s5_on is 2,6v? shouldn't be higher? like 3v?
          i think to reprogram the bios
          • phantomEVO
            • Mar 2013
            • 507
            ok, replaced pu28, flashed bios, now i have
            Pin 6/20 3,1v
            (S5_on)
            Vreg3 3,4
            Vreg 5 5v
            But low voltage
            0,7 3v s5 0,4 5v S5
            pgood is 0vIf I pump 3v 0,100a on pin 8 of pu28, 3v drop to 1,8v I’ve disconnected pl22 from pin 1…and I’ve seen that the problem is on the other side (3v_s5)
            • phantomEVO
              • Mar 2013
              • 507
              so using thermal camera, i can see that au2 (audio codec) lu1 (lan) and u25 (become hot)
              removin au2 and lu1 i still have absortion from u25...but maybe it's normal?
              • reformatt
                • Feb 2020
                • 1488
                Well you've obviously got an overload on the +3V rail, either passive or active. Resistance to ground measurement? If you've had an overvoltage on that line, the usual suspect is the PCH.
                • phantomEVO
                  • Mar 2013
                  • 507
                  1,5 kohm
                  • jasko_jacker
                    • Oct 2014
                    • 1140
                    • italy
                    #69
                    In almost all rog models it is common that the pch is damaged, measure the resistance on the capacitors (usually it is sufficient to know the situation but not always)
                    • phantomEVO
                      • Mar 2013
                      • 507
                      So can't with do anything else?
                      • reformatt
                        • Feb 2020
                        • 1488
                        Refer to pg 59 of the schematic. +3V_S5 feeds a lot of other buses via load switches. Check resistance to ground for each supply after each load switch (PU21, 22, 23, 27, 29, 30, 34, 37). I'm assuming LCD/trackpad are also disconnected.
                        Also check resistance to ground @PL8 (+1.05V_S5)
                        • phantomEVO
                          • Mar 2013
                          • 507
                          Ok,but have you seen the video about thermal camera?
                          • reformatt
                            • Feb 2020
                            • 1488
                            U25 is your PCH, which based on my previous experience with +3V/+1.05V overloads, is normally fried.
                            You asked about what else to do, and you can check these things to isolate what is causing the overload. But odds are it's the PCH. Up to you whether you want to waste anymore time on it, or throw it on the donor pile.
                            • phantomEVO
                              • Mar 2013
                              • 507
                              What do you mean “with 3v/1v overload”??
                              Do you think i haven’t 3v/5v because of pch?
                              You think there is no hope?
                              • reformatt
                                • Feb 2020
                                • 1488
                                Too high a voltage on that rail.
                                • phantomEVO
                                  • Mar 2013
                                  • 507
                                  is it my failt???
                                  • reformatt
                                    • Feb 2020
                                    • 1488
                                    Does it matter? You need to find out whether the board is repairable or a donor. Steps I've already given you.
                                    • phantomEVO
                                      • Mar 2013
                                      • 507
                                      ok i will try
                                      • phantomEVO
                                        • Mar 2013
                                        • 507
                                        PL8 52ohm
                                        PU21 after pl20 170ohm
                                        22 pin 14 33kohm, pin 8 260 ohm
                                        23 pin 6 2,7k
                                        27 pin 6 2k
                                        29 pin 14 35k pin 8 60k
                                        30 pin 14 150k pin 8 9k
                                        34 pin 5 25k
                                        37 pin 6 10k
                                        • reformatt
                                          • Feb 2020
                                          • 1488
                                          PU12 pin 6
                                          PU13 pin 10 (or PL8) - this is +1.05V_S5 for the PCH
                                            ASUS ROG GL703GE-EE057T Notebook Strix Specification for Upgrade or Repair
                                            This specification for the ASUS ROG GL703GE-EE057T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL703GE-EE057T boardview and GL703GE-EE057T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-06-2024, 09:00 AM
                                            ASUS ROG GL703GE-EE013 Notebook Strix Specification for Upgrade or Repair
                                            This specification for the ASUS ROG GL703GE-EE013 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL703GE-EE013 boardview and GL703GE-EE013 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-06-2024, 08:27 AM
                                            ASUS ROG GL703GE-GC053T Notebook Strix Specification for Upgrade or Repair
                                            This specification for the ASUS ROG GL703GE-GC053T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL703GE-GC053T boardview and GL703GE-GC053T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-06-2024, 07:58 AM
                                            ASUS ROG GL703GE-PS71 Notebook Strix Specification for Upgrade or Repair
                                            This specification for the ASUS ROG GL703GE-PS71 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL703GE-PS71 boardview and GL703GE-PS71 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                            09-06-2024, 07:33 AM
                                            ASUS ROG GL703GE-WH72 Notebook Strix Specification for Upgrade or Repair
                                            This specification for the ASUS ROG GL703GE-WH72 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL703GE-WH72 boardview and GL703GE-WH72 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
