Thinkpad L540 5v/3.3v output issue
  • baddjavo
    • Jun 2018
    • 87
    • Serbia
    I have similar problem. Lenovo laptop came wont turn on on pwrbtn. Shortly after inspection found that missing 20v Vin in 3v_5v regulator. Probably burned track. So i shorted 20v from mosfets supply and get laptop working. Day after customer reported that laptop wont turn again. Figured, that voltages on 3.3v is 1.3v and on 5v is 2.1v, and ENC pin is 1.24v whitch is quite low like Mon2 said, but still giving output.
    I have read this thread and did same like Djosla said. Now i have correct voltage but laptop wont turn...
  • baddjavo
    • Jun 2018
    • 87
    • Serbia
    Re: 5/3.3v output issue
    • baddjavo
      • Jun 2018
      • 87
      • Serbia
      Re: Thinkpad L540 5v/3.3v output issue
      Update, after remove diode (diode.jpg) i got correct 3.3v and 5v.
      After a while TPS51123RGER regulator died.
      I have put back diode and changed TPS51123RGER with new.
      Now iam on starting point again.
      Question is, why ENC pin is on 1.27v ? Probably pure_hw_shutdown# signal after diode is bad.
      i have schematic from thinkpad L430 and boardview L530
      • mon2
        • Dec 2019
        • 13992
        What is the voltage to ground of PURE_HW_SHUTDOWN# ?
        Are the DCin mosfets bypassed / shorted to force the logic board to power on ?
        • baddjavo
          • Jun 2018
          • 87
          • Serbia
          DCin mosfets are good.
          PURE_HW_SHUTDOWN# yesterday was 0.7v, but right now is 0.8v, 0.1v increased, and 3.3 and 5v outputs are 1.4v and 2.3v, increased also. ENC pin was 1.27v and right now is 1.34v. Looks like some component changing characteristics.
          • mon2
            • Dec 2019
            • 13992
            Remove all power. Meter in resistance mode.
            Measure the resistance to ground for each of the above power rails.
            One meter probe on 3v3 rail; other to ground (shield is ok).
            What is the resistance ? Post each measurement.
            Do you have an oscilloscope? Perhaps the ENC pin is oscillating / pulsing and causing the above outputs to also be swinging on/off which with a meter will read to be a lower value.
            • baddjavo
              • Jun 2018
              • 87
              • Serbia
              mon2, after removing diode d3601 on picture all voltages are ok, ENC ok, 3.3v ok, 5v ok ... but pure_hw_shutdown# going to 9x plases, one is pnp transistor q2701 that cut ECRST from 3.3v to 1.4v which is needed in power sequence. Ill try to remove all components connected to pure_hw_shutdown# one by one to figure which one causing voltage drop.
              resistances on rails are: dcbatout 4M, ENC 95k, 3.3v 570ohm, 5v 30k , looks good, didnt notice overheating.
              No oscilation, checked with oscilloscope.
              • baddjavo
                • Jun 2018
                • 87
                • Serbia
                update
                tracing pure_hw_shutdown i came to U2802 (op amp) and removed
                R2815 ( 0ohm ) which connecting pure_hw_shutdown to U2802. After that motherboard starting. Laptop working.
                Question is why U2802 outputting wrong voltage and causing pure_hw_shutdown# voltage drop ?
                Something about FAN or some of PTC network failed ?
                • mon2
                  • Dec 2019
                  • 13992
                  Good job !!
                  Measure the voltage to ground on each pin of U2802 comparator.
                  • baddjavo
                    • Jun 2018
                    • 87
                    • Serbia
                    u2802
                    before bwrbtn
                    only pin 5: 5,11v
                    after bwrbtn
                    1: 3.65v 2: 0v 3: 5.11v 4: 0v and 5: 5,11V
                    customer call me, so ill leave this state. Laptop is working.
                    • Maxpower3
                      Brand name and Model Type for Lenovo error 2202 product name is invalid
                      by Maxpower3
                      Info for error 2202 LenovoThinkPad models and type
                      Extract from ThinkPad Maintenance Utilities Configuration File
                      plnsrv.ini Version 1.01
                      Some information that may be useful
                      There must also be missing models, add them to the list if you know of any.
                      Code:
                      brand name
                      20B1=ThinkPad Edge E445
                      20B2=ThinkPad Edge E545
                      20BC=ThinkPad Edge E145
                      20BM=ThinkPad X140e
                      20BL=ThinkPad X140e
                      20A3=ThinkPad X230s
                      20AH=ThinkPad X230s
                      20AK=ThinkPad X240s
                      20AJ=ThinkPad X240s
                      02-21-2024, 10:27 AM
                      Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook X Specification for Upgrade or Repair
                      This specification for the Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon + ThinkPad USB 3.0 Pro Dock boardview and X1 Carbon + ThinkPad USB 3.0 Pro Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                      09-06-2024, 11:40 AM
