Oz8660ln replacement
  • String2016
    • Nov 2015
    • 2233
    • philippines
    Can i replace OZ8660LN to OZ8691ln or OZ8690ln?
  • String2016
    • Nov 2015
    • 2233
    • philippines
    Re: Oz8660ln replacement
    Anyone can help i cannot find same chip
    • reformatt
      • Feb 2020
      • 1404
      You can get them on Aliexpress or eBay amongst others. Pretty easy to find from what I can see.
      • String2016
        • Nov 2015
        • 2233
        • philippines
        @reformatt but i have to wait for a long time I just want to know i have avail here OZ8691ln or OZ8690ln if i can use it?
        • reformatt
          • Feb 2020
          • 1404
          Without datasheets, I can't tell you. They appear to either be obsolete or supplied only to the vendors directly. The best you can do is find schematic with the other IC's in it and compare pinouts.
          • ferah831208
            • Aug 2019
            • 58
            • Cuba
            Not compatible, have several pins different and i received a laptop from a customer with a previous repair attempt and it had oz8691 instead of original oz8660, I didn't check schematics 😔😔 and I solder a new one and then I realized it cannot work, check pin 31 for example, also vdd chip. I didn't find a compatible I had to buy original
            • ferah831208
              • Aug 2019
              • 58
              • Cuba
              I had this pin to pin comparison if a anyone encounters the same situation.
