Elitebook usb code 10
  • mindstorm88
    • Feb 2023
    Hi guys , i have an HP Elitebook 850 G4 that lost all usb ports after a reboot. Everything was good before the reboot.
    in the device manager i get :cannot start xHCI USB code 10,
    if i put a bootable win10 usb key, it starts the setup , then to install it complain about a missing driver.
    bios unlocked then updated (was help on this forum)
    These are the solutions I have tried:
    1. Updating the driver
    2. Uninstall/reinstall
    3. System restore point
    4. Manually updating the driver by browsing for files
    5. Scanning for hardware changes
    6. Updating windows (already checked for updates and all good)
    7. Clean Windows installation
    8. BIOS update, default value
    9. HP support assistant update (all up to date). Through HP PC Hardware Diagnostics UEFI, no fail ,usb port ok (according to this, no hardware failure)
    10. Updates from Intel driver & support assistant (all up to date)
    I really don't know what else to try
    Can it be hardware failure even if HP UEFI says port are ok ?
  • mindstorm88
    • Feb 2023
    Re: Elitebook usb code 10
    update : i even tried to reflash the EC, nothing solve the problem.
    i tried to install Ubuntu, same problem it ask for missing driver !!
    it seems that my usb port are only good to boot at bios, after that all systems i tried to install ask for missing driver, probably a problem with the usb controller !!!
    • mon2
      • 14663
      Could this be some sort of security lock that is configured by your bios settings?
      • Curtissimo
        HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
        by Curtissimo
        Hi everyone.
        I have a HP Elitebook 850 G8.
        Serial: 5CG2324XM0
        ProdID 6L8D5EC#ABA
        It has a Winbond W25Q256JVEN Chip.
        I need to remove BIOS Password.
        I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
        Attached my dump.
        I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
        I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
        What I did:...
        08-26-2025, 04:42 AM
      • m3vuv
        getting an hp elitebook 8730w to work with a gpt drive with uefi
        by m3vuv
        Its a bit of a long tale but i swapped the original hd for a 2tb ssd,i want about 6 bootable partitions,it needs the uefi enabling in the bios,I am ok with that,the issue is i cant convert the drive to gpt when it has data on it,the issue is windows wont install to a gpt drive,there is a utility from hp to install the efi partition on the drive but it runs on windows,its a chicken and egg thing,can anyone explaine how hp did this?,I am pulling my hair out;it seems i need to run the hp uefi tool to make the uefi option work in the bios, but it needs windows to run this that wont install on a gpt...
        07-15-2024, 10:15 AM
        HP EliteBook 830 G8 Notebook 800 Specification for Upgrade or Repair
        This specification for the HP EliteBook 830 G8 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 830 G8 boardview and 830 G8 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP EliteBook...
        09-07-2024, 05:20 AM
      • Gau_saha
        Bluetooth driver error (code 10)
        by Gau_saha
        Hi
        I am not able to put on bluetooth dongle.Its giving bluetooth error (code 10).
        I have uninstalled the driver and reinstalled it .same problem persist .
        Help needed for troubleshooting the problem .
        12-12-2024, 09:30 AM
